Author Topic: Tool palette, Object selection and Event  (Read 24329 times)
FengK
Re: Tool palette, Object selection and Event
« Reply #60 on: June 08, 2007, 12:24:16 PM »
Tim, if you're not sure whether to implement it or not, how about adding a checkbox next to the button that says "De-select block after edit". something like this. and save user's choice in registry or somewhere, so the setting will be remembered next time when he/she uses this command.  is this palette made for editing block attributes? if so, what's the purpose of keeping the selectionset with multiple blocks? Thanks!
« Last Edit: June 08, 2007, 12:27:31 PM by Kelie »
« Reply #61 on: June 08, 2007, 01:18:03 PM »
Kelie,
You make a good point, and I think it should be implemented, but I can't find any way to deselect the selection set.  I will continue to look, and post back when I find what I'm looking for.
FengK
« Reply #62 on: June 08, 2007, 07:04:14 PM »
Kelie,
Thanks Tim. Can Application's Sendkeys function be used as an ugly fix? In lisp, it would something like this: (vla-eval (vlax-get-acad-object)  "Sendkeys \"{ESC}\"")  i don't know C#. this is just a guess.
LE
« Reply #63 on: June 08, 2007, 11:22:24 PM »
Master Tim;
Have you tried by adding:
public static void SelectionMade(object sender, SelectionAddedEventArgs e)
            if (!ps.Visible || string.Compare(AcadApp.GetSystemVariable("CmdActive").ToString(), "0") != 0) return;
            if (e.Selection.Count == 0 && e.AddedObjects.Count != 0)
                FillInControl(e.AddedObjects.GetObjectIds());
                e.Remove(0); //<<<===
            else if (ps.Count > 0) ps.Remove(0);
Might help...
Also, why is needed to keep the data on the palette, once the changes are applied? - maybe using something like:
        public static void OkayButtonClick(object sender, System.EventArgs e)
            Document Doc = AcadApp.DocumentManager.MdiActiveDocument;
            using (DocumentLock DocLock = Doc.LockDocument())
                ControlCollection CtrlCol = uc.Controls;
                using (Transaction Trans = Doc.TransactionManager.StartTransaction())
                    foreach (Control Ctrl in CtrlCol)
                        try
                            if (Ctrl.Tag != null)
                                ObjectId ObjId = (ObjectId)Ctrl.Tag;
                                AttributeReference AttRef = Trans.GetObject(ObjId, OpenMode.ForWrite) as AttributeReference;
                                if (string.Compare(AttRef.TextString, Ctrl.Text) != 0)
                                    AttRef.TextString = Ctrl.Text;
                        catch { MessageBox.Show("Could not update attribute value."); }
                    Trans.Commit();
                CtrlCol.Clear(); //<<<===
« Last Edit: June 09, 2007, 11:37:31 AM by LE »
« Reply #64 on: June 10, 2007, 12:31:19 PM »
Thanks for the suggestions Kelie and Luis.  I will try them on Monday when I have the ability to.
« Reply #65 on: June 11, 2007, 01:49:43 PM »
Kelie,
I don't see any 'SendKeys' with .Net for AutoCAD.  There is a 'SendStringToExecute' but that didn't work with what you have, and I don't have the time right now to look into this further.
Luis,
With removing it from the selection set that way, it wouldn't remove the selection set when updating the block once you change from one document to the other.  So I need to look for a different way using the selection set class, but I haven't seen any yet.  Real work is calling, so I can't spend time on this right now.
« Reply #66 on: June 13, 2007, 11:38:51 AM »
Thanks to Paul R. here for finding a suitable work around till I understand the option that Glenn posted.
Now for the code.  Comments/suggestions/advice all welcomed.
One thing I hope to get working is the scroll ability in the palette.  I have some blocks that I work on where this options would be really helpful.  I tried putting a mouse event (wheel) on the user control, but that didn't seem to work.  I will see what I can find when I have more time to look.
Thanks all for the help and suggestions!!
Edit:  Removed old code.
« Last Edit: June 14, 2007, 01:10:13 PM by T.Willey »
LE
« Reply #67 on: June 13, 2007, 12:02:56 PM »
Muy bien Tim;
I will test your routine, later at home... looks good (it is not hard as appears the coding in C# no?)
One question is the PICKFIRST sysvar value changed? and put it back as it was?
« Reply #68 on: June 13, 2007, 12:10:26 PM »
Muy bien Tim;
Thanks Luis.  :-)
Not really, but then again at the same time yes.  I think it is just the amount of research that you have to do because the langague is more powerful than lisp (which I'm used to using).
That is what I was thinking, but it worked when testing.  I don't really have time to research why it worked, as 'real' work is starting to come quickly and in bunches now.  Got big piles on my desk, which I like because the day goes faster.
