Author Topic: create Mtext in the midpoint of a rectangle  (Read 8466 times)
Humbertogo
« on: May 30, 2007, 07:51:20 AM »
Help :lol:
How can i addMtext in the midpoint of a rectangle and the same angle of the rectangle?
Sdoman
Re: create Mtext in the midpoint of a rectangle
« Reply #1 on: May 30, 2007, 08:36:11 AM »
Can you get the two coordinates from the rectangle's bounding box, and then calculate the midpoint?  I can't help you with VBA, but I just did almost the same coding task in Vlisp the other day.
DaveW
« Reply #2 on: May 30, 2007, 09:58:54 AM »
Help :lol:
Is the angle 3D or 2D?
Humbertogo
« Reply #3 on: May 30, 2007, 10:02:22 AM »
the angle is 2D
Bryco
« Reply #4 on: May 30, 2007, 10:16:35 AM »
Describe the rectangle. Is it allways the same size etc.
Guest
« Reply #5 on: May 30, 2007, 10:20:05 AM »
Here's a little snippet from one of my programs.  It uses regular text though.  It allows the user to select two points to create the rectangle and automatically adds the text at the center of the rectangle.
Option Explicit
Public Sub DrawTextInRectangle()
    Dim pnt1 As Variant, pnt2 As Variant
    Dim ctr(0 To 2) As Double, ht As Double
    Dim newText As AcadText
    Dim strText As String
    Dim intTextHeight As Integer
    strText = "THIS SPACE FOR RENT"
    intTextHeight = 10
    If getPoints1(pnt1, pnt2) = 0 Then
        Rectangle pnt1, pnt2
        ' Now add text at the midpoint of the rectangle...
        ctr(0) = (pnt1(0) + pnt2(0)) / 2
        ctr(1) = (pnt1(1) + pnt2(1)) / 2
        ctr(2) = (pnt1(2) + pnt2(2)) / 2
        ht = Abs(pnt1(1) - pnt2(1)) / 2
        Set newText = ThisDrawing.ModelSpace.AddText(UCase(strText), ctr, intTextHeight)
        newText.Alignment = 4
        newText.TextAlignmentPoint = ctr
        newText.StyleName = "Standard"
        newText.Update
    End If
' From Frank Oquendo
Private Function Rectangle(Point1, Point2) As AcadLWPolyline
    Dim vertices(0 To 7) As Double, pl As AcadLWPolyline
    vertices(0) = CDbl(Point1(0)): vertices(1) = CDbl(Point1(1))
    vertices(2) = CDbl(Point2(0)): vertices(3) = CDbl(Point1(1))
    vertices(4) = CDbl(Point2(0)): vertices(5) = CDbl(Point2(1))
    vertices(6) = CDbl(Point1(0)): vertices(7) = CDbl(Point2(1))
    Set pl = ThisDrawing.ModelSpace.AddLightWeightPolyline(vertices)
    pl.Closed = True
    Set Rectangle = pl
End Function
Private Function getPoints1(pt1 As Variant, pt2 As Variant) As Integer
' This sub returns two points, or an error flag if cancelled
   On Error Resume Next
   pt1 = ThisDrawing.Utility.GetPoint(, "Specify first corner:")
   If Err Then
      getPoints1 = -1
      Exit Function
   End If
   pt2 = ThisDrawing.Utility.GetCorner(pt1, "Specify opposite corner:")
   If Err Then
      getPoints1 = -1
      Exit Function
   End If
   On Error GoTo 0
End Function
Humbertogo
« Reply #6 on: May 30, 2007, 10:23:30 AM »
Humbertogo
« Reply #7 on: May 30, 2007, 10:25:37 AM »
attach
Guest
« Reply #8 on: May 30, 2007, 10:33:07 AM »
That's, ummmm..... not a rectangle.  Close, but it's not a rectangle.
Sounds/looks like you need to find the centroid of a closed polyline instead??
LE
« Reply #9 on: May 30, 2007, 10:50:54 AM »
That can be an easy one to do, and will help everyone, if you try to code something first, what is the code you have done, so far?
Thanks.
