Author Topic: Changing Dimstyles with Lisp  (Read 2865 times)
whdjr
« on: May 18, 2007, 10:53:07 AM »
I need to change some colors in some dimensions in a template dwg.  The code below sets everything correctly it just doesn't apply it to the dwg.  Can someone help please?
(defun test (/ dim)
 (defun sub (lst code int)
  (setq dim (subst (cons code int) (assoc code lst) lst))
 (while
  (if (not dim)
   (setq dim (tblnext "DIMSTYLE" T))
   (setq dim (tblnext "DIMSTYLE"))
  (if dim
   (mapcar '(lambda (x y)
     (sub dim x y)
   '(176 177 178)
   '(1 1 4)
  (entmod dim)
Guest
Re: Changing Dimstyles with Lisp
« Reply #1 on: May 18, 2007, 10:59:48 AM »
Not having worked with changing dimstyles via LSP, I'm just thinking out loud here but, do you need to ENTUPD the dim??
whdjr
« Reply #2 on: May 18, 2007, 11:07:59 AM »
Entupd updates an ename.  'TBLNEXT' doesn't give an ename and I think that is the issue.  I used entmod because it is supposed to work on an entity list but technically I don't have a complete entity list from TBLNEXT.
whdjr
« Reply #3 on: May 18, 2007, 11:13:34 AM »
I tried changing (entmod dim) to
(entupd (tblobjname "DIMSTYLE" (cdr (assoc 2 dim) )))
but it didn't help any.
jbuzbee
« Reply #4 on: May 18, 2007, 11:47:30 AM »
Dimension "entities" are special blocks, that when created, use properties stored in a dimstyle - which is a table object.  If you change the dimstyle pragmatically, chances are you'd need to iterate through the database and entupd each dimension "entity" referencing that style?
James Buzbee
Windows 8
« Reply #5 on: May 18, 2007, 06:37:58 PM »
You've changed the definition Table, you now need to change the individual dims, so ..
Command: dim
Dim: update
Select objects: ....................
whdjr
« Reply #6 on: May 21, 2007, 03:34:31 PM »
Command: dim
Dim: update
This was a template dwg that didn't have any actual dimensions just the styles, and it never actually changed the styles.
I did it all manually this morning.
Thanks,
