Ok so i took out the () like you said and I changed alittle bit of the code
(defun get_radiobuttons (minc maxc anggva)
((= gvaothr1 1) (setq minc min100))
((= gva1b 1) (setq minc 1.125))
((= gvaothr2 1) (setq maxc max100))
((= gva4b 1) (setq maxc 4))
((= gva6b 1) (setq maxc 6))
((= gva8b 1) (setq maxc 8))
((= gvaothr3 1) (setq anggva ang100))
((= gva60b 1) (setq anggva (* pi (/ 60)) 180))
(defun get_minmaxcirc ()
(setq mincirc (* minc ss100))
(setq maxcirc (* maxc ss101))
instead of calling out a seperate variable i just called what that varible should be...1.125, 4, 6, 8, 60...
I changed the ang100 variable here to becalled anggva so that it could be called later.
I also made sure to change that call in
(DrawCircles mincirc maxcirc anggva InsPt (car ScList) (cadr ScList))
Yet still got no where....I must be missing something, cause anggva, minc, and maxc are all coming up nil when the program runs.
Should it not be a condition statement? maybe a If statement? if it is then I an lost cause i dont know the if statement code and I have looked online but there are no good examples I have found.
