Author Topic: Document mismatch problem with beta 12  (Read 3702 times)
jbuzbee
« on: May 10, 2007, 09:26:52 AM »
Is no one else using modeless dialogs like palettes? i.e. keep them floating for multiple document sessions??
Oh well.
There is a document mismatch bug with beta 12.  A modeless form opened in drawing 1 won't respond in drawing 2 - and the onDocActivated event isn't firing either.  I posted a bug report and uploaded a sample at sourceforge.  Could someone else confirm this.  ADT 2006 and AutoCAD Architect 2008.
Back to beta 9 . . .
« Last Edit: May 10, 2007, 09:28:55 AM by jbuzbee »
James Buzbee
Windows 8
Re: Document mismatch problem with beta 12
« Reply #1 on: May 10, 2007, 11:44:53 PM »
I've added a note and alternative code at SourceForge James ... essentially I agree.
I can close the dialog.
Calling the eventHandler from the command line does update the dialog, so it's certainly an event firing problem.
« Reply #2 on: May 18, 2007, 04:30:42 AM »
Have you tried this with B13 James ??
jbuzbee
« Reply #3 on: May 18, 2007, 08:42:30 AM »
Ahhhhh . . .
I have code in my mnl file to catch and refresh floating forms, and the onDocActivated event is now working - I think I can finally take most of the refresh buttons off my forms!
13 indeed seems to be a lucky number: everything seems to be working fine.
Thanks for your help in confirming the problem.  Your work with opendcl has proved invaluable.   :wink:
James Buzbee
Windows 8
