Author Topic: Most underated / underused commands / variables ...  (Read 23129 times)
M-dub
« Reply #90 on: August 03, 2004, 01:41:45 PM »
~At least for AutoCAD 2004 Express Tools~
ATTIN
ATTOUT
Very nice!
'Bout Bloody Time!
tcdan
« Reply #91 on: July 22, 2005, 08:21:15 PM »
Neat post!
OVERKILL (express tools)
Crank
« Reply #92 on: July 24, 2005, 11:58:13 AM »
3DCONFIG has a hidden option that is not documented. Try enter V and you will see this:
Command: 3DCONFIG Configure: 3DCONFIG
Enter option [Adaptive degradation/Dynamic tessellation/Render
options/Geometry/acceLeration/eXit] <Adaptive degradation>: V
Configure: adVanced
Enter option [Redraw on window expose/Cache viewport draw geometry/Display
lists/Fast hidden line only/Pixel Deviation/eXit]
Crank
« Reply #93 on: July 24, 2005, 11:58:46 AM »
Undocumented commands are +CUSTOMIZE, +DSETTINGS, +OPTIONS, +UCSMAN, and +VPORTS. With the '+' sign before the command name AutoCAD ask you to enter the index for the tab that will be active in the dialog box. +PUBLISH is another one.
Crank
« Reply #94 on: July 24, 2005, 11:59:18 AM »
The undocumented SPACESWITCH system variable can be used to allow or forbid switching between between paperspace and floating modelspace with a double click.
Crank
« Reply #95 on: July 24, 2005, 11:59:50 AM »
FNSPLITL (File Name Split To List) is an undocumented lisp function. It returns a list of (path filename extension). Example: (cadr (fnsplitl (getvar "dwgname")))
Crank
« Reply #96 on: July 24, 2005, 12:00:16 PM »
QAFLAGS been used a long time (<r12) by developers and autodesk themself too. QAFLAGS acceps a value between 0 and 32767
bit 0 (1) : ^C in menu macro cancels grips (acts like keyboard <Esc>).
bit 1 (2) : no pause during text screen listings.
bit 2 (4) : no "alert" dialogs (text display instead).
bit 7 (128) : accepts "screen picks" (point lists) via (command) function.
Normally QAFLAGS should be set to 0.
Graldensblud
« Reply #97 on: July 24, 2005, 02:02:30 PM »
TIME
displayes the time spent working on a given project so far. Useful if you forget your timesheets...
I think there is a way to pause the counter though, somewhere.
Big G
« Reply #98 on: July 25, 2005, 04:30:04 AM »
<TAB>
as in tabbing between OSNAP points.
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
jonesy
  • SuperMod
« Reply #99 on: July 25, 2005, 04:42:57 AM »
My vote has to go with "align"
But I also love the polar command
But the one variable that gets me wound up the most is "textfill" being switched off, it seems to spread like a virus around drawings  :x
SDETERS
« Reply #100 on: July 25, 2005, 08:27:48 AM »
I like rarely used  bpoly command takes a mess of lines and arcs that are closed and makes one single polyline
Also edit paste special
CottageCGirl
« Reply #101 on: July 25, 2005, 09:32:13 AM »
Quote from: Graldensblud
TIME
COOOL....
thanks
Big G
« Reply #102 on: July 25, 2005, 09:42:24 AM »
TIME
The AutoCAD today feature was great for that :P Dont think 2K6 has it anymore though
CottageCGirl
« Reply #103 on: July 25, 2005, 09:42:28 AM »
I am digging polar, it works great for placing furniture, which does not need to be exact, but i try to stick w/ 90 or 45's
my favorite are:
(anything) previous
layer translate
Battman
we are still leary of palletts, -not sure though, the idea is sound and it seems it would be easier than customizing menu's, but too many glitches would be bad, very very bad.....
Dent Cermak
« Reply #104 on: July 25, 2005, 10:51:41 AM »
not a command; a key: NUM LOCK. Don't think it's powerfull? When the guy next to you ain't looking, push it on his key board. Then sit back and watch the fun. Time the event. It would be interesting to see if the people in your office are as dumb as the ones in my office. The shortest time so far is 30 seconds(and that's my time.  :oops: )