Humbertogo
« Reply #10 on: May 30, 2007, 10:59:53 AM »
in my drawing i have a different rectangles
i get some point and create a close polyline
     Dim LastObj As AcadEntity
     Dim objLWPolyline(0) As AcadLWPolyline
     Dim minExt As Variant
     Dim maxExt As Variant
     Dim MTextObj As AcadMText
     Dim corner(0 To 2) As Double
     Dim Pt As Variant, _
         varArea As String, _
         pstr As String, _
         SysVarName As String, _
         sysVarName2 As String, _
         VarData As Variant, _
         intData As Double, _
         textObj As AcadText, _
         text As Variant, _
         Height As Variant, _
         Msg As String, _
         varMinPt As Variant, _
         varMaxPt As Variant
Private Sub test()
     SysVarName = "DIMSCALE"
     sysVarName2 = "AREA"
     With ThisDrawing
          .SetVariable "OSMODE", 0
          .SetVariable "CMDECHO", 0
          '' Multiple getpoint method by Tony Tanzillo
          Msg = vbCrLf & "Select an Internal Point"
          Do
               Pt = .Utility.GetPoint(, Msg)
               If Err Then
                    Err.Clear
                    Exit Do
               End If
               On Error GoTo 0
               pstr = Replace(CStr(Pt(0)), ",", ".") & "," & _
                      Replace(CStr(Pt(1)), ",", ".")
               .SendCommand Chr(3) & Chr(3) & "._-boundary" & vbCr & pstr & vbCr & vbCr
                  Set LastObj = .ModelSpace.Item(.ModelSpace.Count - 1)
            If TypeOf LastObj Is AcadLWPolyline Then
                  Set objLWPolyline(0) = LastObj
                      objLWPolyline(0).GetBoundingBox varMinPt, varMaxPt
                      objLWPolyline(0).Delete
              End If
              corner(0) = varMinPt(0): corner(1) = varMaxPt(1): corner(2) = 0#
              Height = 2000#
               Set MTextObj = .ModelSpace.AddMText(corner, 10, "50")
                   MTextObj.Height = Height
'                   MTextObj.Rotate MTextObj.insertionPoint, lineObj.Angle
'                   MTextObj.Move MTextObj.insertionPoint, lineObj.endPoint
'               Set textObj = .ModelSpace.AddText(varArea, Pt, Height)
'               textObj.Update
               Msg = vbCrLf & "Next Internal Point or ENTER to exit: "
          Loop
          On Error GoTo 0
          .SetVariable "OSMODE", 703
          .SetVariable "CMDECHO", 1
     End With
     MsgBox "Done"
LE
« Reply #11 on: May 30, 2007, 12:31:21 PM »
I see why, I never went all the way with VBA, it is ugly the coding there... :)
Here is something I just did in C#, very simple, that might help you, you simple select a rectangle area, and the routine will place a text inside. HTH
using System;
using System.ComponentModel;
using System.Data;
using System.Text;
using System.IO;
using Autodesk.AutoCAD.Windows;
using System.Text.RegularExpressions;
using System.Runtime.InteropServices;
using System.Threading;
using System.Globalization;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcWd = Autodesk.AutoCAD.Windows;
Auxiliary functions:
        public static double Angle(Point3d pt1, Point3d pt2)
            return Math.Atan2((pt2.Y - pt1.Y), (pt2.X - pt1.X));
        public static Point3d Polar(Point3d ptBase, double angle, double distance)
            return new Point3d(ptBase.X + (distance * Math.Cos(angle)), ptBase.Y + (distance * Math.Sin(angle)), 0.0);
        public static double Distance(Point3d pt1, Point3d pt2)
            return Math.Sqrt(Math.Pow(pt2.X - pt1.X, 2) + Math.Pow(pt2.Y - pt1.Y, 2));
Command:
        [CommandMethod("PLACETEXT")]//place some text inside a rectangle area
        public void placetext()
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptEntityResult res = ed.GetEntity("\nSelect the rectangle base line: ");
            if (res.Status != PromptStatus.OK) return;
                Polyline poly = tr.GetObject(res.ObjectId, OpenMode.ForRead, false) as Polyline;
                if (poly != null)
                    Point3d pickPoint = res.PickedPoint;
                    Point3d oPoint = poly.GetClosestPointTo(pickPoint, ed.GetCurrentView().ViewDirection, false);
                    double param = 0;
                    param = poly.GetParameterAtPoint(oPoint);
                    double sparam=0, eparam=0;
                    sparam = (int)param;
                    eparam = sparam + 1;
                    Point3d sp = poly.GetPointAtParameter(sparam);
                    Point3d ep = poly.GetPointAtParameter(eparam);
