Author Topic: Why does the VS IDE show this as an error?  (Read 8810 times)
mkweaver
« on: May 12, 2007, 11:35:59 AM »
In the code below the Visual Studio IDE (2005 express) flags this "trans.Dispose()" with: Error   1   Name 'trans' is not declared.
Why?  And what is the solution?
Thanks,
Mike
Private Function CreateLayer(ByVal strLayerName As String) As ObjectId
    Dim db As Database = HostApplicationServices.WorkingDatabase
    Try
      Dim Trans As Transaction = db.TransactionManager.StartTransaction()
      Dim ltable As LayerTable = Trans.GetObject(db.LayerTableId, OpenMode.ForRead)
      If ltable.Has(strLayerName) Then
        Return ltable.Item(strLayerName)
      End If
      Dim layNew As LayerTableRecord = New LayerTableRecord()
      layNew.Color = Color.FromColorIndex(ColorMethod.ByAci, 2)
      Return layNew.ObjectId
    Catch ex As System.Exception
      MsgBox("Error in CreateLayer Command" + ex.Message)
    Finally
      [color=red]trans.Dispose()[/color]
    End Try
  End Function
Re: Why does the VS IDE show this as an error?
« Reply #1 on: May 12, 2007, 11:38:48 AM »
You need to declare trans outside(before) the try scope
LE
« Reply #2 on: May 12, 2007, 11:41:38 AM »
See the difference between both names, what is?
« Reply #3 on: May 12, 2007, 11:45:08 AM »
VB is not case sensitive right?
mkweaver
« Reply #4 on: May 12, 2007, 11:47:11 AM »
Okay, an observation and a questions then:
I considered that, but didn't think it would be an issue since both the Trans initialization and Dispose occur inside the Try Block.
If I declare Trans outside the Try block don't I run the risk of an unhandled exception on it's initialization?  Is the only way, then, to dim Trans outside the Try block and initialize it inside?
Regarding the case, I use camelCase when I declare my vars then use them in lower case.  The IDE will change the case to match the declaration when I get the spelling correct.  This helps identify spelling errors.
« Last Edit: May 12, 2007, 11:51:37 AM by mkweaver »
LE
« Reply #5 on: May 12, 2007, 11:48:33 AM »
I don't do VB.NET but just by reading: Name 'trans' is not declared - but I will check here, just to make myself sure. :)
« Reply #6 on: May 12, 2007, 11:54:28 AM »
I am not sure the VB syntax but you could either nest inside another try catch block or look at using the  "using" statement.
is in C# would be
using (ResultBuffer ci1 = new ResultBuffer())
        ci1.Add(new TypedValue(0, "CIRCLE"));
        ci1.Add(new TypedValue(8, "0"));
        ci1.Add(new TypedValue(10, pt1));
        ci1.Add(new TypedValue(40, 2.5));
        Sds.entMake(ci1);
ci1 get disposed when the scope ends
« Last Edit: May 12, 2007, 11:55:30 AM by Danielm103 »
« Reply #7 on: May 12, 2007, 11:59:48 AM »
Good point. VB is Greek  vb to me   :-o
LE
« Reply #8 on: May 12, 2007, 12:07:37 PM »
Yes... (I do not like it... super mickey mouse.... go for C# instead....!!!!!!)
Miguel, try the below code.... it works I mean it gets compiled (and yes you are right the compiler will make the appropriate change of case (for trans to Trans) first time playing with VB.NET
        Try
            End If
            layNew.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, 2)
        Finally
            Trans.Dispose()
        End Try
    End Function
« Last Edit: May 12, 2007, 12:09:13 PM by LE »
« Reply #9 on: May 12, 2007, 12:15:46 PM »
so then
using db As Database = HostApplicationServices.WorkingDatabase
   blah blah blah
End using
and get rid of the dispose call
TonyT
« Reply #10 on: May 12, 2007, 03:54:20 PM »
Yes, you run the risk that StartTransaction() failed to return
a valid Transaction.
But if that ever did happen, it's so serious/critical an error,
that your code should/must fail at that point.
IMHO, the Using construct is a lot easier to understand
and use, and helps avoid needlessly complicated code.
Glenn R
« Reply #11 on: May 13, 2007, 12:02:04 AM »
Agree with Tony, but you could dim it outside try and set to null/nothing, then inside try set it to a valid transaction....
« Reply #12 on: May 13, 2007, 12:17:31 AM »
Would that work? I mean is null IDisposable ?
Glenn R
« Reply #13 on: May 13, 2007, 12:22:12 AM »
C#
Transaction tr = null;
try {
  tr = db.TransactionManager.StartTransaction();
  // more mojo here
} finally {
  tr.Dispose();
I imagine you could do the same thing with VB.
« Reply #14 on: May 13, 2007, 12:26:22 AM »
C#
try {
  // more mojo here
} finally {
  tr.Dispose();
Ah, now I understand
