Author Topic: GeometricExtents of a MPolygon  (Read 5175 times)
MaksimS
« on: April 21, 2007, 06:28:06 AM »
AutoCAD 2007 / VS.NET 2005
Hi all,
I'm getting erroneous values for GeometricExtents.MinPoint of a database resident MPolygon entity. It always defaults to 0,0,0 neverthless of MPolygon's actual location in space. On the other hand, GeometricExtents.MaxPoint returns correct results.
Please find attached sample drawing.
Regards,
Maksim Sestic
MaksimS
Re: GeometricExtents of a MPolygon
« Reply #1 on: April 21, 2007, 06:52:58 AM »
Of course, you can always convert MPolygon to Polyline and extract GeometricExtents out of a Polyline, still sometimes this may not be straightforward thing to do as you need to take in account possible multiple outer (exterior) boundaries, etc.
Regards,
Maksim Sestic
MaksimS
« Reply #2 on: April 23, 2007, 07:31:17 AM »
Yap, it's definately a bug.
djonio
« Reply #3 on: April 23, 2007, 07:58:36 AM »
Yes,
This is a known "issue". It has to do with initialization of the MPolygon.
You could try this:
       public void getboundingboxinfo(ObjectId[] objs, ref double[] box)
            DocumentLock docLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument();
            Database db = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
            try
                using (Transaction t = db.TransactionManager.StartTransaction())
                    foreach (ObjectId obj in objs)
                        Entity ent = (Entity)t.GetObject(obj, OpenMode.ForRead);
                        MPolygon mpoly = ent as MPolygon;
                        if (mpoly != null)
                            // Extents3d e = mpoly.GeometricExtents;
                            // ... does not work ... known issue with Autodesk
                            // ................ so we extract the outer vertices
                            int loops = mpoly.NumMPolygonLoops;
                            for (int i = 0; i < loops; i++)
                                MPolygonLoop mPolygonLoop = mpoly.GetMPolygonLoopAt(i);
                                // the count of 2d points
                                int verts = mPolygonLoop.Count;
                                // the count of ordinates
                                foreach (BulgeVertex bv in mPolygonLoop)
                                    Point2d a2dp = bv.Vertex;
                                    if ((a2dp.X < box[0]) || (box[0] == 0.0)) box[0] = a2dp.X;
                                    if ((a2dp.Y < box[1]) || (box[1] == 0.0)) box[1] = a2dp.Y;
                                    box[2] = 0F;
                                    if ((a2dp.X > box[3]) || (box[3] == 0.0)) box[3] = a2dp.X;
                                    if ((a2dp.Y > box[4]) || (box[4] == 0.0)) box[4] = a2dp.Y;
                                    box[5] = 0F;
                    t.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception) { }
            catch (System.Exception) { }
            finally
                docLock.Dispose();
Hi all,
Regards,
Maksim Sestic
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: April 23, 2007, 09:41:22 AM »
Welcome djonio Nice Coding
MaksimS
« Reply #5 on: April 23, 2007, 10:44:48 AM »
Thanks for the tip, I've been collecting outer boundaries for the sake of speed but that's it.
Yes,
