ok, I am so stumpped here....I have the program loading and allowing for inputs into the editboxes in the UI, all the slides are showing up and are in the correct places.
But, when I hit accept...nothing. it just stops. It doesnt run throught the rest of the commands. ei. it doesnt draw what its suppose too.
I modified the GVA.dwg drawings to try to better show what I want drawn out when accept is selected as Fatty asked for.
T. Willey's Mygva.lsp does what I want too do, but I need it to work with the UI and have a selection for rotation angle, and for it not too ask for the minimum and maximum good viewing area circle radius but calc it by using a the useriputs for the multipliers.
ei. Min multiplier = 1.5, screen height = 72, 1.5X72=108, minimum good viewing area circle = 108R
I am attaching a Image here I hope that helps.
If you download this zip file attached the image will be in there along with the code and the dwg file I was speaking of.
