Author Topic: Linking and updating objects  (Read 4148 times)
DMSS
« on: June 30, 2004, 03:11:23 PM »
I have a small (I think) project for you VB'rs.
1st create a 2D rectangle (10"long x 2" high) w/ a 1" dia. circle in the middle of the 2D shape in world-plan view.
Next,
Create a 3D shape of the 2D rectangle
We will call this the "elevation" view.
Create another rectangle (a right view of same object) w/ hole.
Then, A top, bottom and left view of the elevation object (again w/ hole).
Link all these views to the 2D elevation.
Changes made to the 2d elevation object should auto-change all views of the 3D object.
Interested?
This can be done using v-lisp, but you have to re-run the code to update the objects.
Hint: Use handles to find and link objects with.
