Author Topic: dimension prefix delete  (Read 5307 times)
Eloquintet
« on: October 30, 2003, 02:45:45 PM »
hey all i have a drawing who's dimstyle units are set to fractional with an inch suffix added so it reads 60" rather than 5'-0". the problem is when i do angular dimensions i get 60 degrees". can someone help me with a lisp that will delete a dimension's suffix by clicking it. or maybe suggest something else. thanks
dan
Dan
AutoCAD Architecture 2015
daron
« Reply #1 on: October 30, 2003, 03:00:26 PM »
Would two different dimstyles be the answer? It's all I could come up with. ...Or changing it manually for each dimension.
« Reply #2 on: October 30, 2003, 03:06:11 PM »
this is kinda quick-n-dirty but..........
(defun MST-entsel-obj (msg / ent obj)
  (vl-catch-all-apply
    (function
      (lambda ()
        (and
          (equal (type msg) 'STR)
          (setq ent (entsel msg))
          (setq obj (vlax-ename->vla-object (car ent)))
          ); and
  obj
  ); defun
(defun MST-release (obj /)
    (= (type obj) 'VLA-OBJECT)
    (if (not (vlax-object-released-p obj))
      (vlax-release-object obj)
(defun c:remove-suffix (/ dim-al)
  (setq dim-al (MST-entsel-obj "\nSelect A Dimension Line..."))
  (if dim-al
      (vlax-put-property dim-al 'TextSuffix "")
      (MST-release dim-al)
SMadsen
« Reply #3 on: October 30, 2003, 03:22:23 PM »
One could also create an angular child of the dimstyle .. but somehow it seems that pre-/suffix's are locked for angular children?? Never knew that.
It can be changed afterwards by modifying code 3 in the table entry, though.
Eloquintet
« Reply #4 on: October 30, 2003, 03:46:50 PM »
i know i could create another dimstyle and change it maually but i don't want to do either just want to be able to click on the angular dim and have the inch disappear. haven't tried yours yet mark but i'll let you know how it goes. thanks everyone. ps-is it just me or am i the only one posting anything here. thanks guys
dan
Dan
Eloquintet
« Reply #5 on: October 30, 2003, 04:00:12 PM »
mark works great i love you man :lol:
dan
Dan
daron
« Reply #6 on: October 30, 2003, 04:39:15 PM »
Quote from: eloquintet
dan
We're waiting for you to invite all your friends.
Dent Cermak
  • Clinton, Mississippi
« Reply #7 on: October 30, 2003, 04:55:19 PM »
Both of them.   :oops:
If you are looking to me for answers, you really have problems. Carlson Survey 2016 w/ Embedded AutoCad
« Reply #8 on: October 30, 2003, 05:05:57 PM »
dan
ah shucks ...........
you're welcome Dan.
