Author Topic: Most underated / underused commands / variables ...  (Read 22468 times)
Bob Wahr
« Reply #135 on: August 17, 2005, 03:59:01 PM »
I forgot oops existed.  Don't think I've used it since r9, maybe 10.
CADaver
« Reply #136 on: August 18, 2005, 06:22:39 AM »
The CHANGE command.
Use it to change the radii of several circles
or
CHANGE a line with ORTHO on to guarantee a true horizontal or vertical line.
or
CHANGE several lines to the same point (with ORTHO on to make parallel lines)
or
Draw several random lines, and a couple of circles.  Enter the CHANGE command and select the objects and press enter.  When prompted for the change point or properties enter the word DRAG (toggle ORTHO off).  You can then change the elements one at a time.  To swap ends of lines that are being changed, move the crosshair such the the "dragged" line would be 0 length, and the anchored end will switch.
Big G
« Reply #137 on: August 29, 2005, 05:53:17 AM »
Revert
Kinda like 'oops'
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
whdjr
« Reply #138 on: August 29, 2005, 11:26:09 AM »
Quote from: Big G
Revert
Kinda like 'oops'
Isn't that an Express Tool?
cparnell
Re: Most underated / underused commands / variables ...
« Reply #139 on: September 14, 2005, 12:54:39 PM »
How about the LSP and or ARX commands
Big G
« Reply #140 on: September 16, 2005, 06:23:34 AM »
REA
As in REgen All
deegeecees
« Reply #141 on: September 16, 2005, 01:33:41 PM »
How about "Align"? I haven't used this command since I started manipulating the UCS.
t-bear
« Reply #142 on: September 16, 2005, 01:47:05 PM »
I still use it in 3D occasionally.....can be a bit unpredictable with solids.............
Bob Wahr
« Reply #143 on: September 16, 2005, 02:57:08 PM »
wow, I use align a lot.
whdjr
« Reply #144 on: September 19, 2005, 10:49:10 AM »
