Cab,
Hello, how is everything going? I have attached two sample files that shows what I am doing. The drawing that is named (before) has text inside of a boundry that designates the room number. The drawing that is named (after) has the attribute called Room-tag inside each boundry. When that attribute is inserted, it would take the room number inside the boundry and automatically place is in the attribute. When you look at the attribute, you will find a place holder for the room number. Also, could you please add a command to this routine to get the area in sq. ft. and add it to the attirbute. When you look at the attribute, you will find a place holder for the area.
Thank you,
Brad
