Author Topic: Search of Windows type Sort function  (Read 30610 times)
terrycadd
« on: May 16, 2007, 04:18:40 PM »
I’ve searched the forum for a sort function that sorts a list of files or part numbers the way windows sorts filenames. I didn’t have any luck, but I did find some very useful utilities, such as “getdir” by ronjonp.
The vl-directory-files functions sorts the files the same way that acad_strlsort would sort these filenames in a list.  Example:
(setq FileList@ (vl-directory-files Foldername$ "*.dwg" 1))
(setq SortList@ (acad_strlsort FileList@))
Both return the following list:
(list “PN375-A10.dwg”
      “PN375-A9.dwg”
      “PN375-D1.dwg”
      “PN375-D10.dwg”
      “PN375-D14.dwg”
      “PN375-D2.dwg”
      “PN375-D22.dwg”
      “PN375-D7r3.dwg”
      “PN375-DB.dwg”
      “PN375-DB10a.dwg”
      “PN375-DB9.dwg”)
The order that I’m wanting is:
(list “PN375-A9.dwg”
      “PN375-A10.dwg”
      “PN375-D1.dwg”
      “PN375-D2.dwg”
      “PN375-D7r3.dwg”
      “PN375-D10.dwg”
      “PN375-D14.dwg”
      “PN375-D22.dwg”
      “PN375-DB9.dwg”
      “PN375-DB10a.dwg”
      “PN375-DB.dwg”)
I can see the unique groups of PN375-A, PN375-D, PN375-DB. The sort is then based on the numbers that follow the unique groups.
If I missed this topic in my search, please point me to the right thread.
Thanks,
Terry
« Last Edit: May 17, 2007, 10:27:49 AM by Terry Cadd »
VVA
Re: Search of Windows type Sort function
« Reply #1 on: May 17, 2007, 08:14:11 AM »
Try It
;;Usage (SortStringWithNumberAsNumber '("A9" "A1" "A10" "B11" "B2" "B05"))
;;Return ("A1" "A9" "A10" "B2" "B05" "B11")
(defun SortStringWithNumberAsNumber (ListOfString)
;;;Function Normalize (add 0 befor number) number in string
;;; Count normalize symbols set in variable count
  (defun NormalizeNumberInString (str / ch i pat ret count buf)
    (setq i     0
          pat   '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9")
          ret   ""
          count 4 ;_Count normalize symbols
    ) ;_ end of setq
    (while (/= (setq ch (substr str (setq i (1+ i)) 1)) "")
      (if (vl-position ch pat)
          (setq buf ch) ;_ end of setq
          (while
            (vl-position (setq ch (substr str (setq i (1+ i)) 1)) pat)
             (setq buf (strcat buf ch))
          ) ;_ end of while
          (while (< (strlen buf) count) (setq buf (strcat "0" buf)))
          (setq ret (strcat ret buf))
        ) ;_ end of progn
      ) ;_ end of if
      (setq ret (strcat ret ch))
    ) ;_ end of while
    ret
  ) ;_ end of defun
  (mapcar '(lambda (x) (nth x ListOfString))
          (vl-sort-i (mapcar 'NormalizeNumberInString ListOfString)
          ) ;_ end of VL-SORT-I
  ) ;_ end of mapcar
) ;_ end of defun
Usage
(setq lst (list "PN375-A10.dwg"
      "PN375-A9.dwg"
      "PN375-A04.dwg"
      "PN375-A555.dwg"
      "PN375-D1.dwg"
      "PN375-D10.dwg"
      "PN375-D14.dwg"
      "PN375-D2.dwg"
      "PN375-D22.dwg"
      "PN375-D7r3.dwg"
      "PN375-DB.dwg"
      "PN375-DB10a.dwg"
      "PN375-DB9.dwg"))
(mapcar '(lambda(x)(terpri)(princ x))
        (SortStringWithNumberAsNumber lst))
Return
PN375-A04.dwg
PN375-A9.dwg
PN375-A10.dwg
PN375-A555.dwg
PN375-D1.dwg
PN375-D2.dwg
PN375-D7r3.dwg
PN375-D10.dwg
PN375-D14.dwg
PN375-D22.dwg
PN375-DB.dwg
PN375-DB9.dwg
PN375-DB10a.dwg
mkweaver
« Reply #2 on: May 17, 2007, 08:45:37 AM »
Very nice!  Saved to my library.
Thanks,
Mike
« Reply #3 on: May 17, 2007, 02:33:17 PM »
Excellent, I like it too.
GDF
« Reply #4 on: May 17, 2007, 02:41:55 PM »
Kool
Like it...
terrycadd
« Reply #5 on: May 18, 2007, 04:28:29 PM »
I just completed win_sort.  It was quite a challenge for a “Newt” with only 52 postings.  I also attached dependant files, number_sort, change_nth and delete_nth.  The win_sort function sorts a list of strings very similar to the way Windows sorts files in folders.  It may be used to display filenames in a dialog list, and may also be used in a plot script function to plot a folder of drawings in the Windows sorted order other than just the acad_strlsort order.  This is my first version, and it is a bit lengthy.  You are welcomed and challenged to find a shorter way to accomplish its’ tasks.
Here are the results of the following functions using the FilesList@ for a test run.
