Author Topic: create region  (Read 2398 times)
David Hall
  • Automatic Duh Generator
create region
« on: May 04, 2007, 04:33:38 PM »
Riddle me this, if the help file says a region is created from a LWPolyline, why wont this work?
Public Sub wall()
      Dim dblLength As Double, dblWidth As Double, dblHeight As Double
      Dim inspt(2) As Double, endpt(2) As Double
      inspt(0) = 120: inspt(1) = 120: inspt(2) = 0
      Dim oLayer As AcadLayer, oCurrLayeR As AcadLayer, oBlock As AcadBlockReference, _
          oEntity As AcadEntity, newObjs As Variant      ', InsPT As Variant
      Set oCurrLayeR = ThisDrawing.ActiveLayer
      Set oLayer = ThisDrawing.Layers.Add("SITE-WALL")
      oLayer.color = 1
      ThisDrawing.ActiveLayer = oLayer
'      dblLength = CDbl(txtLength.Value)
'      dblWidth = CDbl(txtWidth.Value)
'      dblHeight = CDbl(txtHeight.Value)
      dblLength = 144
      dblWidth = 72
      dblHeight = 60
Dim WallCoords(9) As Double
WallCoords(0) = inspt(0) - (dblLength / 2): WallCoords(1) = inspt(1) + (dblWidth / 2)
WallCoords(2) = inspt(0) + (dblLength / 2): WallCoords(3) = inspt(1) + (dblWidth / 2)
WallCoords(4) = inspt(0) + (dblLength / 2): WallCoords(5) = inspt(1) - (dblWidth / 2)
WallCoords(6) = inspt(0) - (dblLength / 2): WallCoords(7) = inspt(1) - (dblWidth / 2)
WallCoords(8) = inspt(0) - (dblLength / 2): WallCoords(9) = inspt(1) + (dblWidth / 2)
Dim plineObj As AcadLWPolyline
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(WallCoords)
plineObj.Closed = True
Dim regionObj As Variant
  Set regionObj = ThisDrawing.ModelSpace.AddRegion(plineObj)
    ZoomAll
      ThisDrawing.ActiveLayer = oCurrLayeR
RetVal = object.AddRegion(ObjectList)
Object-ModelSpace Collection, PaperSpace Collection, Block
The object or objects this method applies to.
ObjectList-Array of Objects
The array of objects forming the closed coplanar face to be made into a region. This array may contain the following object types: Line, Arc, Circle, Elliptical Arc, LightweightPolyline, Spline.
RetVal-Variant
This method outputs an array of the newly created Region objects.
Re: create region
« Reply #1 on: May 04, 2007, 04:54:08 PM »
the item you pass has to be an array of objects ...
Public Sub wall()
      Set oLayer = ThisDrawing.layers.Add("SITE-WALL")
      oLayer.Color = 1
      dblLength = 144
      dblWidth = 72
      dblHeight = 60
Dim objArray(0) As AcadEntity
Set objArray(0) = ThisDrawing.ModelSpace.AddLightWeightPolyline(WallCoords)
    objArray(0).Closed = True
  ThisDrawing.ModelSpace.AddRegion objArray
  ZoomAll
Fatty
Re: create region
« Reply #2 on: May 04, 2007, 04:55:27 PM »
I am late again :(
Anyway
Public Sub wall()
      oLayer.color = 1
      dblLength = 144
      dblWidth = 72
      dblHeight = 60
Dim bound(0) As AcadEntity
Set bound(0) = plineObj
  regionObj = ThisDrawing.ModelSpace.AddRegion(bound)
plineObj.Delete
    ZoomAll
David Hall
Re: create region
« Reply #3 on: May 04, 2007, 05:25:34 PM »
So let me see if I understand, we are using a generic AcadEntity, creating a LWP as said entity, and passing that to the region command?
Re: create region
« Reply #4 on: May 04, 2007, 05:38:58 PM »
basically .. except the argument for the AddRegion method must be an array of entities ...
i.e.
Dim NumberOfEntities, X As Integer
NumberOfEntities = 10
Dim EntityArray(0 to NumberOfEntities) As AcadEntity
For X = 0 to NumberOfEntities
 Set EntityArray(X) = MakePline() <--- dummy function returning a LWpolyline
Next X
ThisDrawing.ModelSpace.AddRegion(EntityArray)
Atook
  • AKA Tim
Re: create region
« Reply #5 on: May 04, 2007, 05:41:22 PM »
No, you create your LWP, and put that into an array. Pass the array to the .addregion command. It's kinda silly if you're only passing one object, but would make sense if you were using 3 objects to define the region.
Summing it up:
LWP=addlwpoly(blah)
dim arrRegionBound(0) as variant
arrRegionBound(0)=LWP
regionObj = ThisDrawing.ModelSpace.AddRegion(arrRegionBound)
Edit: Just what quickfingersKeith said.
« Last Edit: May 04, 2007, 05:43:49 PM by Atook »
Matersammichman
Re: create region
« Reply #6 on: May 08, 2007, 08:19:16 AM »
along those same lines...
How can you find the center of a region?
Guest
Re: create region
« Reply #7 on: May 08, 2007, 09:27:13 AM »
Maybe this will help?