« Reply #69 on: June 14, 2007, 01:11:55 PM »
Here is the code I'm happy with.  I added a context menu so that when you have a long list of attributes you can right click on the palette anywhere but a combo box and either apply to block or toggle the de-select option.
Thanks for all the help, and all the comments.
 * Created by SharpDevelop.
 * User: Tim Willey
 * Date: 6/1/2007
 * Time: 2:55 PM
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
 * v0.2 6/7/07 Changed the command method call and all method calls to static, per Tony T.'s recommendation
 *   and Luis E.'s example
 * v0.3 6/13/07 Changed the code per Kelie's and Luis E.'s request to have the option of de-select the objects once the
 *   apply button is pressed.  Thanks to Paul R. for the code to de-select the objects.
 *   Changed the code per Tony T.'s suggestions, so that it won't load up the tool palette when a command is active.
 * V0.4 6/13/07 Used Glenn R.'s suggestion for de-selection.
 * v0.5 6/14/07 Added a context menu to apply to block and toggle the de-selection option, it also displays what
 *   the option is currently.
using System;
using System.ComponentModel;
using System.Drawing;
using System.Drawing.Drawing2D;
using System.IO;
using System.Runtime.InteropServices;
using System.Windows.Forms;
using System.Collections;
using System.Data;
using System.Data.OleDb;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Windows.ToolPalette;
[assembly: CommandClass(typeof(AutoCAD3M.UserControl1))]
namespace AutoCAD3M
/// <summary>
/// Description of UserControl1.
/// </summary>
public class UserControl1 : System.Windows.Forms.UserControl
public UserControl1()
// The InitializeComponent() call is required for Windows Forms designer support.
InitializeComponent();
// TODO: Add constructor code after the InitializeComponent() call.
#region Windows Forms Designer generated code
/// <summary>
/// This method is required for Windows Forms designer support.
/// Do not change the method contents inside the source code editor. The Forms designer might
/// not be able to load this method if it was changed manually.
/// </summary>
private void InitializeComponent() {
// BlankUserControl
this.Name = "BlankUserControl";
this.Size = new System.Drawing.Size(232, 408);
#endregion
private static Autodesk.AutoCAD.Windows.PaletteSet ps;
private static UserControl1 uc;
private static System.Windows.Forms.Button OkBut;
private static System.Windows.Forms.CheckBox DeSelCkBox;
private static System.Windows.Forms.ContextMenu MyContextMenu;
private static bool FirstLoad = true;
private static bool IsDeSelChecked = true;
private static ObjectId BlockInForm = ObjectId.Null;
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedSSSetFirst")]
private static extern int acedSSSetFirst(long[] pset, long[] unused);
[CommandMethod("MyAttPalette")]
public static void CreateMyPalette()
if (ps == null) {
ps = new Autodesk.AutoCAD.Windows.PaletteSet("My Attribute Palette");
ps.Style = Autodesk.AutoCAD.Windows.PaletteSetStyles.ShowPropertiesMenu |
Autodesk.AutoCAD.Windows.PaletteSetStyles.ShowAutoHideButton |
Autodesk.AutoCAD.Windows.PaletteSetStyles.ShowCloseButton;
ps.Opacity = 90;
ps.Size = new System.Drawing.Size(250, 400);
ps.MinimumSize = new System.Drawing.Size(225, 400);
ps.DockEnabled = Autodesk.AutoCAD.Windows.DockSides.None;
ps.Text = "Edit attributes";
try { ps.AutoRollUp = true; }
catch {}
//ObjectId ObjId = SelectBlock();
//if (!ObjId.IsNull) CreateControls(ObjId);
ps.Visible = true;
ps.Dock = Autodesk.AutoCAD.Windows.DockSides.None;
if (FirstLoad) {
foreach (Document Doc in AcadApp.DocumentManager) {
Doc.Editor.SelectionAdded += new SelectionAddedEventHandler(UserControl1.SelectionMade);
AcadApp.DocumentManager.DocumentCreated += new DocumentCollectionEventHandler(UserControl1.onDocCreated);
AcadApp.DocumentManager.DocumentToBeDestroyed += new DocumentCollectionEventHandler(UserControl1.onDocToBeDestroyed);
AcadApp.DocumentManager.DocumentBecameCurrent += new DocumentCollectionEventHandler(UserControl1.onDocBecameCurrent);
FirstLoad = false;
public static void CreateControls (ObjectId ObjId) {
//MessageBox.Show("Creating controls.");
using (DocumentLock DocLock = AcadApp.DocumentManager.MdiActiveDocument.LockDocument()) {
AttributeDefinition AttDef = null;
uc = new UserControl1();
Point StPt = new System.Drawing.Point(2, 45);
bool FoundAtt = false;
using (Transaction Trans = AcadApp.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()) {
BlockTable BlkTbl = (BlockTable) Trans.GetObject(Doc.Database.BlockTableId, OpenMode.ForRead);