(setq FilesList@ (list "1-C4.dwg" "7-b7.dwg" "11-C4.dwg" "2-b3.dwg" "2-c2.dwg" "22-b2.dwg" "pn374-x9.dwg" "pn374-z9.dwg" "Pn375-A10.dwg" "pN375-A9.dwg" "pn375-D1.dwg" "PN375-D10.dwg" "pN375-D2r3.dwg" "pn375-D22.dwg" "qr86-007.dwg" "pN375-DB.dwg" "pn375-DB10a.dwg" "PN375-DB9.dwg"))
SortStringWithNumberAsNumber  win_sort
          1-C4.dwg                      1-C4.dwg
          2-b3.dwg                      2-b3.dwg
          2-c2.dwg                      2-c2.dwg
          7-b7.dwg                      7-b7.dwg
          11-C4.dwg                    11-C4.dwg
          22-b2.dwg                     22-b2.dwg
          PN375-D10.dwg              pn374-x9.dwg
          PN375-DB9.dwg              pn374-z9.dwg
          Pn375-A10.dwg              pN375-A9.dwg
          pN375-A9.dwg                Pn375-A10.dwg
          pN375-D2r3.dwg             pn375-D1.dwg
          pN375-DB.dwg                pN375-D2r3.dwg
          pn374-x9.dwg                PN375-D10.dwg
          pn374-z9.dwg                pn375-D22.dwg
          pn375-D1.dwg                pN375-DB.dwg
          pn375-D22.dwg              PN375-DB9.dwg
          pn375-DB10a.dwg           pn375-DB10a.dwg
          qr86-007.dwg                 qr86-007.dwg
; win_sort - Windows type of sort function
; Arguments: 1
;   List@ = List of strings or filenames
; Returns: List of strings sorted similar to how Windows sorts files
(defun win_sort (Original@ / AlphaSort@ Cnt# Compare$ First Item List@ Loop
  Next$ Num# NumSort@ NumStrings@ Passed Prefix$ Prefixes@ PrefixList@
  PrefixSort@ Previous$ SortLenghts@ SortList@ Str$)
  (setq Passed t)
  (if (= (type Original@) 'LIST)
    (foreach Item Original@ (if (/= (type Item) 'STR) (setq Passed nil)))
    (setq Passed nil)
  );if
  (if (not Passed)
    (progn (princ "\nUsage: (win_sort <list of strings>)") (exit))
  );if
  (setq Original@ (acad_strlsort Original@))
  (setq AlphaSort@ (mapcar 'strcase Original@))
  (setq Num# 0 Next$ (chr 160));a unique character
  (repeat (length AlphaSort@)
    (setq Previous$ Next$
          Next$ (nth Num# AlphaSort@)
          Prefix$ nil
          Cnt# 1
    );setq
    (if (not (wcmatch (substr Next$ 1 1) "#"))
      (repeat (strlen Next$)
        (setq Str$ (substr Next$ 1 Cnt#)
              Compare$ (strcat Str$ "*")
        );setq
        (if (and (wcmatch Previous$ Compare$)(not (wcmatch (substr Str$ (strlen Str$)) "#")))
          (setq Prefix$ Str$)
        );if
        (setq Cnt# (1+ Cnt#))
      );repeat
    );if
    (if Prefix$
        (setq Compare$ (strcat Prefix$ "#*"))
        (if (and (wcmatch Previous$ Compare$)(wcmatch Next$ Compare$))
          (setq Passed t)
          (setq Passed nil)
        );if
      );progn
    );if
    (if (and Passed Prefix$ (not (member Prefix$ Prefixes@)))
      (setq Prefixes@ (append Prefixes@ (list Prefix$)))
    );if
    (setq Num# (1+ Num#))
  );repeat
  (if Prefixes@
      (if (> (length Prefixes@) 1)
          (setq Num# 1 List@ (cons (nth 0 Prefixes@) (append Prefixes@ (list (last Prefixes@)))))
          (repeat (length Prefixes@)
            (setq Compare$ (strcat (nth Num# List@) "*"))
            (if (and (wcmatch (nth (1- Num#) List@) Compare$)(wcmatch (nth (1+ Num#) List@) Compare$))
              (setq Prefixes@ (vl-remove (nth Num# List@) Prefixes@))
            );if
          );repeat
        );progn
      );if
      (setq SortLenghts@ (reverse (number_sort (mapcar 'strlen Prefixes@))))
      (setq List@ Prefixes@)
      (foreach Num# SortLenghts@
        (setq First t)
        (foreach Str$ List@
          (if (and (= (strlen Str$) Num#) First)
            (setq First nil
                  List@ (vl-remove Str$ List@)
                  PrefixSort@ (append PrefixSort@ (list Str$))
            );setq
          );if
        );foreach
      );foreach