                    double ang = Angle(sp, ep);
                    Extents3d ext = poly.GeometricExtents;
                    Point3d min = ext.MinPoint;
                    Point3d max = ext.MaxPoint;
                    Point3d geoCtr = Polar(min, Angle(min, max), Distance(min, max) / 2.0);
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    DBText txt = new DBText();
                    txt.TextString = "TESTING"; //<==change to your default string value
                    txt.SetDatabaseDefaults(db);
                    txt.Height = Distance(min, max) / 8.0; //<==change to your default height
                    txt.HorizontalMode = TextHorizontalMode.TextMid;
                    txt.Rotation = ang;
                    btr.AppendEntity(txt);
                    tr.AddNewlyCreatedDBObject(txt, true);
                    txt.AlignmentPoint = geoCtr;
                tr.Commit();
« Last Edit: May 30, 2007, 12:35:50 PM by LE »
Fatty
« Reply #12 on: May 30, 2007, 01:33:31 PM »
There is not exactly what you
need but may help I think
You can add there the part to get
second point on the desired edge and then
calculate rotation angle of text
~'J'~
Option Explicit
Sub AddSomeLabel()
Dim varPt As Variant
Dim oPoly As AcadLWPolyline
Dim oEnt As AcadEntity
With ThisDrawing
.Utility.GetEntity oEnt, varPt, "Select polyline (pick left point on the edge)"
If TypeOf oEnt Is AcadLWPolyline Then
Set oPoly = oEnt
Else
MsgBox "Wrong entity selected"
Exit Sub
End If
Dim txtPt As Variant
txtPt = PseudoCenter(oPoly)
Dim oText As AcadMText
Dim txtStr As String
txtStr = "Blah\PBlah\PBlah"
Dim pointUCS As Variant
pointUCS = .Utility.TranslateCoordinates(txtPt, acUCS, acUCS, False)
Set oText = MakeMText(pointUCS, txtStr)
End With
Function MakeMText(txtPt As Variant, strTxt As String) As AcadMText
Dim oMText As AcadMText
Dim oLine As AcadLine
Set oMText = ThisDrawing.ModelSpace.AddMText(txtPt, 0#, strTxt)
oMText.AttachmentPoint = acAttachmentPointMiddleCenter
oMText.InsertionPoint = txtPt
oMText.Update
Set MakeMText = oMText
End Function
Function PseudoCenter(oPoly As AcadLWPolyline) As Variant
Dim minPt As Variant
Dim maxPt As Variant
oPoly.GetBoundingBox minPt, maxPt
Dim centPt(2) As Double
centPt(0) = (minPt(0) + maxPt(0)) / 2
centPt(1) = (minPt(1) + maxPt(1)) / 2
centPt(2) = (minPt(2) + maxPt(2)) / 2
PseudoCenter = centPt
End Function
Bryco
« Reply #13 on: May 30, 2007, 01:59:59 PM »
Mathimatically this is very problematic.
The first instinct is to use the centroid as Matt suggested,
however this fails with an "L" as the centroid is outside the line,
Luis's method will always work (if I can read it correctly)
DaveW
« Reply #14 on: May 30, 2007, 02:19:53 PM »
Sorry I do not have time to code it, but this is what I would do:
I would make a region from the polyline. If the polyline is not closed I would set the system variable of plinetype to 2. Then sendcommand pedit, maybe using the multiple option. Then turn the close polyline into a region and get the centroid. As long as these so called rectangles are close enough to one, the centroid should be fine.
Next I would find the longest line in that rectangle and get its start and endpoint. Get its angle from the wcs, either by drawing a line or parsing the polyline for the longest line and their length. Then use the returned centroid and the angle of the line/points to place the text.
« Last Edit: May 30, 2007, 03:18:42 PM by DaveW »
Fatty
« Reply #15 on: May 30, 2007, 03:08:54 PM »
Thanks Bryco I knew that by OP
asked about contours similar on
rectangles though...
Regards
~'J'~
LE
« Reply #16 on: May 30, 2007, 04:00:47 PM »
Bryco;
I did not look at that, but to fix it in a simple way is to just add the code below to my function:
Point3d p1 = poly.GetPointAtParameter(0.0);
Line line1 = new Line(p1, geoCtr);
Point3dCollection points = new Point3dCollection();
poly.IntersectWith(line1, Intersect.OnBothOperands, points, 0, 0);
if (points.Count == 2)
    txt.AlignmentPoint = Polar(points[0], Angle(points[0], points[1]), Distance(points[0], points[1]) / 2.0);
The above, will force the position of the text to be inside of the area, if it is an L or U shape, is not optimized but (can be) works!
And the whole function modified/updated:
        if (poly != null)
            double param = 0;
            txt.Rotation = ang;
        tr.Commit();
Bryco
« Reply #17 on: May 30, 2007, 04:09:10 PM »
I'll try that tonight Luis.
Fatty you are right.
