Author Topic: Overloading types.  (Read 9910 times)
Bryco
Re: Overloading types.
« Reply #15 on: May 26, 2007, 06:19:11 PM »
Great stuff.
Thanks Tony and Bobby (on my favourites).
It seemed like a good idea at the time but I see the danger now.
I'll try catch up on this this weekend.
TonyT
« Reply #16 on: May 26, 2007, 07:31:06 PM »
Code snippits are great for inserting simple frequently used constructs,
like try/finally try/catch and so on. But, I don't know if I would use it
to replicate more complex, commonly used constructs rather than
abstracting that into a reusable form, which eliminates the need for
replication (replication of code is something I try to avoid as much as
possible).
As an example, I found that writing very simple editing commands in
.NET was extremely tedious compared to LISP, where it can be done
in typically less than half a dozen lines of code. In .NET, there was
much more code needed, to build simple commands that had no UI
and used the command line (e.g., like the 'ERASE' command).
To make it easier for me to quickly build those kind of commands in
.NET (where the pattern is to prompt for a selection set of objects,
possibly filtered, and then perform some action on each selected
object), I wrote a class that I can use to easily implement those kind
of commands, which factors out 95% of the 'grunt work' needed and
reduces the actual amount of code required to the absolute minimum.
The code in the class is consumed/reused by deriving new classes
from it, typically one for each editing command to be built. Below
are a few examples of how the resuable code in the class is consumed.
Note that most of the grunt work typically required by commands
that prompt for and then operate on a user selection, is delegated
to the base classes, e.g., things like document locking; transaction
management; object selection with filtering; iterating through the
selection; and even opening the objects.
The derived class merely needs to override a virtual method (called
ProcessEntity), that is called once for each each selected object,
that's passed as the parameter and is already open, and there it
can do what it needs to the object and bada bing, bada boom... done.
Of course, there's some performance overhead, but my experience
shows it to be neglegible, and certainly worth the productivtity gain.
namespace CaddZone.AutoCAD.EditorServices
   // A class that implements a command to reset the color
   // of selected block references to BYLAYER:
   public class BlockRefPropertyReset : SelectionEditor<BlockReference>
      protected override void ProcessEntity(BlockReference blockref)
          blockref.ColorIndex = 256;
          return EditorStatus.Continue;
      [CommandMethod("BLOCKCOLORTOBYLAYER", CommandFlags.UsePickSet)]
      public override void CommandHandler()
         Execute();
   /// CIRCLEOFFSET command:
   /// This specialization of SelectionEditor implements
   /// an editor that prompts you to select one or more
   /// circles, and enter a distance. It then offsets each
   /// selected circle's radius by the specified distance.
   /// The larger thing which the trained eye will notice
   /// about this, is that we have successfuly factored
   /// out 95% of the 'grunt work' that must typically
   /// be done in order to build relatively simple custom
   /// AutoCAD commands, using the .NET API.
   public class CircleOffsetEditor : SelectionEditor<Circle>
      // Called after objects are selected, to
      // obtain additional input:
      protected override PromptStatus EndEditorInput( Editor ed )
         PromptDistanceOptions ops = new PromptDistanceOptions( "" );
         ops.Message = "\nCircle radius offset: ";
         ops.AllowZero = false;
         ops.DefaultValue = offset;
         PromptDoubleResult res = ed.GetDistance( ops );
         if( res.Status == PromptStatus.OK )
            offset = res.Value;    // store the value for use in ProcessObject()
         return res.Status;
      /// <summary>
      ///  Override this to gain access to the PromptSelectionOptions
      ///  that's used to get the selection of objects. Here we just
      ///  set the prompts to "Select/remove circles: "
      /// </summary>
      protected override void BeginSelect( PromptSelectionOptions options )
         base.BeginSelect( options );
         options.MessageForAdding = "Select circles: ";
         options.MessageForRemoval = "Remove circles: ";
      /// <summary>
      /// This override is called once for each selected
      /// object, which is passed in as the parameter.
      /// The passed in object is already open for Write,
      /// and cast to the Type of the generic parmeter
      /// argument to this class (a Circle in this case).
      /// This is where each object is Modified.