      (setq Prefixes@ (mapcar 'list PrefixSort@))
      (setq List@ AlphaSort@ Num# 0)
      (foreach Prefix$ PrefixSort@
              PrefixList@ (nth Num# Prefixes@)
              First t
        );setq
        (foreach Str$ List@
          (if (wcmatch Str$ Compare$)
              (if First
                (setq PrefixList@ (append PrefixList@ (list (vl-position Str$ AlphaSort@)))
                      First nil
                );setq
              );if
              (setq List@ (vl-remove Str$ List@)
                    Str$ (substr Str$ (1+ (strlen Prefix$)))
                    PrefixList@ (append PrefixList@ (list Str$))
              );setq
            );if
          );if
        );foreach
        (setq Prefixes@ (change_nth Num# PrefixList@ Prefixes@))
      );foreach
      (foreach PrefixList@ Prefixes@
        (setq NumStrings@ (cddr PrefixList@)
              NumSort@ (number_sort (mapcar 'atoi NumStrings@))
              List@ nil
        );setq
        (foreach Num# NumSort@
          (setq Loop t Cnt# 0)
          (while Loop
            (setq Str$ (nth Cnt# NumStrings@))
            (if (= (atoi Str$) Num#)
              (setq NumStrings@ (delete_nth Cnt# NumStrings@)
                    Str$ (strcat (nth 0 PrefixList@) Str$)
                    List@ (append List@ (list Str$))
                    Loop nil
              );setq
            );if
          );while
        );foreach
        (setq Num# (nth 1 PrefixList@) SortList@ Original@)
        (foreach Str$ List@
          (setq Str$ (nth (vl-position Str$ AlphaSort@) Original@))
          (setq SortList@ (change_nth Num# Str$ SortList@))
        );foreach
        (setq Original@ SortList@)
      );foreach
    );progn
  );if
  (foreach Str$ AlphaSort@
    (if (wcmatch (substr Str$ 1 1) "#")
      (setq NumStrings@ (append NumStrings@ (list Str$)))
    );if
  );foreach
  (if NumStrings@
      (setq NumSort@ (number_sort (mapcar 'atoi NumStrings@))
            List@ nil
      );setq
        (while Loop
                  Loop nil
            );setq
          );if
        );while
      );foreach
      (setq Num# 0 SortList@ Original@)
      (foreach Str$ List@
      );foreach
    );progn
  );if
  Original@
);defun win_sort
; number_sort - Sorts list of numbers
; Arguments: 1
;   List@ = List of numbers
; Returns: List of sorted numbers
(defun number_sort (List@ / High~ Item~ List1@ List2@ Low~ NewList@ Passed Swap~)
  (setq Passed t)
  (if (= (type List@) 'LIST)
    (foreach Item~ List@ (if (not (numberp Item~)) (setq Passed nil)))
    (setq Passed nil)
  );if
  (if (not Passed)
    (progn (princ "\nUsage: (number_sort <list of numbers>)") (exit))
  );if
  (repeat (/ (length List@) 2)
    (setq Low~ (car List@) High~ nil NewList@ nil)
    (foreach Item~ (cdr List@)
      (and (< Item~ Low~) (setq Swap~ Low~ Low~ Item~ Item~ Swap~))
      (and (> Item~ High~) (setq Swap~ High~ High~ Item~ Item~ Swap~))
      (setq NewList@ (cons Item~ NewList@))
    );foreach
    (setq List1@ (cons Low~ List1@) List2@ (cons High~ List2@) List@ (cdr (reverse NewList@)))
  );repeat
  (append (reverse List1@) List@ List2@)
);defun number_sort
; Change_nth - Changes the nth item in a list with a new item value.
; Arguments: 3
;   Num# = Nth number in list to change
;   Value = New item value to change to
;   OldList@ = List to change item value
; Returns: A list with the nth item value changed.
(defun Change_nth (Num# Value OldList@)
  (if (<= 0 Num# (1- (length OldList@)))
    (if (> Num# 0)
      (cons (car OldList@) (Change_nth (1- Num#) Value (cdr OldList@)))
      (cons Value (cdr OldList@))
    );if
    OldList@
  );if
);defun Change_nth
; Delete_nth - Deletes the nth item from a list.
; Arguments: 2
;   Num# = Nth number in list to delete
;   OldList@ = List to delete the nth item
; Returns: A list with the nth item deleted.
