Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Appload
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Appload (Read 2284 times)
Luke
Guest
Appload
on:
April 24, 2007, 10:58:48 AM »
Full Version Vanilla AutoCAD 2008.
I feel like I should know this...
Is there a way to APPLOAD from the command line?
I don't want the pop up menu. I want to create a button to load a lisp, run the lisp and update the fields I select in the drawing.
Logged
Dinosaur
Guest
Re: Appload
Reply #1 on:
April 24, 2007, 11:02:45 AM »
assuming your routine is in the search path
(load"your_routine")
Logged
deegeecees
Guest
Re: Appload
Reply #2 on:
April 24, 2007, 11:10:44 AM »
Put this in the button:
(load"yourLisp");(yourCommand)
or if you have created a command:
(load"yourLisp");yourCommand
Logged
Luke
Guest
Re: Appload
Reply #3 on:
April 24, 2007, 11:26:40 AM »
That did it. Thanks!
Logged
deegeecees
Guest
Re: Appload
Reply #4 on:
April 24, 2007, 11:41:27 AM »
No problem whatsoever.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Appload