      /// </summary>
      protected override EditorStatus ProcessEntity( Circle circle )
         if( circle.Radius + offset > 0.0 )
            circle.Radius += offset;
         return EditorStatus.Continue;  // continue processing objects
      // user-supplied offset distance:
      private double offset = 1.0;
      // Implement a command for this editor
      [CommandMethod("CIRCLEOFFSET", CommandFlags.UsePickSet)]
         Execute();
   // A class that implements the 'LENGTH' command, which
   // measures the length of selected curves:
   public class CurveLengthReporter : SelectionViewer<Curve>
      protected override void Initialize()
         totalLength = 0.0;
         counted = 0;
         base.Initialize();
      protected override EditorStatus ProcessEntity( Curve curve )
         try           // Ignore eNotApplicable returned by rays/xlines
            totalLength += curve.GetDistanceAtParameter( curve.EndParam );
            ++counted;
         catch (Autodesk.AutoCAD.Runtime.Exception ex)
             if( ex.ErrorStatus != ErrorStatus.NotApplicable )
                throw ex;
      protected override string GetReportMessage()
         if( counted > 0 )
            return string.Format(
               "Total length of {0} curves: {1}, average length: {2}",
                     counted, totalLength, totalLength / counted );
         else
            return "No curves were processed";
      [CommandMethod( "LENGTH", CommandFlags.UsePickSet )]
          Execute();
      private Distance totalLength = 0.0;
      private int counted = 0;
   /// The SCALEWIDTH command
   /// <summary>
   /// The SCALEWIDTH command applies a scale factor to the
   /// constant widths of a selection of polyLines.
   /// Custom filtering:
   /// This class also utilizes custom selection filtering, where
   /// an overridden method of the base class examines each
   /// object selected by the user, and acccepts or rejects it.
   /// Custom filtering is enabled by overriding the FilterObject()
   /// method. At runtime the SelectionEditor class will detect if
   /// this method has been overridden in a derived class, and if
   /// so, it will invoke the method to allow it to filter each object
   /// selected by the user.
   public class PolylineWidthScaler : SelectionEditor<Polyline>
      // Get the scale factor to apply to each Polyline's width:
      protected override PromptStatus EndEditorInput( Editor editor )
         PromptDoubleOptions ops = new PromptDoubleOptions( "\nWidth scale factor: " );
         ops.AllowNegative = false;
         ops.DefaultValue = scaleFactor;
         PromptDoubleResult res = editor.GetDouble( ops );
         if( res.Status != PromptStatus.OK )
            return res.Status;
         if( Math.Abs( res.Value - 1.0 ) < 1.0e-6 )
            Prompt( "\nScale factor cannot be 1.0," );
            return PromptStatus.Other;
         scaleFactor = res.Value;
         return res.Status;
      // Filter out polyLines whose constant width is nominally 0
      protected override bool FilterEntity( Polyline polyline )
         return polyline.ConstantWidth > 1.0e-6;
      // Operate on each Polyline
      protected override EditorStatus ProcessEntity( Polyline polyline )
         polyline.ConstantWidth *= scaleFactor;
      [CommandMethod( "SCALEWIDTH", CommandFlags.UsePickSet )]
         base.CommandHandler();
      private double scaleFactor = 1.0;
   // only to show how rediculously simple it is to build commands
   // with SelectionEditor<>, this example prompts for a selection set
   // of circles, and changes their color to RED, and does it in only 4
   // lines of code:
   public class MakeCirclesRed : SelectionEditor<Circle>
      protected override EditorStatus ProcessEntity(Circle circle)
          circle.ColorIndex = 1;
   // To invoke the command, just use:  new MakeCirclesRed().Execute();
So, while there's nothing wrong with snippets for reducing typing,
I think they can also be misused to replicate larger code constructs
that possibly shouldn't be replicated if that can be avoided through
carefully designed modular, reusable classes.
Glenn, since there is virtually no globals I have a sub that is the full monty way of adding an ent. Otherwise I was finding C# was way more verbose than vba. With as BlockTableRecord btr here and a BlockTableRecord btr there etc.
Well, if I may say so myself, I've found that trying to invent
your own API that offers the 'full monty' way of doing things,
will ultimately create more problems than it solves.
<snip>
I traversed this same path, asked myself the same questions you have asked yourself, and lamented all the extra work involved in using this API.  But in the end, I agree with Tony.
We all know however that we are lazy and typing is not how we want to spend our days.  If you're using Visual Studio as your IDE, I suggest Code Snippets.  You can create snippets that encapsulate a logical action, like adding an entity to a database, although most of mine aren't quite that chunky, and modify the code after it's inserted.