(defun Delete_nth (Num# OldList@)
  (vl-remove-if '(lambda (x) (zerop (setq Num# (1- Num#)))) OldList@)
);defun Delete_nth
« Last Edit: May 21, 2007, 04:20:50 PM by Terry Cadd »
VVA
« Reply #6 on: May 19, 2007, 06:36:17 AM »
Win_sort sort string with ignore case of none numeric char
Other variant
(defun SortStringWithNumberAsNumber1 (ListOfString)
    (setq i     0
          ret   ""
    ) ;_ end of setq
          (while
          ) ;_ end of while
        ) ;_ end of progn
      ) ;_ end of if
    ) ;_ end of while
    ret
  ) ;_ end of defun
          (vl-sort-i (mapcar 'NormalizeNumberInString (mapcar 'strcase ListOfString))
  ) ;_ end of mapcar
) ;_ end of defun
Test
(setq Lst (list "1-C4.dwg" "7-b7.dwg" "11-C4.dwg" "2-b3.dwg" "2-c2.dwg" "22-b2.dwg" "pn374-x9.dwg" "pn374-z9.dwg" "Pn375-A10.dwg" "pN375-A9.dwg" "pn375-D1.dwg" "PN375-D10.dwg" "pN375-D2r3.dwg" "pn375-D22.dwg" "qr86-007.dwg" "pN375-DB.dwg" "pn375-DB10a.dwg" "PN375-DB9.dwg"))
        (SortStringWithNumberAsNumber1 lst))
Result
SortStringWithNumberAsNumber1   Win_Sort
1-C4.dwg                            1-C4.dwg
2-b3.dwg                                         2-b3.dwg
2-c2.dwg                                         2-c2.dwg
7-b7.dwg                                         7-b7.dwg
11-C4.dwg                           11-C4.dwg
22-b2.dwg                           22-b2.dwg
pn374-x9.dwg                           pn374-x9.dwg
pn374-z9.dwg                           pn374-z9.dwg
pN375-A9.dwg                           pN375-A9.dwg
Pn375-A10.dwg                           Pn375-A10.dwg
pn375-D1.dwg                           pn375-D1.dwg
pN375-D2r3.dwg                           pN375-D2r3.dwg
PN375-D10.dwg                           PN375-D10.dwg
pn375-D22.dwg                           pn375-D22.dwg
pN375-DB.dwg                           pN375-DB.dwg
PN375-DB9.dwg                           PN375-DB9.dwg
terrycadd
« Reply #7 on: May 19, 2007, 02:34:01 PM »
VVA,
You have written a very nice and short program. It does everything that win_sort does in the sort. Good job!
I've attached two demos that you and others can try out to test their own sort functions. SortDemo1 is using your SortStringWithNumberAsNumber1 function, and SortDemo2 is using the win_sort function.
(defun c:SortDemo1 (/ Filename$ OriginalList@ PathFilename$ SortedList@)
  (princ "\nSelect a drawing in a folder for Folder name:")(princ)
  (if (not *LastFolder$)
    (setq *LastFolder$ (getvar "DWGPREFIX"))
  );if
  (if (setq PathFilename$ (getfiled " Select a drawing in a folder for Folder name" *LastFolder$ "dwg" 2))
    (setq *LastFolder$ (strcat (vl-filename-directory PathFilename$) "\\"))
    (exit)
  );if
  (textscr)
  (princ (strcat "\n" *LastFolder$))
  (setq OriginalList@ (vl-directory-files *LastFolder$ "*.dwg" 1))
  (princ (strcat "\n" (chr 160) "\nOriginal list:\n--------------"))
  (foreach Filename$ OriginalList@
    (princ "\n")(princ Filename$)
  );foreach
  ;Here you can change the sort function name that you are testing
  (setq SortedList@ (SortStringWithNumberAsNumber1 (vl-directory-files *LastFolder$ "*.dwg" 1)))
  (princ (strcat "\n" (chr 160) "\nSorted list:\n------------"))
  (foreach Filename$ SortedList@
  );foreach
);defun c:SortDemo1
(defun c:SortDemo2 (/ Filename$ OriginalList@ PathFilename$ SortedList@)
  );if
    (exit)
  );if
  (textscr)
  );foreach
  (setq SortedList@ (win_sort (vl-directory-files *LastFolder$ "*.dwg" 1)))
  );foreach
);defun c:SortDemo2
« Last Edit: May 19, 2007, 11:02:40 PM by Terry Cadd »
« Reply #8 on: May 20, 2007, 12:16:10 PM »
VVA has done an excellent job.
I wrote a version that changes the strings to list but it was much longer & slower than your code.
I made some mods of your code for my use. I'll post them in case anyone is interested.
;;  By VVW --  05.20.07 mods by CAB
;;Usage (SortStringWithNumberAsNumber '("A9" "A1" "A10" "B11" "B2" "B05") nil)
;;  CAB added Ignore Case Flag as an argument
(defun SortStringWithNumberAsNumber (ListOfString IgnoreCase / NorStrs count
                                     NormalizeNumberInString getcount)
;;; CAB added count as an argument
  (defun NormalizeNumberInString (str count / ch i pat ret buf)
    (setq i   0
          ret ""
    ) ;_ end of setq
          (while
          ) ;_ end of while
        ) ;_ end of progn
      ) ;_ end of if
    ) ;_ end of while
    ret
  ) ;_ end of defun
  ;;  function to Count the longest number in string
  ;;  CAB added to get the correct COUNT
  (defun getcount (lst / count pat)
    (setq count 0)
    (setq pat '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9"))
    (mapcar
      '(lambda (str / i maxlen ch)
         (setq i 0 maxlen 0)
           (if (vl-position ch pat) ; number
             (setq maxlen (1+ maxlen))
             (setq count  (max count maxlen) maxlen 0)
      Lst
    count
  (setq count   (GetCount ListOfString)
        NorStrs (mapcar '(lambda (x) (NormalizeNumberInString x count))
                        ListOfString)
  (and IgnoreCase (setq NorStrs (mapcar 'strcase NorStrs)))
  (mapcar '(lambda (x) (nth x ListOfString)) (vl-sort-i NorStrs '<))
) ;_ end of defun
<edit: corrections made per VVA suggestion below>
« Last Edit: May 21, 2007, 11:33:57 AM by CAB »
VVA
« Reply #9 on: May 21, 2007, 04:21:41 AM »
CAB has written, I so think, a final variant of function. One small addition:
NorStrs count set as local variables
;;Published http://www.theswamp.org/index.php?topic=16564.0
;;By VVA --  05.20.07 mods by CAB
;;With ignore case (SortStringWithNumberAsNumber '("A9" "A1" "A10" "B11" "B2" "B05") t)
(defun SortStringWithNumberAsNumber (ListOfString IgnoreCase / NorStrs count)
    (setq i   0
          ret ""
    ) ;_ end of setq
          (while
          ) ;_ end of while
        ) ;_ end of progn
      ) ;_ end of if
    ) ;_ end of while
    ret
  ) ;_ end of defun
    (setq count 0)
    (mapcar
         (setq i 0 maxlen 0)
      Lst
    count
                        ListOfString)
) ;_ end of defun
terrycadd
« Reply #10 on: May 21, 2007, 10:42:01 AM »
VVA,
Thank you so much for writing this sort program. It’s excellent!
