Author Topic: Not so much a standard...  (Read 21719 times)
hudster
« on: June 29, 2004, 03:56:37 AM »
....more of a common sense thing.
SAVE YOUR WORK REGULARLY.
I have a guy in my office who works on a really old computer, I think we got it from moses.  His computer regularly crashes and he never saves his work, he will go hours without saving, so when it crashes he loses hours worth of work, unless i can salvage his autosave.
I tend to save every 2 minutes as I work through a drawing, less hastle if anything goes wrong.
pmvliet
« Reply #1 on: June 29, 2004, 08:27:30 AM »
Do you set his savetime to something shorter then the default?
we set our entire office to 10 minutes. It helps some but we still loose stuff from time to time.
We also move the backup's to a local directory so that each person gets a BAK for their file... That helps at times as well, but only if people save. I have lots of Microstation users and since Microstation will continually save, people don't like saving every 3rd command or so in AutoCad... hard habits are hard to break.
CADaver
« Reply #2 on: June 29, 2004, 08:35:35 AM »
I have added QSAVE to about a dozen of our canned routines, so it's real hard to go more than 10-15 minutes without the system doing it's own Qsave.  I have made everyone aware that the program is saving itself, so don't expect to quit without saving and return to and old version.  OPEN THE BLOODY THING READ-ONLY.
Remember when you could set acad to open everything read-only?
M-dub
« Reply #3 on: June 29, 2004, 08:39:09 AM »
That's almost like Microstation...That can be dangerous if you don't know it saves the drawing after every single command.
Not a bad idea if everyone knows what's going on, but I think the Vent proves that not everyone does...;)
CADaver
« Reply #4 on: June 29, 2004, 08:49:52 AM »
Quote from: M-dub
Yes it can, and it has bitten a few in the ... ummm... tailgate.
Quote from: M-dub
After the tailgate bandaids were applied, I think most everyone here is aware, those that aren't, aren't aware they're breathing.
« Reply #5 on: June 29, 2004, 06:20:13 PM »
Autosave set to 10 minutes,  create backup with each save and that is all you realistically need to have, anything else is a waste of time and unnecessary
VerticalMojo
« Reply #6 on: June 30, 2004, 09:36:21 AM »
I set mine to every three min......
Yes I know..... but I can do a lot of work in 10 min.
« Reply #7 on: June 30, 2004, 10:33:24 AM »
Me too  :D .
« Reply #8 on: June 30, 2004, 10:38:41 AM »
Due to the size of our models and the glut of data that travels between models and associated databases, saves can take upwards of 20 minutes in ambitious models. As such, the last thing we want is a autosave to kick in. Our operators know: save it or lose it. But I fully admit, ours is a different kind of camp, and not necessarilly representative of "the norm" ... :)
CADaver
« Reply #9 on: June 30, 2004, 10:57:03 AM »
Quote from: MP
Ours can take some time as well (not nearly 20 min, however), and that's the primary reason I don't shorten the autosaves to less than 15 minutes
t-bear
« Reply #10 on: June 30, 2004, 11:00:55 AM »
Like CADaver & MP, our 3D models can take a while....15 minutes.
« Reply #11 on: June 30, 2004, 11:06:37 AM »
We deal with drawings typically less than 2 megs, some are as small as 200k (in 2000) they are even smaller in 2004
CADaver
« Reply #12 on: June 30, 2004, 01:05:11 PM »
Quote from: Keith
Geez, the good ol' days....
The only real disadvantage to 3D modeling is file size, we average 20-40Mbs.
t-bear
« Reply #13 on: June 30, 2004, 01:22:35 PM »
Yah...baybe they'll come out with a "3d Lite" option.....LOL
A lot of our 3D objects are blocks (multiple insert) which helps *a little bit*, but not much......
Still, I couldn't do the design dwgs I do in a 2D environment.  Piping going every which-a-way, valves and instrumentation hung all over the place....I'd NEVER find the "crashes" in 2D!
« Reply #14 on: June 30, 2004, 01:53:59 PM »
Well I do some 3d stuff, but mostly for visualization, not for construction purposes, it is rarely called for in the construction industry.
