Author Topic: remove a item from list  (Read 4950 times)
subbup
« on: June 29, 2004, 07:07:19 AM »
I know the position of an item in a list.
Till that position I want to remove all the items.
Is there any function to do this.
hendie
« Reply #1 on: June 29, 2004, 07:13:57 AM »
have you looked into vl-remove ?
subbup
« Reply #2 on: June 29, 2004, 07:27:03 AM »
It's removing all the duplicates in a list.
but I want to delete upto particular position in a list.
« Reply #3 on: June 29, 2004, 07:44:44 AM »
this is as beautiful as some but.......
(setq lst (list 23 23 43 54 90 77 88 99))
(23 23 43 54 90 77 88 99)
; remove the first three elements
(repeat 2 (setq lst (vl-remove (nth 0 lst) lst)))
(54 90 77 88 99)
« Reply #4 on: June 29, 2004, 08:34:44 AM »
Using the same list as Mark:
(defun list_trim (lst posit / )
  (repeat posit (setq lst (cdr lst)))
  lst
_$ (setq lst (list 23 23 43 54 90 77 88 99))
_$ (list_trim lst 3)
(54 90 77 88 99)
_$ (list_trim lst 5)
(77 88 99)
_$ (list_trim lst 2)
(43 54 90 77 88 99)
_$ (list_trim lst 1)
(23 43 54 90 77 88 99)
BTW Mark, can you see why your code removes the first three elements of your list when you only run repeat twice?
« Reply #5 on: June 29, 2004, 09:59:23 AM »
Hay that's fun. :)
And useful too.
(defun list_Rtrim (lst posit / )
  (setq lst (reverse lst))
  (reverse lst )
(defun list_Ltrim (lst posit / )
(defun list_trim (lst left right / )
  (list_Ltrim (list_Rtrim lst right) left)
(setq lst (list 0 1 2 3 4 5 6 7 8 9))
_$ (list_ltrim lst 4)
(4 5 6 7 8 9)
_$ (list_rtrim lst 4)
(0 1 2 3 4 5)
_$ (list_trim lst 2 3)
(2 3 4 5 6)
SMadsen
« Reply #6 on: June 29, 2004, 10:05:30 AM »
Heh
.. and the recursive version?
« Reply #7 on: June 29, 2004, 10:18:48 AM »
You know that makes my head hurt. :oops:
« Reply #8 on: June 29, 2004, 10:27:39 AM »
Something like this?
  (if (> posit 1)
    (list_Ltrim (cdr lst) (1- posit))
    (cdr lst)
SMadsen
« Reply #9 on: June 29, 2004, 10:44:55 AM »
Almost. What happens with (list_Ltrim alist 0)?
Or even (list_Ltrim alist -1)? I know that shouldn't be an issue but at least it shouldn't return (cdr alist)
I'd do it something like this:
(defun list_Ltrim (lst posit)
  (cond ((null lst) nil)
        ((> posit 0) (list_Ltrim (cdr lst) (1- posit)))
        (lst)
« Reply #10 on: June 29, 2004, 11:53:06 AM »
Ah yes, the old fox does it again.
I like it, just wish i thought of it. :)
« Reply #11 on: June 29, 2004, 12:05:24 PM »
*Psst* Look over here.
« Reply #12 on: June 29, 2004, 05:56:55 PM »
I think what's been posted, particularly:
        (lst)
are very good solutions, and generally follow the approach I'd take.
But solely for fun, obfuscation and a demonstration of "thinking outside the box" consider why this works (code distilled to re-useable functions):
(defun MakeKeys ( lst / key )
    (setq key -1)
    (mapcar '(lambda (item) (setq key (1+ key))) lst)
(defun IndexList ( lst )
    (mapcar 'cons
        (MakeKeys lst)
        lst
(defun LeftTrimList ( lst n / index )
    (if (< n 1) lst
        (mapcar 'cdr
            (member
                (assoc n (setq index (IndexList lst)))
                index
(setq lst '(A B C D E F G H I))
(LeftTrimList lst 5)  =>  (F G H I)
(LeftTrimList lst -1)  =>  (A B C D E F G H I)
(LeftTrimList lst 99)  =>  nil
Cheers. :)
SMadsen
« Reply #13 on: June 29, 2004, 06:08:10 PM »
Interesting approach, Michael. Quite a detour but instructive
So, a righttrim function would be
(defun RightTrimList (lst n / index)
  (if (< n 1) lst
    (reverse (mapcar 'cdr (member
                (assoc n (setq index (IndexList (reverse lst))))
                index))
Right?
« Reply #14 on: June 29, 2004, 06:11:38 PM »
Quote from: SMadsen
Thank you Stig, just a knurd havin' fun. :)
<Didn't test your variant but it looks just about right ro me.>