Thanks,
Terry
VVA
« Reply #11 on: June 21, 2007, 03:48:50 AM »
Found one bugs (thanks Elpanov Evgeniy)
 return
("A1" "A10" "A9" "B05" "B11" "B2")
should be
The corrected variant
    (setq i   0
          ret ""
    ) ;_ end of setq
          (while
          ) ;_ end of while
        ) ;_ end of progn
      ) ;_ end of if
    ) ;_ end of while
    ret
  ) ;_ end of defun
    (setq count 0)
    (mapcar
         (setq i 0 maxlen 0)
(setq count  (max count maxlen)) ;_<<< ADD 21.06.2007 by VVA
      Lst
    count
                        ListOfString)
) ;_ end of defun
antistar
« Reply #12 on: January 27, 2014, 10:11:10 AM »
Could anyone help me to sort this way?
("AS1" "AS2" "AS10" "T1" "T2" "T10" "T1A" "T2A" "T10A" "T1B" "T2B" T10B ")
Thanks in advance.
dale_fuger
« Reply #13 on: January 27, 2014, 11:29:44 PM »
You might look into DOSLib's DOS_STRSORT function and it's logical sorting option.
http://www.en.na.mcneel.com/doslib/string_functions/dos_strsort.htm
For example:
Command: (dos_strsort '("A1" "A10" "A9" "B05" "B11" "B2") -1)
Does this help?
-- Dale
Marc'Antonio Alessi
  • Marco
« Reply #14 on: January 28, 2014, 06:13:30 AM »
Thanks in advance.
I have this:
; Function: ALE_List_SortAtoms
; Version 1.00 -    01/2005    (old name ALE_SortAlphaNum)
; Version 1.13 - 24/01/2007
; Version 1.20 - 26/03/2007
; Version 1.21 - 26/08/2010
; Example:
;   (ALE_List_SortAtoms
;    '("C20.10R" "C20.3R" nil (1 . 20) "C12" nil "C20.1R" "0"
;      "20K" T (10 20 30) T "2K" -99 "C2" 0 (55) "C201" "-99"
;      "L4" "L1" "L100" "-200K" 8 1 "2C" "20C.1R" "20C.10R"
;      "20C.3R" "20C.R4" "20C.R44" "20C.R3" 4 "20C" "4R" "4C"
;      3.2 1 10 100 200 2 20
; =>(nil nil -99 0 1 1 2 3.2 4 8 10 20 100 200 "-200K" "-99" "0"
;    "2C" "2K" "4C" "4R" "20C" "20C.10R" "20C.1R" "20C.3R" "20C.R3"
;    "20C.R4" "20C.R44" "20K" "C2" "C12" "C20.10R" "C20.1R" "C20.3R"
;    "C201" "L1" "L4" "L100" T T (55) (10 20 30) (1 . 20)
(defun ALE_List_SortAtoms (InpLst)
  (mapcar
   '(lambda (LmbDat) (nth LmbDat InpLst))
    (vl-sort-i InpLst
     '(lambda (LmbDt1 LmbDt2 / Typ001 Typ002 Num001 Num002 Flg001 Flg002)
        (setq Typ001 (type LmbDt1)    Typ002 (type LmbDt2))
          ( (not LmbDt1) )
          ( (not LmbDt2) nil)
          ( (eq Typ001 'LIST) nil)
          ( (eq Typ002 'LIST) )
          ( (eq Typ001 'SYM)  nil)
          ( (eq Typ002 'SYM) )
          ( (and
              (setq Flg001 (numberp LmbDt1)  Flg002 (numberp LmbDt2))
              Flg001
            (< LmbDt1 LmbDt2)
          ( (and Flg002 (not Flg001)) nil )
          ( Flg001 )
              (setq Num001 (if Flg001 LmbDt1 (atof LmbDt1)))
              (setq Num002 (if Flg002 LmbDt2 (atof LmbDt2)))
              0
            (setq
              Num001 (atof
                       (vl-string-translate
                         " ABCDEFGHIJKLMNOPQRSTUVWXYZ"
                         "000000000000000000000000000"
                         (strcase LmbDt1)
              Num002 (atof
                         (strcase LmbDt2)
              LmbDt1 (vl-string-translate "123456789" "000000000" LmbDt1)
              LmbDt2 (vl-string-translate "123456789" "000000000" LmbDt2)
              ( (and (= LmbDt1 LmbDt2) (< Num001 Num002)) )
              ( (< LmbDt1 LmbDt2) )
          ( (and (zerop Num001) (not (eq LmbDt1 "0"))) nil )
          ( (and (zerop Num002) (not (eq LmbDt2 "0"))) )
          ( (or (< Num001 Num002) (and (= Num001 Num002) (< LmbDt1 LmbDt2))) )
(ALE_List_SortAtoms '("T1A" "AS2" "AS10" "T10B" "T1" "AS1" "T2" "T10" "T2A" "T10A" "T1B" "T2B"))
=====>  ("AS1" "AS2" "AS10" "T1" "T2" "T10" "T10A" "T10B" "T1A" "T2A" "T1B" "T2B")
Your=>  ("AS1" "AS2" "AS10" "T1" "T2" "T10" "T1A" "T2A" "T10A" "T1B" "T2B" "T10B")
antistar
« Reply #15 on: January 28, 2014, 06:39:59 AM »
For example:
Does this help?
