Author Topic: Opening an Acrobat file with a known password  (Read 1980 times)
iliekater
« on: April 26, 2007, 06:40:23 PM »
I wonder if it's possible to open a password protected acrobat file using VB6 . Ofcourse , given the fact that we already know the password . I came with this idea being based on the fact that the same thing can be done for the Access password protect files , so this maybe is possible for Acrobat too .
Edit :
I forgot to specify that I don't want to do that obligatory through a VBA form . I am the same satisfied if I could do that with the default PDF viewer . The main problem is how to specify by code the password , not how to open the PDF with the default viewer .
« Last Edit: April 30, 2007, 08:05:31 AM by iliekater »
Guest
Re: Opening an Acrobat file with a known password
« Reply #1 on: April 27, 2007, 08:26:05 AM »
iliekater
« Reply #2 on: April 30, 2007, 08:01:56 AM »
Thanks . Reading there , I found out that there may be a change of doing it by using Acrobat Proffessional . I'll see what I can do .
