Author Topic: Making text bold and set colors on MS Chart control  (Read 3718 times)
iliekater
« on: May 08, 2007, 01:42:01 AM »
 Recently I discovered the MSChart control . It looks great , but I have a problem . I want to show a bold text at the bottom of the control , so I use the following code :
MyForm.MSChart.Footnote.Location.LocationType = VtChLocationTypeBottom
MyForm.MSChart.Footnote.Font.Bold = True
Although I manage to specify the position of the text (at the bottom) , I get an error message at the second line saying :
Property is write only .
What does it mean ? I press the Help button , but MSDN informs that I should create my own functions for handling the MSChart's errors . Yeah , thanks alot .
The strange thing is that I can actually make the text bold through the manual procedure (right click on the control > Properties > and so on ...) . But I want to do that by code . Is there a way ?
The other thing I can't do by code (but can do manually - but it's not what I want) , is to set the color for each of the columns . Does anyone know ho this is possible ?
Re: Making text bold and set colors on MS Chart control
« Reply #1 on: May 08, 2007, 04:22:38 AM »
Do you mean Read Only ??
iliekater
« Reply #2 on: May 08, 2007, 07:41:15 AM »
Nope ! I literaly meant "write-only" ! Here's the proof . In fact two proofs :
1) During execution :
2) In debug mode (see the yellow pop-up message) :
HarleyHetz
« Reply #3 on: May 17, 2007, 08:49:43 AM »
Try doing a "Debug.Print" on the property...just to see if it will "read" it.
Debug.Print THERMAL_Chart.MSChartTHERMAL.Footnote.Font.Bold
DaveW
« Reply #4 on: May 17, 2007, 09:21:47 AM »
If a property is write-only, then you can't retreive it. You can only set it.
Try using Let or Set
iliekater
« Reply #5 on: May 27, 2007, 06:24:12 PM »
Nope , all negativ . Oh well , I quess I'll have to do that manually .
