Author Topic: Array of arrays vs Class  (Read 12121 times)
« on: May 16, 2007, 05:42:35 PM »
In my plot routine I use an array of arrays to store all the options for plotting.  I was thinking that I could make a class specific for this instead.  I could set up all the properties I would need, and if I need to add some later, I wouldn't have to rework the code to see the number of items in the array divided by the items per nested array, which I would have to do now.
Is this doable?  Is it a good idea?  Comments/opinions wanted and welcomed.
Thanks in advance.
Re: Array of arrays vs Class
« Reply #1 on: May 16, 2007, 06:16:45 PM »
If your array holds arrays of the same data (say an array of strings for options) then yes, wrapping this into a class (or struct even) is a good idea.
This way you can use your class like a 'record' in a db, just create a new one each plot, set it up and add it to the array.
This would make parsing the internal arrays much neater as well.
Is that what you're proposing?
- John Carmack
- J.R.R. Tolkien
« Reply #2 on: May 16, 2007, 06:20:55 PM »
Yep, that is my line of thinking.  The class/struct will have properties (string, bool, double, int and Acad specific types like StdScaleType and PlotRotation) that will correspond with what the plot engine wants.  I was just reading up on class right now.  I will have a look at struct when I get a chance.  Thanks Mick.
Edit:  This is how I was thinking of setting up my class.
public class MyPlotParams {
private string DeviceName;
private string Paper;
private string ctbName;
private bool ScLw;
private double Rot;
private int Cnt;
private Autodesk.AutoCAD.DatabaseServices.StdScaleType ScTyp;
private Autodesk.AutoCAD.DatabaseServices.PlotRotation PltRot;
« Last Edit: May 16, 2007, 06:27:43 PM by T.Willey »
« Reply #3 on: May 16, 2007, 06:42:30 PM »
No prob's, I'm not to sure how structures work in .net but if you could just make your variable public it would save a lot of property get/set code, your could just asign the variables to the plot engine like -
plotEngine.Paper = myPlotParams.Paper;
I think properties are the prefered way to do it though.
- John Carmack
- J.R.R. Tolkien
« Reply #4 on: May 16, 2007, 06:46:16 PM »
or a better example from the array would be -
foreach(plotparam in plotparams)//loop through the plotparams array
    plotEngine.Paper = plotparams[ i ].plotparam.Paper;
    plotEngine.DeviceName = plotparams[ i ].plotparam.DeviceName;
    // etc etc
- John Carmack
- J.R.R. Tolkien
LE
« Reply #5 on: May 16, 2007, 06:51:16 PM »
Tim;
Have a look into this article:
http://www.c-sharpcorner.com/UploadFile/rajeshvs/StructuresInCS11112005234341PM/StructuresInCS.aspx
I have my own examples, but wait for the masters... :)
« Reply #6 on: May 16, 2007, 06:58:56 PM »
Since I call my plotting portion like
public void MyPlottingPart (
                            string DeviceName,
                            string Paper,
                            string ctbName,
                            StdScaleType ScaleType,
                            bool IsModel,
                            bool ScLws,
                            PlotRotation PltRot,
                            bool LastPlot
I would pass the properties from the class to it like Mick shows in the first response.
where I would make a new class object per file to plot.  I have constructed the constructor to MyPlotParms like
public MyPlotParams(){}
public MyPlotParams(string DwgPath, string DeviceName, string Paper, string ctbName, bool ScLw, double Rot, int Cnt, Autodesk.AutoCAD.DatabaseServices.StdScaleType ScTyp, Autodesk.AutoCAD.DatabaseServices.PlotRotation PltRot) {
this.DwgPath = DwgPath;
this.DeviceName = DeviceName;
this.Paper = Paper;
this.ctbName = ctbName;
this.ScLw = ScLw;
this.Rot = Rot;
this.Cnt = Cnt;
this.ScTyp = ScTyp;
this.PltRot = PltRot;
This is the way I'm heading right now.  If it seems wrong please let me know.
