Author Topic: C++ managed project command  (Read 3710 times)
Draftek
« on: May 08, 2007, 03:43:17 PM »
I'm playing around with managed c++ and cannot get a command to work:
I can't get the assembly:CommandClassAttribute method to compile and if I comment it out, the command "MyTest" does not register with AutoCAD.
// MgdCpp.h
#using <System.dll>
#using <..\..\..\Program Files\Autodesk\Acadm 2007\acdbmgd.dll>
#using <..\..\..\Program Files\Autodesk\Acadm 2007\acmgd.dll>
#pragma once
using namespace System;
using namespace Autodesk::AutoCAD::Runtime;
//[assembly: CommandClassAttribute(MgdCpp::Commands::typeid)]
namespace MgdCpp {
public ref class Commands
[CommandMethodAttribute("MyTest")]
static void MyTest()
see anything blaring wrong?
LE
Re: C++ managed project command
« Reply #1 on: May 08, 2007, 06:07:57 PM »
Mr. Matchmaker;
I don't have my books here... but I remember that Master Daniel uploaded a SLN project here.
Anyway, I have never have done any managed C++ code, but, it does not follow basically the same as in C++?
Like in your header file:
using namespace Autodesk::AutoCAD::DatabaseServices;
namespace ClassLibrary
public class LESQClass
private:
LESQClass() {};
[Autodesk::AutoCAD::Runtime::CommandMethodAttribute("CMDTEST1")]
static void cmdtest1();
void ClassLibrary::LESQClass::cmdtest1()
Don't know...
if you use the arxwizard for your solution and click in the .NET checkbox... it will generate the basic skeleton...
edit: some grammatical that was super mickey mouse...
« Last Edit: May 08, 2007, 06:27:23 PM by LE »
Paul Richardson
« Reply #2 on: May 08, 2007, 08:44:15 PM »
// MgdCpp.h
#using <System.dll>
#pragma once
namespace MgdCpp {
You need to make your CommandMethod Public:
public:
« Last Edit: May 08, 2007, 08:47:03 PM by Paul Richardson »
Draftek
« Reply #3 on: May 09, 2007, 08:08:22 AM »
DOH! - I KNEW it was something simple.
Thanks guys!
Any clue why the CommandClassAttribute will not compile? I'm guessing I'd have the same problem with IExtensionApplication Attribute as well, which I use on occasion.
LE
« Reply #4 on: May 09, 2007, 12:22:39 PM »
Dang... I see that my response was indeed out-of-scope...  :oops:  :oops:
Paul Richardson
« Reply #5 on: May 10, 2007, 09:59:24 AM »
I'll gladly trade my knowledge of C++/CLI for your knowledge of ARX... You'd
get the short end of that stick... :)