-- Dale
Hi Dale,
This function does not return what I need.
Still I appreciate your attention and reply.
Thanks a lot...  :-)
antistar
« Reply #16 on: January 28, 2014, 06:44:23 AM »
I have this:
Hi Marc'Antonio,
Your code is what is closer than I need.
Thanks for your attention and help.
« Reply #17 on: January 28, 2014, 08:49:37 AM »
You can use Gile's Alpha2Num routine & index sort on the resulting numbers.  8)
« Reply #18 on: January 28, 2014, 07:13:48 PM »
I have this in my library:
  1. ;; Alphanumerical Sort  -  Lee Mac
  2. ;; Sorts a list of strings containing a combination of alphabetical & numerical characters.
  3.
  4. (defun LM:alphanumsort ( lst )
  5.     (mapcar (function (lambda ( n ) (nth n lst)))
  6.         (vl-sort-i (mapcar 'LM:splitstring lst)
  7.             (function
  8.                 (lambda ( a b / x y )
  9.                     (while
  10.                         (and
  11.                             (setq x (car a))
  12.                             (setq y (car b))
  13.                             (= x y)
  14.                         )
  15.                         (setq a (cdr a)
  16.                               b (cdr b)
  17.                         )
  18.                     )
  19.                     (cond
  20.                         (   (null x) b)
  21.                         (   (null y) nil)
  22.                         (   (and (numberp x) (numberp y)) (< x y))
  23.                         (   (numberp x))
  24.                         (   (numberp y) nil)
  25.                         (   (< x y))
  26.                     )
  27.                 )
  28.             )
  29.         )
  30.     )
  31. )
  32.
  33. ;; Split String  -  Lee Mac
  34. ;; Splits a string into a list of text and numbers
  35.
  36. (defun LM:splitstring ( str )
  37.     (
  38.         (lambda ( l )
  39.             (read
  40.                 (strcat "("
  41.                     (vl-list->string
  42.                         (apply 'append
  43.                             (mapcar
  44.                                 (function
  45.                                     (lambda ( a b c )
  46.                                         (cond
  47.                                             (   (= 92 b)
  48.                                                 (list 32 34 92 b 34 32)
  49.                                             )
  50.                                             (   (or (< 47 b 58)
  51.                                                     (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
  52.                                                     (and (= 46 b) (< 47 a 58) (< 47 c 58))
  53.                                                 )
  54.                                                 (list b)
  55.                                             )
  56.                                             (   (list 32 34 b 34 32))
  57.                                         )
  58.                                     )
  59.                                 )
  60.                                 (cons nil l) l (append (cdr l) '(( )))
  61.                             )
  62.                         )
  63.                     )
  64.                     ")"
  65.                 )
  66.             )
  67.         )
  68.         (vl-string->list str)
  69.     )
  70. )
Marc'Antonio Alessi
  • Marco
« Reply #19 on: January 29, 2014, 03:01:43 AM »
I have this in my library:...
Hi Lee,
ALE=====>  ("AS1" "AS2" "AS10" "T1" "T2" "T10" "T10A" "T10B" "T1A" "T2A" "T1B" "T2B")
LM:=====>  ("AS1" "AS2" "AS10" "T1" "T1A" "T1B" "T2" "T2A" "T2B" "T10" "T10A" "T10B")
Antistar>  ("AS1" "AS2" "AS10" "T1" "T2" "T10" "T1A" "T2A" "T10A" "T1B" "T2B" "T10B")
which is more correct?
snownut2
  • Bricscad 22 Ultimate
« Reply #20 on: January 29, 2014, 06:45:39 AM »
It seems from a logic perspective that LeeMac's is more correct.
« Reply #21 on: January 30, 2014, 10:58:49 AM »
My attempt resulted same as Lee but not so elegant.
  1. (defun c:test ()
  2.   (MySort '("T2A" "AS10" "T10B" "T1" "T2" "AS2" "T10" "T1A" "AS1" "T10A" "T1B" "T2B"))
  3. ;|
  4.   ALE=====>  ("AS1" "AS2" "AS10" "T1" "T2" "T10" "T10A" "T10B" "T1A" "T2A" "T1B" "T2B")
  5.   LM:=====>  ("AS1" "AS2" "AS10" "T1" "T1A" "T1B" "T2" "T2A" "T2B" "T10" "T10A" "T10B")
  6.   Antistar>  ("AS1" "AS2" "AS10" "T1" "T2" "T10" "T1A" "T2A" "T10A" "T1B" "T2B" "T10B") desired result
  7.   CAB=====>  ("AS1" "AS2" "AS10" "T1" "T1A" "T1B" "T2" "T2A" "T2B" "T10" "T10A" "T10B")
  8.
