Author Topic: Cooperative Fiber Mode Application sample cannot be debugged properly  (Read 2753 times)
WTF, you say ?
https://connect.microsoft.com/VisualStudio/feedback/ViewFeedback.aspx?FeedbackID=95392
long story short.
MS are looking (again) at this known issue which prohibits attaching a bebugger to a running AutoCAD session.
Till then,  we still need to debug apps in AutoCAD by starting AutoCAD from inside Vis' Studio running debug mode.
The article that pointed to this has a reminder " to change the 'Copy To Local' project setting to FALSE if it's TRUE originally. "
interesting .. I guess you learn something every day .. no wonder I have been having such a tough time tracking down pesky runtime errors ...
TonyT
I'm pretty sure the person that logged that issue
was Albert Szilvasy from Autodesk.
WTF, you say ?
long story short.