Tim;
Luis thanks for the link.  :-)
LE
« Reply #7 on: May 16, 2007, 07:06:52 PM »
Tim;
I know that later, the ones that really know, will guide better, but on the mean time, let me post a little simple class I wrote for one of my routines, it might help, I do not know... :)
    public partial class Door : DoorsAndWindowsForm
        // Declarations
        private ObjectId m_blockid       = new ObjectId();
        private const Int32 m_vertices   = 4;
        private String m_doorName        = "";
        private Double m_doorThick       = 1.75; //1-3/4"
        private Double m_doorWidth       = 0.0;
        private Double m_wallThick       = 0.0;
        private Double m_dirRight        = 0.0;
        private Double m_dirUp           = 0.0;
        private Double m_dirLeft         = 0.0;
        private Double m_swingStartAngle = 0.0;
        private Double m_swingEndAngle   = 0.0;
        public enum Names
            dr90,
            dr45,
            dr30,
            dr15,
            dr180,
            drPair90,
            drPair90egress,
            drSliding,
            drPocket,
            drFolding,
            Rolling
        // Default Constructor
        public Door()
        // Alternate constructor
        public Door(Double doorWidth, Double wallThick, int drValue)
            drWidth = doorWidth;
            getDoorName(drValue);
                Entity[] ent = new Entity[entities.Count];
                entities.CopyTo(ent, 0);
                ObjectId blockid = makeBlock("*U", ent);
                DoorId = blockid;
                // remove originals
                en1.Erase(true);
                en2.Erase(true);
                en3.Erase(true);
                en4.Erase(true);
                tr.Commit();
        // Properties
        public Double SwingStartAngle
            get
                return m_swingStartAngle;
            set
                m_swingStartAngle = value;
        public Double SwingEndAngle
            get
                return m_swingEndAngle;
            set
                m_swingEndAngle = value;
        public ObjectId DoorId
            get
                return m_blockid;
            set
                m_blockid = value;
        public Double DirRight
            get
                return m_dirRight;
            set
                m_dirRight = value;
        public Double DirUp
            get
                return m_dirUp;
            set
                m_dirUp = value;
        public Double DirLeft
            get
                return m_dirLeft;
            set
                m_dirLeft = value;
        public Double Thick
            get
                return m_doorThick;
            set
                m_doorThick = value;
        public Double drWidth
            get
                return m_doorWidth;
            set
                 m_doorWidth = value;
        public Double WallThick
            get
                return m_wallThick;
            set
                m_wallThick = value;
        public String drName
            get
                return m_doorName;
            set
                m_doorName = value;
        public String getDoorName(int valor)
            string block_dwg = "90 degrees swing"; //default
            switch (valor)
                case 0:
                    SwingStartAngle = 0.0;
                    SwingEndAngle = c90Degrees;
                    DirRight = 0.0;
                    DirUp = c90Degrees;
                    DirLeft = Math.PI;
                    drName = "90 degrees swing";
                    break;
                case 1:
                    SwingEndAngle = 0.785398;
                    DirRight = c315Degrees;
                    DirUp = c45Degrees;
                    DirLeft = c135Degrees;
                    drName = "45 degrees swing";
                    block_dwg = "45 degrees swing";
                    break;
                case 2:
                    SwingEndAngle = 0.523599;
                    DirRight = 5.23599;
                    DirUp = 0.523599;
                    DirLeft = 2.0944;
                    drName = "30 degrees swing";
                    block_dwg = "30 degrees swing";
                    break;
                case 3:
                    SwingEndAngle = 0.261799;
                    DirRight = 4.97419;
                    DirUp = 0.2618;
                    DirLeft = 1.8326;
                    drName = "15 degrees swing";
                    block_dwg = "15 degrees swing";
                    break;
                case 4:
                    SwingEndAngle = Math.PI;
                    DirRight = c90Degrees;
                    DirUp = Math.PI;
                    DirLeft = c270Degrees;
                    drName = "180 degrees swing";
                    block_dwg = "180 degrees swing";
                    break;
                case 5: // ignore this door - remove from here
                    block_dwg = "Pair 90 degrees swing";
                    break;
                case 6: // ignore this door - remove from here
                    block_dwg = "Pair 90 degrees double egress";
                    break;
                case 7:
                    block_dwg = "Sliding";
                    break;
                case 8:
                    block_dwg = "Pocket";
                    break;
                case 9:
                    block_dwg = "Folding";
                    break;
                case 10:
                    block_dwg = "Rolling";
                    break;
            return block_dwg;
    }//end of Door class
Then, when I need to change/update one of the doors I just read all the data in the dictionaries and call it like:
Door door = new Door(dw, wwidth, doorNamesIndex);
Point2d pgeo = new Point2d(x, y);
// save values to door!!!
door.drName = dname;
door.WallThick = wwidth;
 door.drWidth = dw;
Super Mickey Mouse.... I know..
« Last Edit: May 17, 2007, 10:10:39 AM by LE »
« Reply #8 on: May 16, 2007, 07:13:56 PM »
That link has all you need to know, if you don't need member methods/functions there's no need to create a class. You create a struct the same as a class but as the member var's are public you just assign straight to them as you would any ather variable except you use the struct's instance name in front like -
MyStruct s = new MyStruct();
s.var1 = somevar;
s.var2 = another var
etc....
- John Carmack
- J.R.R. Tolkien
« Reply #9 on: May 16, 2007, 07:23:19 PM »
Tim;
<snip>
Thanks Luis.  This will take me some time to digest.
s.var1 = somevar;
etc....
This what I was thinking out of reading that article.  A struct sounds like it may be better suited for what I'm doing right now.
Thanks you two.  I'm off to play now, and tomorrow since today is almost done, and I have to take my car to the shop right after work.
« Reply #10 on: May 16, 2007, 11:00:42 PM »
Thanks in advance.
Hi Tim,
The Framework Design Guidelines say that the maximum size of a struct should be around 16 bytes,
they should be used for making value types. In your case you should consider using a class along with something
from System.Collections.Generic.. For example List<T>
Dan
« Reply #11 on: May 16, 2007, 11:20:18 PM »
Thanks in advance.
Hi Tim,
Dan
Dan,
  Does .Net 1.1 support 'Generic's?  I didn't think it did.  I will do some research on this tomorrow.  Thanks for the idea.
« Reply #12 on: May 16, 2007, 11:26:50 PM »
Nope, May I ask why your not using a newer framework?
« Reply #13 on: May 16, 2007, 11:27:58 PM »
Is that for real?! I noticed that struct's derive from value type (therefore are by inheritance) and I also read that value types are 'recommended' to be 16bytes, does that apply for subclasses like struct's, it just doesn't sound right.
It sucks if it is right though, a struct is a perfect solution for something that just needs to hold data in bundles like in Tim's situation.
- John Carmack
- J.R.R. Tolkien
« Reply #14 on: May 17, 2007, 12:28:37 AM »
Here is one link http://msdn2.microsoft.com/en-us/library/y23b5415(VS.71).aspx
From what I gather, it’s just a matter of efficiency. I read a great article (I need to find the link) which explained the impact of placing large objects on the managed stack. Interesting stuff.