« Last Edit: May 26, 2007, 08:15:36 PM by TonyT »
« Reply #17 on: May 26, 2007, 08:12:42 PM »
possible).
I found my head nodding in agreemant as I read this. I've played a little with snippets .. { you'll find a couple of threads in this forum discussing snippets and XML editors } .. and had grandiose visions of writing large tracts of code with a few keystrokes ; untill I slapped myself up the side of my head and came back to reality. The name 'snippets' is a perfect description of how I use them now.
Thanks for the comment Tony. Just as importantly, thanks for the code example. There is a lot to be learnt from that seemingly simple example.
« Reply #18 on: May 26, 2007, 09:29:37 PM »
Bryco,
To come back to the Overloading ..
Here's a couple of examples of Method Overloading you may find interesting.
        // class Autodesk.AutoCAD.Runtime.Converter
        // enum Autodesk.AutoCAD.Runtime.DistanceUnitFormat
        // struct Autodesk.AutoCAD.Geometry.Point3d
        public static string PtToStr(Point2d pt)
            return PtToStr(pt, DistanceUnitFormat.Current, -1);
        public static string PtToStr(Point3d pt)
        public static string PtToStr(Point2d pt, DistanceUnitFormat unitType, int prec)
            return string.Format("({0}, {1})",
                Converter.DistanceToString(pt.X, unitType, prec),
                Converter.DistanceToString(pt.Y, unitType, prec));
        /// <summary>
        /// </summary>
        /// <param name="pt"></param>
        /// <param name="unitType"></param>
        /// <param name="prec"></param>
        /// <returns></returns>
        public static string PtToStr(Point3d pt, DistanceUnitFormat unitType, int prec)
            return string.Format("({0}, {1}, {2})",
                Converter.DistanceToString(pt.Y, unitType, prec),
                Converter.DistanceToString(pt.Z, unitType, prec));
        public static void Rotate(Entity ent, Point3d basePoint, double rotationAngle)
            Rotate(ent.ObjectId, basePoint, rotationAngle);
        /// <summary>
        /// </summary>
        /// <param name="id"></param>
        /// <param name="basePoint"></param>
        /// <param name="rotationAngleInRadians"></param>
        public static void Rotate(ObjectId id, Point3d basePoint, double rotationAngleInRadians)
            // note: System.Math.PI is const 3.1415926535897931
            // struct Autodesk.AutoCAD.Geometry.Matrix3d
            // struct Autodesk.AutoCAD.Geometry.Vector3d
            // Matrix3d transform = Matrix3d.Rotation(((rotationAngleInDegrees * Math.PI) / 180,
                rotationAngleInRadians,
                new Vector3d(0, 0, 1),
                basePoint);
            using (Transaction tr =
                AcadApp.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())
                ((Entity)tr.GetObject(id, OpenMode.ForWrite, true)).TransformBy(transform);
                tr.Commit();
        public static void Move(Entity ent, Point3d fromPoint, Point3d toPoint)
            Move(ent.ObjectId, fromPoint, toPoint);
        /// <summary>
        /// </summary>
        /// <param name="fromPoint"></param>
        /// <param name="toPoint"></param>
        public static void Move(ObjectId id, Point3d fromPoint, Point3d toPoint)
            Matrix3d transform = Matrix3d.Displacement(fromPoint.GetVectorTo(toPoint));
                tr.Commit();
         public static bool SelectPoint01(string Message, out Point3d pt )
            return SelectPoint01(Message,  out pt, new Point3d(), false );
        /// <summary>
        /// </summary>
        /// <param name="Message"></param>
        /// <param name="defVal"></param>
        /// <param name="useDefVal"></param>
        public static bool SelectPoint01(string Message,  out Point3d pt,Point3d defVal, bool useDefVal  )
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            bool result = false;
            PromptPointOptions ppo = new PromptPointOptions(Message);
            if (useDefVal)
                ppo.BasePoint = defVal;
                ppo.UseDashedLine = true;
                ppo.UseBasePoint = true;
                ppo.AllowNone = true;
            PromptPointResult ppr = ed.GetPoint(ppo);
            switch (ppr.Status)
                case PromptStatus.Cancel:
                    ed.WriteMessage("\nUser canceled.");
                    break ;
                case PromptStatus.Error:
                    ed.WriteMessage("\nUser input error.");
                    break;
                case PromptStatus.OK:
                    result = true;
                    break;
            pt = ppr.Value;
            return result;
... and a quick tester
        [CommandMethod("TestPoints")]
        public static void TestPoints()
            Point3d pt = new Point3d(0, 0, 0);
            bool result = KdubUtils.Utility.SelectPoint01("Select a Point ", out pt);
            if (result)
                MessageBox.Show("TestPoint_01 Result :" + KdubUtils.Utility.PtToStr(pt));
            bool result2 = KdubUtils.Utility.SelectPoint01("Select a Point ", out pt, pt, true);
            if (result2)
                MessageBox.Show("TestPoint_02 Result :" + KdubUtils.Utility.PtToStr(pt));
« Last Edit: May 27, 2007, 02:16:03 AM by Kerry Brown »
« Reply #19 on: May 27, 2007, 02:07:00 AM »
.. and a tester for the Move and Rotate Methods
        [CommandMethod("TestMove")]
        public static void TestMove()
            PromptEntityResult peResult = ed.GetEntity("\nSelect an entity to Move: ");
            Point3d pt1 = ed.GetPoint("\nMove From: ").Value;
            Point3d pt2 = ed.GetPoint("\nMove To: ").Value;
            KdubUtils.Utility.Move(peResult.ObjectId, pt1, pt2);
        [CommandMethod("TestRotate")]
        public static void TestRotate()
            PromptEntityResult peResult = ed.GetEntity("\nSelect an entity to Rotate: ");
            Point3d pt1 = ed.GetPoint("\nRotate From: ").Value;
            PromptAngleOptions paOptions = new PromptAngleOptions("\nEnter or Select an Angle: ");
            paOptions.AllowZero = true;
            paOptions.AllowNone = false;
            paOptions.DefaultValue = Math.PI * 45.0 / 180; // in Radians
            paOptions.UseDefaultValue = true;
            paOptions.BasePoint = pt1;
            paOptions.UseBasePoint = true;
            double ang1 = ed.GetAngle(paOptions).Value;
            // MessageBox.Show("Angle is :" + Converter.AngleToString(ang1));
            // ang1 is expressed in radians
            KdubUtils.Utility.Rotate(peResult.ObjectId, pt1, ang1);
TonyT
« Reply #20 on: May 27, 2007, 03:55:06 AM »
In addition, here's something that might be useful for
those who want to perform conversions of things like
points, angles, and distances in a way that conforms
to the .NET component model and therefore supports
controls like PropertyGrid and DataGridView:
  http://www.caddzone.com/ComponentModel.cs
Bryco,
« Last Edit: May 28, 2007, 12:13:47 AM by TonyT »
TonyT
« Reply #21 on: May 27, 2007, 09:31:14 PM »
                basePoint);
                tr.Commit();
Well, without assuming anything about the application, I would
have done that a bit differently.
First I would have designed the code to implicitly operate on
an array of ObjectId[] rather than just one (and overloaded
for the case where only one object is being operated on).
Second, I prefer to avoid using the active document when I
can get the database the objects are in from the Objects
themselves, allowing the code to used in any database.
     // for one
         Rotate( new ObjectId[] { id }, basePoint, rotationAngleInRadians);
     // for many
     public static void Rotate(ObjectId[] ids, Point3d basePoint, double rotationAngleInRadians)
                basePoint);
          Database db = ids[0].Database;
          using(Transaction tr = db.TransactionManager.StartTransaction())
              foreach( ObjectId id in ids )
                   Entity ent = tr.GetObject(id, OpenMode.ForWrite) as Entity;
                   if( ent != null )
                        ent.TransformBy(transform);
              tr.Commit();
Bryco
« Reply #22 on: May 28, 2007, 11:20:16 AM »
I've got the feeling I'll be coming back to this thread quite a few times for pointers, it's a beauty.
So far I've found the distance function to be a perfect example of overloading. Now I can feed it 1 2dpoint,2 3dpoints etc etc.
It does seem like there's a lot of preliminary work to do to make coding in cad more efficient.
That's one of the reasons I tried to start with a full monty approach, get it to work then I wont be typing it wrong the next time.
using(Transaction tr = db.TransactionManager.StartTransaction())- this line is one I'll look at as a snippet.
One of the advantages I see in this is being able to post code without searching for 30 included functions.
The commands look they are going to take a little time. E.g. Matrix3d transform = Matrix3d.Rotation, this might take the odd side step to figure out. (The hook). In reality I need to finish reading my C+ book first, but it sure is nice to mix it up a bit.