  9. |;
  10.   )
  11.
  12. ;;  CAB 01/30/14
  13. (defun parseNum (str / lst tnum tstr)
  14.   (mapcar
  15.     (function
  16.      (lambda(x)
  17.        (cond
  18.          ((< 47 x 58) ; number
  19.           (if tstr (setq lst (cons (vl-list->string (reverse tstr)) lst) tstr nil))
  20.           (if tnum (setq tnum (cons x tnum))(setq tnum (list x)))
  21.           )
  22.          (t ; non-number
  23.           (if tnum (setq lst (cons (atoi(vl-list->string (reverse tnum))) lst) tnum nil))
  24.           (if tstr (setq tstr (cons x tstr))(setq tstr (list x)))
  25.           )
  26.         )
  27.        ))
  28.     (vl-string->list str))
  29.   (if tstr (setq lst (cons (vl-list->string (reverse tstr)) lst)))
  30.   (if tnum (setq lst (cons (atoi(vl-list->string (reverse tnum))) lst)))
  31.   (reverse lst)
  32. )
  33.
  34.
  35. (defun MySort (lst)
  36.   (mapcar '(lambda (x) (nth x lst))
  37.           (vl-sort-i (mapcar '(lambda(x) (ParseNum x)) lst)
  38.                      '(lambda (e1 e2)
  39.                         (if (= (car e1) (car e2))
  40.                           (if (= (cadr e1) (cadr e2))
  41.                             (< (caddr e1) (caddr e2))
  42.                             (< (cadr e1) (cadr e2))
  43.                           )
  44.                           (< (car e1) (car e2))
  45.                         )
  46.                       )
  47.           )
  48.   )
  49. )
Andrea
« Reply #22 on: June 27, 2017, 01:48:46 PM »
100 kudos  :smitten:
Keep smile...
rayakmal
« Reply #23 on: September 24, 2018, 04:51:26 AM »
  3.
  7.             (function
  9.                     (while
  10.                         (and
  13.                             (= x y)
  14.                         )
  15.                         (setq a (cdr a)
  16.                               b (cdr b)
  17.                         )
  18.                     )
  19.                     (cond
  20.                         (   (null x) b)
  21.                         (   (null y) nil)
  23.                         (   (numberp x))
  25.                         (   (< x y))
  26.                     )
  27.                 )
  28.             )
  29.         )
  30.     )
  31. )
  32.
  35.
  37.     (
  38.         (lambda ( l )
  39.             (read
  40.                 (strcat "("
  42.                         (apply 'append
  43.                             (mapcar
  44.                                 (function
  46.                                         (cond
  47.                                             (   (= 92 b)
  49.                                             )
  53.                                                 )
  54.                                                 (list b)
  55.                                             )
  57.                                         )
  58.                                     )
  59.                                 )
  61.                             )
  62.                         )
  63.                     )
  64.                     ")"
  65.                 )
  66.             )
  67.         )
  69.     )
  70. )
What if I have a multi dimension list like this:
(("A.05" "12.34" "Regular") ("A.10 "34.54 "BigSize") ("B.9" "66.73" "Regular") ("A.05" "12.55" "BigSize"))
What is the most efficient and correct way  to sort this list?
« Reply #24 on: September 24, 2018, 12:28:27 PM »
Should the list be sorted by the first element; or by first, then second, then third?
rayakmal
« Reply #25 on: April 29, 2019, 12:21:22 AM »
I gave a wrong list. It should be like this:
(("A.05" 12.34 "Regular") ("A.10" 34.54 "BigSize") ("B.9" 66.73 "Regular") ("A.10" 12.12 "BigSize") ("A.05" 12.55 "BigSize"))
The result:
(("A.05" 12.34 "Regular") ("A.05" 12.55 "BigSize") ("A.10" 12.12 "BigSize") ("A.10" 34.54 "BigSize") ("B.9" 66.73 "Regular"))
The list should be sort by the first element and then second.
« Reply #26 on: April 29, 2019, 08:19:37 AM »
(("A.05" 12.34 "Regular") ("A.10" 34.54 "BigSize") ("B.9" 66.73 "Regular") ("A.10" 12.12 "BigSize") ("A.05" 12.55 "BigSize"))The result:
(("A.05" 12.34 "Regular") ("A.05" 12.55 "BigSize") ("A.10" 12.12 "BigSize") ("A.10" 34.54 "BigSize") ("B.9" 66.73 "Regular"))The list should be sort by the first element and then second.
