Author Topic: Object Properties names to a list?  (Read 2102 times)
mkweaver
« on: May 07, 2007, 07:25:16 PM »
I want to get a list of object properties.  I know I can do a vlax-dump-object, but I want these property names into a list so I can iterate over them.  Something along the lines of:
(mapcar '(lambda (propertyname)
   (vlax-put-property objTarget prop (vlax-get-property objSource prop))
  (listallobjectproperties objSource)
It's the "listallobjectproperties" I'm trying to figure out.  I suppose I could use vlax-dump-object, grab the results from the log file and parse it, but I'm sure hoping there's a better way.
Thanks in advance,
Mike Weaver
Re: Object Properties names to a list?
« Reply #1 on: May 07, 2007, 07:46:56 PM »
One way would be to create a list of every possible, writeable, property, then use a (mapcar) & (vlax-property-available-p) to determine if it's a valid property for the object. I say writeable, because there's no reason to check for Read-Only props if you are copying them from one object to another.
« Reply #2 on: May 07, 2007, 08:55:26 PM »
mkweaver
« Reply #3 on: May 07, 2007, 11:30:11 PM »
Cab,
Thanks for the link.  That is just the kind of information I was hoping to find.
Off to bury myself in parens...
Fatty
« Reply #4 on: May 08, 2007, 04:42:47 AM »
Hi Mike
Here is my old one
Hth
~'J'~
; With help by Peter Ciganek
;  3/7/05  10:39 PM ;
; Display object properties and methods ;
;  helpers:
(defun initax ()
(or acapp (setq acapp (vlax-get-acad-object)))
(or adoc (setq adoc (vla-get-activedocument acapp)))
(cond  ((= (vlax-variant-value
(vla-getvariable adoc "TILEMODE")) 1)
(or mdsp (setq mdsp (vla-get-modelspace adoc))))
(vla-getvariable adoc "TILEMODE")) 0)
(or mdsp (setq mdsp (vla-get-paperspace adoc))))))
(defun my-propts ()
(mapcar (function (lambda (x)
(substr x 9)))
(vl-remove-if-not
(wcmatch (strcase x) "VLA-GET-*")))
(atoms-family 1))))
(defun my-methods ()
(substr x 5)))
(vl-remove-if-not (function (lambda (x)
(and (wcmatch (strcase x) "VLA-*")
(not (wcmatch (strcase x) "VLA-GET-*,VLA-PUT-*")))))
              (atoms-family 1))))
(defun my-err-msg (func_lambda / ret)
  (setq ret (vl-catch-all-apply (function (lambda () func_lambda))))
  (if (and (vl-catch-all-error-p ret))
    (apply (list (vl-catch-all-error-message ret))
    ret
(defun my-catch (a)
(vl-catch-all-apply (function (lambda () a ))))
(defun my-obj (en)
(my-err-msg (vlax-ename->vla-object en)))
(defun my-sel-obj (msg / ent)
(setvar "ERRNO" 0)
(while
  (and (not (setq ent (entsel msg)))
       (equal 7 (getvar "ERRNO"))
  (setvar "ERRNO" 0)
  ((equal (getvar "ERRNO") 52) nil)
  (T (my-obj (car ent)))))
(defun my-make-props-dcl ()
(gc)
(setq fname (strcat (getvar "DWGPREFIX") "objprops.dcl"))
(setq fn (open fname "w"))
(write-line (strcat "selobj : dialog { label = " mark ";") fn)
(write-line "spacer_0;" fn)
(write-line ": boxed_row {" fn)
(write-line ": list_box {" fn)
(write-line (strcat "label = " "\"" "*** PROPERTIES / VALUES ***" "\"" ";")  fn)
(write-line (strcat "key = " "\"" "elist1" "\"" ";")  fn)
(write-line (strcat "width = 45; height = 20;}") fn)
(write-line (strcat "label = " "\"" "*** METHODS ***" "\"" ";")  fn)
(write-line (strcat "key = " "\"" "elist2" "\"" ";")  fn)
(write-line (strcat "width = 30; height = 20;}") fn)
(write-line "}" fn)
(write-line "ok_only; " fn)
(write-line ": text_part {" fn)
(write-line (strcat "value = " "\"" "© Designed by Fatty T.O.H." "\"" ";") fn)
(write-line "alignment = left; }" fn)
(write-line (strcat "value = " "\"" "//  From man to man  //" "\"" ";") fn)
(write-line "alignment = right; }" fn)
(write-line "}" fn)
(close fn)
(defun my-props-and-methods ( / en elist elistn tmp)
(setq vobj (my-sel-obj "\nSelect object :  >>> \n")
      pr_list (acad_strlsort
(vlax-property-available-p vobj x)))
(my-propts)))
      met_list (acad_strlsort
(vlax-method-applicable-p vobj x)))
(my-methods)))
      val_list (mapcar (function (lambda(a)(if (not (member a '("COORDINATE" "BULGE")))
      (vlax-get-property vobj a)
"NOT AVAILABLE")))
       pr_list)
    data_list (mapcar (function (lambda(p q)(strcat p " " "  <*> : "
(vl-princ-to-string q)))) pr_list val_list)
    mark (substr (strcase (vla-get-objectname vobj)) 5)
(my-make-props-dcl)
(setq dcl_ix (load_dialog "objprops.dcl"))
(new_dialog "selobj" dcl_ix)
(start_list "elist1")
(mapcar 'add_list data_list)
(end_list)
(start_list "elist2")
(mapcar 'add_list met_list)
(end_list)
(if (= (start_dialog) 1)
nil
(vl-file-delete fname)
(defun C:bxp ()
(setvar "cmdecho" 0)
(initax)
(my-props-and-methods)
(setvar "cmdecho" 1)
(prompt "\nType BXP to execute ... \n")
mkweaver
« Reply #5 on: May 08, 2007, 08:42:04 AM »
Thanks,  I'll take a look at it.
Mike
