Author Topic: Dot Net from VLisp?  (Read 2022 times)
mkweaver
Dot Net from VLisp?
« on: May 25, 2007, 10:27:03 AM »
Is it possible to access the Dot Net Framework from VLisp?  I seem to remember seeing a way to do this, but can't find it now:-(
Mike Weaver
Re: Dot Net from VLisp?
« Reply #1 on: May 25, 2007, 06:11:02 PM »
depends what you mean by 'access' Mike. for the sake of this discussion, yes.
« Reply #2 on: May 25, 2007, 06:15:49 PM »
I believe you could write an ActiveX dll (e.g. Delphi, C++, VB6 Pro / Enterprise ...) that wraps select .NET functionality, which could then be easily invoked from Visual LISP.
Whether you want to do this rather than going direct via C# / VB.NET etc. is a matter for colorful debate.