Humbertogo
« Reply #18 on: May 31, 2007, 12:38:26 PM »
I will try in C#
one more question how can i translatethis code  in C#
 :-D
              End If
LE
« Reply #19 on: May 31, 2007, 12:58:38 PM »
I will try in C#
 :-D
              End If
 :-o want to use sendcommand?... I would rather go and draw the polyline without using the command boundary... but is up to you.
If I have time, I will try to write something, so you pick the points of an area, then create a closed polyline, and want to place any text inside no? or is that text the area?... just want to confirm....
Thanks.
Humbertogo
« Reply #20 on: May 31, 2007, 01:22:38 PM »
LE,
In my drawing i have a routing of house, my idea was to pick
a point in mid. of each house create a closed polyline and place  text inside
LE
« Reply #21 on: May 31, 2007, 01:47:54 PM »
I see, ... but you have here something to start (did you tested the command PLACETEXT or adapted the C# code to suit your needs?), the only other problem I see, is that when you end up having an area, where the command boundary or bpoly, not capable to generate the closed area, then you will require to do it manually or make your own boundary generator, when bpoly fails,  will see if a solution is provided...
[edited by me]
« Last Edit: June 04, 2007, 09:54:14 AM by LE »
Humbertogo
« Reply #22 on: May 31, 2007, 03:09:05 PM »
Oh y that is the one :-D
havano
« Reply #23 on: June 03, 2007, 10:26:33 AM »
I solved your problem in VBA by not using Mtext but linear Dimensions. First, I determined the midpoint XYs of the two opposite vertical(ish) rectangle sides for positioning and aligning the dimension. Then, I set the dimension offset to 0, turned all dimension graphics off (arrows etc.) and replaced the dimension value with the text I desired.
« Last Edit: June 03, 2007, 10:47:52 AM by havano »
Matersammichman
« Reply #24 on: June 04, 2007, 09:02:46 AM »
I'm trying to do something along those same lines- :lol:
I'm working at using a Region to obtain the Room Length x Width for a Room Size attribute.
Anyone else already done this...?
Humbertogo
« Reply #25 on: June 05, 2007, 04:41:11 AM »
may no the best way but i solved the  problem in VBA  :-D
Public Sub test()
Dim intnum As Integer
Dim PolyCoord As Variant
Dim PolySp(0 To 2) As Double
Dim PolyEp(0 To 2) As Double
Dim AngleInDegree As Double
Dim strAng  As String
intnum = 5
NumCout = 2
     With ThisDrawing
          Do
               If Err Then
                    Err.Clear
                    Exit Do
               End If
               On Error GoTo 0
                ' Return all the coordinates of the polyline
                      PolyCoord = objLWPolyline(0).Coordinates
                      PolySp(0) = PolyCoord(0): PolySp(1) = PolyCoord(1)
                      PolyEp(0) = PolyCoord(2): PolyEp(1) = PolyCoord(3)
                Set objLine = ThisDrawing.ModelSpace.AddLine(PolySp, PolyEp)
                    AngleInDegree = Format(objLine.Angle / PI * 180# + 90 - 270, "##.000")
                    objLine.Delete
                    strAng = Replace(CStr(AngleInDegree), ",", ".")
                    dblAngle = .Utility.AngleToReal(strAng, acDegrees)
              End If
                Height = 2000#
                midPoint(0) = (varMinPt(0) + varMaxPt(0)) / 2
                midPoint(1) = (varMinPt(1) + varMaxPt(1)) / 2
                midPoint(2) = 0
               Set MTextObj = .ModelSpace.AddMText(corner, 10, " {\fVerdana|b0|i0|c0|p34;" & intnum & "}")
                   MTextObj.AttachmentPoint = acAttachmentPointMiddleCenter
             Call MTextObj.Rotate(midPoint, dblAngle)
                   MTextObj.Move MTextObj.insertionPoint, midPoint
                   MTextObj.color = acYellow
                    intnum = intnum + NumCout
          Loop
          On Error GoTo 0
     End With
     MsgBox "Done"
Matersammichman
« Reply #26 on: June 05, 2007, 08:33:38 AM »
Humbertogo,
Why not create the MText first, then just use BoundingBox to create a rectangle around it?
Dnereb
« Reply #27 on: June 05, 2007, 09:51:40 AM »
the bounding box doesn't detect the text but the grip box of an mtext object.... this can be smaler or biger then the contained text.
Humbertogo
« Reply #28 on: June 05, 2007, 09:59:06 AM »
right
LE
« Reply #29 on: June 05, 2007, 10:00:30 AM »
He wants to place a text in the geometric center or inside of a boundary (Lot), normally will be a rectangle, that's what I understood :).
Humbertogo
« Reply #30 on: June 05, 2007, 10:27:30 AM »
in the center  of a boundary