BlockReference BlkRef = (BlockReference) Trans.GetObject(ObjId, OpenMode.ForWrite);
BlockTableRecord BlkTblRec = (BlockTableRecord) Trans.GetObject(BlkRef.BlockTableRecord, OpenMode.ForRead);
Autodesk.AutoCAD.DatabaseServices.AttributeCollection AttCol = BlkRef.AttributeCollection;
foreach (ObjectId id in AttCol) {
AttributeReference AttRef = (AttributeReference) Trans.GetObject(id, OpenMode.ForRead);
foreach (ObjectId tempId in BlkTblRec) {
AttDef = Trans.GetObject(tempId, OpenMode.ForRead) as AttributeDefinition;
if (AttDef != null  && string.Compare(AttDef.Tag, AttRef.Tag) == 0) {
if (string.Equals(AttDef.Prompt, string.Empty))
UserControl1.CreateComboBoxAndLabel(AttRef.Tag, AttRef.TextString, AttRef.ObjectId, StPt, uc);
else UserControl1.CreateComboBoxAndLabel(AttDef.Prompt, AttRef.TextString, AttRef.ObjectId, StPt, uc);
FoundAtt = true;
break;
if (!FoundAtt) UserControl1.CreateComboBoxAndLabel(AttRef.Tag, AttRef.TextString, AttRef.ObjectId, StPt, uc);
else FoundAtt = false;
StPt = new System.Drawing.Point(StPt.X, StPt.Y + 30);
OkBut = new System.Windows.Forms.Button();
OkBut.Text = "Apply to block";
OkBut.Name = "Okbutton";
OkBut.BackColor = System.Drawing.Color.Silver;
OkBut.ForeColor = System.Drawing.Color.Navy;
OkBut.Location = new System.Drawing.Point(5, 0);
OkBut.Size = new System.Drawing.Size(220, 25);
OkBut.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Left | System.Windows.Forms.AnchorStyles.Right | System.Windows.Forms.AnchorStyles.Top)));
OkBut.Click += new System.EventHandler(UserControl1.OkayButtonClick);
uc.Controls.Add(OkBut);
DeSelCkBox = new System.Windows.Forms.CheckBox();
DeSelCkBox.Text = "De-Select objects after apply?";
DeSelCkBox.Size = new System.Drawing.Size(220, 20);
DeSelCkBox.Checked = IsDeSelChecked;
DeSelCkBox.Location = new System.Drawing.Point(5, 25);
DeSelCkBox.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Left | System.Windows.Forms.AnchorStyles.Top)));
uc.Controls.Add(DeSelCkBox);
uc.Resize += new System.EventHandler(UserControl1.FormResized);
uc.MouseWheel += new MouseEventHandler(UserControl1.WheelMoved);
MyContextMenu = new System.Windows.Forms.ContextMenu();
MyContextMenu.Popup += new System.EventHandler(UserControl1.MyPopupMenu);
uc.ContextMenu = MyContextMenu;
uc.AutoScroll = true;
uc.AutoScrollMinSize =  new System.Drawing.Size(0, 400);
ps.Add("Test", uc);
BlockInForm = ObjId;
public static void CreateComboBoxAndLabel (string cbName, string cbValue, object Obj, Point pt, UserControl1 uc) {
ComboBox cb = new System.Windows.Forms.ComboBox();
cb.BackColor = System.Drawing.Color.Silver;
cb.ForeColor = System.Drawing.Color.Navy;
cb.Name = cbName;
cb.Text = cbValue;
cb.Location = pt;
cb.Size = new System.Drawing.Size(150,25);
cb.DropDownStyle = System.Windows.Forms.ComboBoxStyle.Simple;
cb.Tag = Obj;
Label lb = new System.Windows.Forms.Label();
lb.Name = cbName;
lb.Text = cbName;
lb.Height = 20;
lb.Size = new System.Drawing.Size(200, 25);
lb.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
lb.Location = new System.Drawing.Point(pt.X + 5 + cb.Size.Width, pt.Y);
uc.Controls.Add(cb);
uc.Controls.Add(lb);
public static void OkayButtonClick (object sender, System.EventArgs e) {
using (DocumentLock DocLock = Doc.LockDocument()) {
using (Transaction Trans = Doc.TransactionManager.StartTransaction()) {
foreach (Control Ctrl in CtrlCol) {
try {
if (Ctrl.Tag != null) {
ObjectId ObjId = (ObjectId) Ctrl.Tag;
Trans.Commit();
if (DeSelCkBox.Checked) {
acedSSSetFirst(null, null);
else IsDeSelChecked = false;
AcadApp.UpdateScreen();
public static void FormResized (object sender, System.EventArgs e) {
OkBut.Size = new System.Drawing.Size(uc.Width - 15, 25);
public static void WheelMoved (object sender, MouseEventArgs e) {
MessageBox.Show(e.Delta.ToString());
public static void ToggleDeSelect (object sender, System.EventArgs e) {
DeSelCkBox.Checked = false;
else {
DeSelCkBox.Checked = true;
public static void MyPopupMenu (object sender, System.EventArgs e)
string tempStr = "Disabled";
if (DeSelCkBox.Checked) tempStr = "Enabled";
System.Windows.Forms.Menu.MenuItemCollection mic = MyContextMenu.MenuItems;
mic.Clear();
mic.Add("De-Select option is:  " + tempStr);
System.Windows.Forms.MenuItem mi1 = new System.Windows.Forms.MenuItem("  &Apply to block.");
mi1.Click += new EventHandler(OkayButtonClick);
mic.Add(mi1);
mi1.Enabled = new EventHandler(OkayButtonClick) != null;
System.Windows.Forms.MenuItem mi2 = new System.Windows.Forms.MenuItem("  &Toggle De-Select.");
mi2.Click += new EventHandler(ToggleDeSelect);
mic.Add(mi2);
mi2.Enabled = new EventHandler(ToggleDeSelect) != null;
// Not used.
