Author Topic: Setting a Cui to Main with VBA  (Read 2494 times)
ML
« on: April 25, 2007, 02:17:03 PM »
I can across The Menufile object under Preferences and realized that is what controls what cui file is the main (customizable) cui
So, I began to write a few macros just to switch beween my working cui and my custom cui.
The first macro is working like a charm but with the second one, it is setting the path to the proper cui and it is saying that my my current workspace that I told it to be is current. However, the toolbars menus etc are not appearing???????????
If I go to the cui editor and right click on the workspace and choose set current, then all is fine.
If the first macro works fine, then the second one "should" work fine as well. Any help is appreciated.
First macro that works well:
Sub Custom()
Dim Preferences As AcadPreferences
Dim MainCuiFile As String
Set Preferences = ThisDrawing.Application.Preferences
'Set a reference to The Main Cui File Path and File
MainCuiFile = "C:\Documents and Settings\my username\Application Data\Autodesk\Autodesk Land Desktop 2006\R16.2\enu\Support\custom.cui"
'The MenuFile = Custom.cui
Preferences.Files.MenuFile = MainCuiFile
'Set The Current Workspace to Custom1
ThisDrawing.SendCommand "wscurrent" & vbCr & "Custom1" & vbCr
MsgBox "The current main cui file is " & MainCuiFile, vbInformation, "Main Cui"
Second macro, not working well????
Sub Land()
MainCuiFile = "C:\Documents and Settings\my username\Application Data\Autodesk\Autodesk Land Desktop 2006\R16.2\enu\Support\land.cui"
'The MenuFile = land.cui
ThisDrawing.SendCommand "wscurrent" & vbCr & "Survey" & vbCr
'Set The Current Workspace to Land Desktop Complete
