Author Topic: Loop to obtain number sequences  (Read 1902 times)
Kheilmann
« on: April 27, 2007, 09:50:22 AM »
I've tried For X = # to # I have not figured it out yet.  I'm not sure if I need to use
Do until or While????
I basically need a loop to return all sequences upto a certain #.
EX.
If the number of items selected = 2, then I need a loop to return 1&2 and 2&1.
If the # of items = 3, then I need to return 1&2&3, 1&3&2, 2&1&3, 2&3&1, 3&2&1, 3&1&2.
etc.
etc.
Basically these items have to be selected in a specific order (for many reasons), and this will make sure
that no matter how someone selects the items, the final result will always be calculated to a certain sequence.
I can give more detail if need be, but for now I just need help creating a loop to return all sequences possible.
The sequence will always be 1 to (# of items selected by user)
Thanks in advance.
Kevin
David Hall
  • Automatic Duh Generator
Re: Loop to obtain number sequences
« Reply #1 on: April 27, 2007, 09:58:33 AM »
I think the number of possible combinations is the number of items picked , factorial.
As you pointed out, for the #2, there are 2 possible combinations.  for 3 #'s,
there are 6 combinations, (3X2X1) or 3 factorial.  So 4 would be 24 right?
David Hall
« Reply #2 on: April 27, 2007, 10:13:57 AM »
Here is a function to obtain the factorial number
Function FACTORIAL(x As Integer) As Integer
Dim i As Integer
FACTORIAL = 1
For i = 1 To x
FACTORIAL = FACTORIAL * i
Next i
End Function
DaveW
« Reply #3 on: April 27, 2007, 10:38:28 AM »
You may want to use a couple of for loops after adding your data to an array.
The problem with doing this is that it is a bit involved to remove data out of an array. The way I do it is I create a Type array.
Public Type typPLinesArray
  MyHandle As String
  MyLineTypeScale As String
  Used As Integer
  MyStartPointX As Double
  MyStartPointY As Double
  MyStartPointZ As Double
  MyEndPointX As Double
  MyEndPointY As Double
  MyEndPointZ As Double
End Type
In your code you need to also create the array to use, because we have only defined a Type above:
Dim MyPLinesArray2() As typPLinesArray
Now populate MyPLinesArray2() with your data, setting each filed as you go.
Tweak as necessary... You will ahve a dropdown for each area you define in the Type
                MyPLinesArray2(PolyLinesFound2).MyHandle = MyLWPoly.Handle
                MyPLinesArray2(PolyLinesFound2).MyLineTypeScale = MyLWPoly.LinetypeScale
                MyPLinesArray2(PolyLinesFound2).Used = 0
                MyPLinesArray2(PolyLinesFound2).MyStartPointX = PolyStartPoint(0)
                MyPLinesArray2(PolyLinesFound2).MyEndPointX = PolyEndPoint(0)
                MyPLinesArray2(PolyLinesFound2).MyStartPointY = PolyStartPoint(1)
                MyPLinesArray2(PolyLinesFound2).MyEndPointY = PolyEndPoint(1)
                MyPLinesArray2(PolyLinesFound2).MyStartPointZ = PolyStartPoint(2)
                MyPLinesArray2(PolyLinesFound2).MyEndPointZ = PolyEndPoint(2)
Notice the line "Used As Integer"
Once I have used that value, I change its value to 1, so I know I have used it. of course, you have to write a line of code for that.
If MyPLinesArray2(X).Used = 0 Then
Once your array(based/dimmed on your own personal Type is filled, then you can process it.
The basic outline is:
For X = 0 To UBound(MyPLinesArray2)
                    Num1 = MyPLinesArray2(X).MyStartPointX
                    'Whatever you are looking for...
                          For Y = 0 To UBound(MyPLinesArray2)
                              If MyPLinesArray2(Y).Used = 0 Then
                                   Num2 = MyPLinesArray2(Y).MyStartPointX
                                   MyString =  MyString & "," & Trim(Str(Num2))
                                   MyPLinesArray2(Y).Used = 1
                              End if
                         Next
Next
You have quite a bit of code to add, conditional checks for first time through to build your string and will probably need 2 different .used columns, .used1 and .used2, and code to reset 1 of them back to 0 when you want to start over.