public ObjectId SelectBlock () {
Editor Ed = Doc.Editor;
PromptEntityOptions Opts = new PromptEntityOptions("\n Select block: ");
Opts.SetRejectMessage("\n Entity not a block.");
Opts.AddAllowedClass(typeof (BlockReference), false);
PromptEntityResult Rslt = Ed.GetEntity(Opts);
return Rslt.ObjectId;
public static void SelectionMade (object sender, SelectionAddedEventArgs e) {
//MessageBox.Show("Selection fired.");
UserControl1.FillInControl(e.AddedObjects.GetObjectIds());
public static void FillInControl (ObjectId[] ObjIdArray) {
ObjectId BlkId = ObjectId.Null;
int BlkCnt = 0;
foreach (ObjectId ObjId in ObjIdArray) {
BlockReference BlkRef = Trans.GetObject(ObjId, OpenMode.ForRead) as BlockReference;
if (BlkRef != null && BlkRef.AttributeCollection.Count > 0) {
++BlkCnt;
BlkId = ObjId;
if (BlkCnt > 1) break;
if (BlkCnt == 1 && (BlockInForm != BlkId || ps.Count == 0)) CreateControls(BlkId);
else if (ps.Count > 0 && BlkCnt != 1 && !object.Equals(BlockInForm, ObjectId.Null)) ps.Remove(0);
public static void onDocCreated (object sender, DocumentCollectionEventArgs e) {
Document newDoc = e.Document;
newDoc.Editor.SelectionAdded += new SelectionAddedEventHandler(SelectionMade);
public static void onDocToBeDestroyed (object sender, DocumentCollectionEventArgs e) {
Document Doc = e.Document;
Doc.Editor.SelectionAdded -= new SelectionAddedEventHandler(SelectionMade);
public static void onDocBecameCurrent (object sender, DocumentCollectionEventArgs e) {
PromptSelectionResult psr = e.Document.Editor.SelectImplied() as PromptSelectionResult;
if (psr == null) return;
SelectionSet ss = psr.Value as SelectionSet;
if (ss != null && ss.Count > 0) UserControl1.FillInControl(ss.GetObjectIds());
TonyT
« Reply #70 on: June 14, 2007, 09:14:52 PM »
Hi Tim.
The above is not how to compare objects with integers (perhaps you got it from Luis?).
      if(  ! AcadApp.GetSystemVariable("CMACTIVE").Equals(0) )
           return;
« Last Edit: June 14, 2007, 09:15:58 PM by TonyT »
LE
« Reply #71 on: June 14, 2007, 10:20:43 PM »
Hi Tim.
nope, was not me.... :)
TonyT
« Reply #72 on: June 15, 2007, 04:55:39 AM »
Sorry Luis I thought I saw it on some code posted by you, but I guess
it was Tim's.
Hi Tim.
« Reply #73 on: June 15, 2007, 11:03:40 AM »
Hi Tim.
           return;
Thanks Tony.  Yea it was all me.  I tried different ways, but couldn't get it to fire correctly.  I will make that change.  Learned something new also.  :-)
Edit: When I do it this way it always returns false even when 'CmdActive' returns 0.  I tried to convert it to an integer, but that doesn't work either "Specified cast is not valid".  Unless you know another way, I have to do it the way I did, as I don't see another way to get the correct results.
« Last Edit: June 15, 2007, 11:50:59 AM by T.Willey »
Paul Richardson
« Reply #74 on: June 15, 2007, 06:16:41 PM »
Hi Tim.
           return;
           return;
"CMACTIVE"?
