Author Topic: Scaling a plotted drawing??  (Read 22366 times)
« Reply #15 on: June 28, 2004, 02:36:52 PM »
Me too
Slim©
  • The Dude Abides...
« Reply #16 on: June 28, 2004, 03:33:27 PM »
When things are set up right (for me), AutoCAD Rocks.    :D  :D
I drink beer and I know things....
Dent Cermak
« Reply #17 on: June 28, 2004, 04:29:27 PM »
I fell in love with autoCad when they told me that I could throw my french curves away.
42
« Reply #18 on: June 28, 2004, 04:40:35 PM »
Keith noted that there is a disclaimer on their drawings to the effect “do not scale these drawings only use figured dimensions”. All of our construction drawings have this disclaimer on them. All of our A1 plots are plotted “Extents” (in paper space), so the finished plot may well be close to 1:100 or 1:50. The exact scale of the plot is irrelevant so long as there are enough figured dimensions to enable the bluntest tools in the box construct the building, slightly unfair, but you know what I mean.
For our own use, we frequently produce a set of A3 prints as desk copies as they are easier to handle than A1. Some contractors will also request A3 prints for the same reason.
The best example I have of a contractor trying to scale prints was a ground worker bringing a dirty soaking wet handful of near pulp and claiming that he could not set out the foundations from these prints!
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
CADaver
« Reply #19 on: June 28, 2004, 04:48:37 PM »
Quote from: Dent Cermak
For me it was the Leroy set and the pen cleaning station.
"You mean I no longer have to spend every afternoon 3 nuckles deep in black water?!?!?!?!?"
« Reply #20 on: June 29, 2004, 03:02:43 AM »
We generally address this issue by putting right on the drawing:
All dimensions shown are <unit of measurement>.
and
Do not scale drawing.
CADaver
« Reply #21 on: June 29, 2004, 07:46:18 AM »
Quote from: MP
and
Then plotting to scale is a non-issue, right?
hendie
« Reply #22 on: June 29, 2004, 07:59:17 AM »
All dimensions in millimetres unless otherwise stated
Do NOT scale. If in doubt ask
is there anything unclear about that ?
if the drawing does not contain enough data to manufacture the part then the drawing is incomplete, and therefore, incorrect.
« Reply #23 on: June 29, 2004, 08:28:54 AM »
Quote from: CADaver
Not when it is required by law AND when the contractor will reject the plans if they are not plotted to scale.
CADaver
« Reply #24 on: June 29, 2004, 08:36:36 AM »
Quote from: Keith
Quote from: CADaver
Based on the other thread, you can't prove it wasn't.
CADaver
« Reply #25 on: June 29, 2004, 08:37:59 AM »
Quote from: hendie
Bingo, we have a winner, to pick up your prize, call 713-555-pintobeans.
« Reply #26 on: June 29, 2004, 09:18:44 AM »
Quote from: hendie
You are absolutely right, but if the drawing contains even a meager amount of data that adequately describes the model, and it can be built using nothing more than basic construction techniques it is indeed correct.
Plotting to scale is a basic idea that produces viable and reproducable results that any monkey with a masuring tape can gather additional information from. If it is not to scale then he cannot.
CADaver
« Reply #27 on: June 29, 2004, 11:53:35 AM »
Quote from: Keith
As long as he doen't care that the additional information is inaccurate.  But then he's only a monkey.
Quote from: Keith
If he's looking for "ballpark" numbers (which is the BEST that can be derived), he can interpolate from any drawing, "to scale" or otherwise.
« Reply #28 on: June 29, 2004, 05:57:47 PM »
Quote from: CADaver
Quote from: Keith
Quote from: Keith
As are most contractors, and managers
CADaver
« Reply #29 on: June 29, 2004, 06:09:42 PM »
Quote from: Keith
ummm.... which?
"Monkeys" or "looking for "ballpark" ??
