Author Topic: OpenDCL  (Read 10829 times)
viva
OpenDCL
« on: May 02, 2007, 07:32:28 AM »
hi everybody,
           i had designed one project in openDcl and written coding in autolisp. while running the lisp, an error is occuring i.e Object dcl could not opened. i kept the odc files and lisp file in the same folder. i had used this coding as shown below.
(Odcl_LoadProject "images")
the version of OpenDCL is 4.0 and iam using autocad map 2004.
can anyone help me solve this problem
regards
viva
Re: OpenDCL
« Reply #1 on: May 02, 2007, 07:44:17 AM »
[recorded message]
Post the ODC and LSP file.
[/recorded message]
Re: OpenDCL
« Reply #2 on: May 02, 2007, 07:45:45 AM »
Is the ARX loaded .. which one .. ?
Are the LSP and ODC in a folder on the ACAD search path. ?
EXACTLY what is the error message you get ?
« Last Edit: May 02, 2007, 07:48:15 AM by Kerry Brown »
Re: OpenDCL
« Reply #3 on: May 02, 2007, 07:49:28 AM »
What does this return ?
(findfile "Images.ODC")
jbuzbee
Re: OpenDCL
« Reply #4 on: May 02, 2007, 09:00:12 AM »
Kerry, now I know why your a "king gator": 3 posts to complete one thought!!  :-o :wink:
James Buzbee
Windows 8
Re: OpenDCL
« Reply #5 on: May 02, 2007, 09:08:17 AM »
Hi James,
I'm usually not that verbose ... the pills are kicking in I think ..
Murphys law says someone will have to ask sooner or later, just getting in sooner I s'pose :-)
viva
Re: OpenDCL
« Reply #6 on: May 03, 2007, 03:18:59 AM »
yeah , lsp and odc are in the search path only. but it shows the error as
" OBJECTDCL COULD NOT ABLE TO FOUND"
iam thinking that the problem is related to objectdcl.arx. how can i find the suitable objectdcl to opendcl 4.0
iam using
Autocad map 2004
opendcl 4.0
objectdcl2004.arx
can u help me to solve
regards
viva
jonesy
  • SuperMod
Re: OpenDCL
« Reply #7 on: May 03, 2007, 03:26:15 AM »
Hi viva
I think you may get more targeted help if  you post the 2 files Kerry Brown has asked for. :-)
Tracey
viva
Re: OpenDCL
« Reply #8 on: May 03, 2007, 03:50:44 AM »
i have attached the lsp and odc file.plz give me solution 2 achieve the target
regards
viva
jonesy
  • SuperMod
Re: OpenDCL
« Reply #9 on: May 03, 2007, 03:54:18 AM »
I'm no programmer, but now the members that can program have something to look at, they will be able to help you sort it out.
Tracey
Re: OpenDCL
« Reply #10 on: May 03, 2007, 04:42:37 AM »
viva,
first try these, and post the results ...
(FINDFILE "OpenDCL_ARXLoader.LSP")
(FINDFILE "OpenDCL.16.arx")
(ODCL_GETVERSIONEX)
Then, change this
(Odcl_LoadProject "images_QC")
to
.... which is the actual NAME of your ODC file
Re: OpenDCL
« Reply #11 on: May 03, 2007, 04:56:58 AM »
Next,
Your File is named Images
your form is named Form1
your button is named TextButton5
Each control is addressed by its name ...
so the Form address is Images_Form1
and the button address is Images_Form1_TextButton5
See the Picture :--
« Last Edit: May 03, 2007, 05:08:39 AM by Kerry Brown »
Re: OpenDCL
« Reply #12 on: May 03, 2007, 05:06:12 AM »
... so the project is loaded with :
(ODCL_LOADPROJECT "images")
the form is displayed with :-
(ODCL_FORM_SHOW images_Form1)
The button is enabled with
(Odcl_Control_SetEnabled images_Form1_TextButton5 T)
So the Code becomes :
(DEFUN c:Images1_QC ()
   ;;(ODCL_LOADPROJECT "images" T)
... and this is the dialog loaded ..
Re: OpenDCL
« Reply #13 on: May 03, 2007, 05:13:03 AM »
.... and it would help if you take the time to answer questions, because they ARE important to help solve your problem.
Re: OpenDCL
« Reply #14 on: May 03, 2007, 05:30:46 AM »
i am thinking that the problem is related to objectdcl.arx.
You also appear to be mixing OpenDCL and ObjectDCL
opendcl 4.0
objectdcl2004.arx ...
objectdcl2004.arx <<<<<<<< The ARX for AC2004 is OpenDCL.16.ARX
If you add something like this to the top of your file, the correct ARX will be loaded.
Note that  OpenDCL_ARXLoader.LSP must be found on the CAD search path.
... only needs to be run once per session.
ADDED: or the .ARX file can be loaded manually or at Startup ..
;; Ensure the OpenDCL.##.ARX is loaded.
(OR (VL-SYMBOL-VALUE 'ODCL_GETVERSIONEX)
    (AND (SETQ tmpfn (FINDFILE "OpenDCL_ARXLoader.LSP"))
         (LOAD tmpfn (STRCAT "Failed to load :- " tmpfn))
    (ALERT (STRCAT "Failed to load OpenDCL_ARXLoader.LSP"))
    (EXIT)
(PROMPT (STRCAT "\n CommandLine : < YOUR COMMAND NAME>  [Build 20070503 kwb] "
                "ODCL.Ver:"
                (ODCL_GETVERSIONEX)
                " \n"
regards
viva
Yes. :-)
« Last Edit: May 03, 2007, 05:42:52 AM by Kerry Brown »
Re: OpenDCL
« Reply #15 on: May 03, 2007, 06:32:59 AM »
I have noticed that there are a couple of sites around that offer downloads of ObjectDCL in various forms .. even one in the Netherlands using the 3Day name ... quite amusing (NOT).
Re: OpenDCL
« Reply #16 on: May 03, 2007, 06:34:16 AM »
OK James, I'm done talking to myself for the night. :-)
viva
Re: OpenDCL
« Reply #17 on: May 04, 2007, 04:19:02 AM »
hi kerry,
          thanks a lot. urs information helped me alot.just iam doing that
regards
viva
jbuzbee
Re: OpenDCL
« Reply #18 on: May 04, 2007, 12:53:23 PM »
Kerry - don't apologize!! Your endless rantings have proved to be an invaluble resource to the openDCL community!! Seriously.  Thanks for taking the time to be so detailed.  :wink:
James Buzbee
Windows 8
