Author Topic: AecExportToAutocad2004 in lisp  (Read 3198 times)
mr_nick
« on: May 14, 2007, 06:28:59 AM »
Is there a way to run the AecExportToAutocad2004 from lisp without triggering the dialog box? I want to quickly open a bundle of drawings, run the command and save them accepting the default suggested filename and location but I can only get the command to run with the dialog box opening.
Krushert
  • FREE BEER Tomorrow!!
Re: AecExportToAutocad2004 in lisp
« Reply #1 on: May 14, 2007, 08:33:18 AM »
The way I have mine setup is to set "Expert" Variable to higher number (4 for me) and then set it back to "zero" afterwards.  Clunky but it works.
Some of the gurus will more robust solution with less issues I imagine.   I am curious to see how they set theirs up.
mr_nick
« Reply #2 on: May 14, 2007, 08:49:29 AM »
Have you tried and tested this? I have had a go but regardless of what value I set expert to, I still get the dialog box.
I'm using Architecture 2008 if that makes any difference.
Krushert
« Reply #3 on: May 14, 2007, 09:02:04 AM »
Ohh I see
Wait a minute, I will be right back
**goes behind curtain and pulls foot from mouth**
Okay I am back; had something stuck in my mouth.
Interesting.  I have a "plot and/or save-as" routine that is set up this way and I assume that the AEC Export would be handled the same way.  Adding the AEC Export to my routine is on my to do list.  I thought it was going to be a simple add.  Hrrrrmmmff
Very interesting my dear Watson.  It requires further thought.
I too have Arch 2008 .  Why do they have to mess with names?
Krushert
« Reply #4 on: May 14, 2007, 09:04:35 AM »
Okay I got it.
Also change your "FileDia" variable to "zero"
Excuse me for being slow, have had my too cups of coffee yet.
« Last Edit: May 14, 2007, 09:08:54 AM by Krushert »
« Reply #5 on: May 14, 2007, 09:26:39 AM »
You can try adding a minus sign before the command, like Command "-insert"
Also you can try setting CmdDia to zero.
mr_nick
« Reply #6 on: May 14, 2007, 10:17:32 AM »
Okay I got it.
Doh - should've remembered that one!! Cheers
This method doesn't work on the AecExportToAutocad2004 command - that was my first port of call.
jbuzbee
« Reply #7 on: May 14, 2007, 01:04:26 PM »
All aec commands are defined in remote executables (arx).  If you want a complete list, at the command line type "arx".  When prompted type "commands".  All commands defined by associative arx's will be displayed.  Note that only some commands have two definitions: "aecMyCommand" and "-aecMyCommand".
James Buzbee
Windows 8