Consider the following function based on the code from my earlier post -
  1. (defun mysort ( l )
  2.     (vl-sort l
  3.         (function
  4.             (lambda ( a b / x y )
  5.                 (if (= (car  a) (car  b))
  6.                     (< (cadr a) (cadr b))
  7.                     (progn
  8.                         (setq a (LM:splitstring (car a))
  9.                               b (LM:splitstring (car b))
  10.                         )
  11.                         (while
  12.                             (and
  13.                                 (setq x (car a))
  14.                                 (setq y (car b))
  15.                                 (= x y)
  16.                             )
  17.                             (setq a (cdr a)
  18.                                   b (cdr b)
  19.                             )
  20.                         )
  21.                         (cond
  22.                             (   (null x) b)
  23.                             (   (null y) nil)
  24.                             (   (and (numberp x) (numberp y)) (< x y))
  25.                             (   (numberp x))
  26.                             (   (numberp y) nil)
  27.                             (   (< x y))
  28.                         )
  29.                     )
  30.                 )
  31.             )
  32.         )
  33.     )
  34. )
  35.
  36. ;; Split String  -  Lee Mac
  37. ;; Splits a string into a list of text and numbers
  38.
  39. (defun LM:splitstring ( str )
  40.     (
  41.         (lambda ( l )
  42.             (read
  43.                 (strcat "("
  44.                     (vl-list->string
  45.                         (apply 'append
  46.                             (mapcar
  47.                                 (function
  48.                                     (lambda ( a b c )
  49.                                         (cond
  50.                                             (   (= 92 b)
  51.                                                 (list 32 34 92 b 34 32)
  52.                                             )
  53.                                             (   (or (< 47 b 58)
  54.                                                     (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
  55.                                                     (and (= 46 b) (< 47 a 58) (< 47 c 58))
  56.                                                 )
  57.                                                 (list b)
  58.                                             )
  59.                                             (   (list 32 34 b 34 32))
  60.                                         )
  61.                                     )
  62.                                 )
  63.                                 (cons nil l) l (append (cdr l) '(( )))
  64.                             )
  65.                         )
  66.                     )
  67.                     ")"
  68.                 )
  69.             )
  70.         )
  71.         (vl-string->list str)
  72.     )
  73. )
Example:
  1. _$ (mysort '(("A.05" 12.34 "Regular") ("A.10" 34.54 "BigSize") ("B.9" 66.73 "Regular") ("A.10" 12.12 "BigSize") ("A.05" 12.55 "BigSize")))
  2. (("A.05" 12.34 "Regular") ("A.05" 12.55 "BigSize") ("A.10" 12.12 "BigSize") ("A.10" 34.54 "BigSize") ("B.9" 66.73 "Regular"))
« Reply #27 on: April 29, 2019, 12:37:24 PM »
I'm sure this logic is flawed and horribly inefficient but it's the first thing that came to mind :)
  1. (vl-sort '(("A.05" 12.34 "Regular")
  2.            ("A.10" 34.54 "BigSize")
  3.            ("B.9" 66.73 "Regular")
  4.            ("A.10" 12.12 "BigSize")
  5.            ("A.05" 12.55 "BigSize")
  6.           )
  7.          '(lambda (a b)
  8.             (< (apply 'strcat (mapcar 'vl-princ-to-string a))
  9.                (apply 'strcat (mapcar 'vl-princ-to-string b))
  10.             )
  11.           )
  12. )
  13. ;; (("A.05" 12.34 "Regular") ("A.05" 12.55 "BigSize") ("A.10" 12.12 "BigSize") ("A.10" 34.54 "BigSize") ("B.9" 66.73 "Regular"))
« Reply #28 on: April 29, 2019, 12:59:54 PM »
Add ("B.10" 66.73 "Regular") to your list  :wink:
« Reply #29 on: April 29, 2019, 03:34:23 PM »
DOH!   :-) That's some strange numbering since "A.05" is formatted correctly.
« Reply #30 on: April 29, 2019, 06:03:46 PM »
I agree - if leading zeroes could be guaranteed, this task would be significantly easier...  :-)
rayakmal
« Reply #31 on: April 29, 2019, 09:56:29 PM »
  2.     (vl-sort l
  3.         (function
  7.                     (progn
  10.                         )
  11.                         (while
  12.                             (and
  15.                                 (= x y)
  16.                             )
  17.                             (setq a (cdr a)
  18.                                   b (cdr b)
  19.                             )
  20.                         )
  21.                         (cond
  22.                             (   (null x) b)
  23.                             (   (null y) nil)
  25.                             (   (numberp x))
  27.                             (   (< x y))
  28.                         )
  29.                     )
  30.                 )
  31.             )
  32.         )
  33.     )
  34. )
  35.
  38.
  40.     (
  41.         (lambda ( l )
  42.             (read
  43.                 (strcat "("
  45.                         (apply 'append
  46.                             (mapcar
  47.                                 (function
  49.                                         (cond
  50.                                             (   (= 92 b)
  52.                                             )
  56.                                                 )
  57.                                                 (list b)
  58.                                             )
  60.                                         )
  61.                                     )
  62.                                 )
  64.                             )
  65.                         )
  66.                     )
  67.                     ")"
  68.                 )
  69.             )
  70.         )
  72.     )
  73. )
Example:
Wow  :-o :-o :-o That's what I want, Lee.
Once again, Thanks.  I really appreciate your help.
Ron, Thanks for chiming in.
« Reply #32 on: May 01, 2019, 01:58:25 PM »
You're welcome!  :-)
