Author Topic: Collaboration: Draw outline  (Read 11625 times)
Guest
Re: Collaboration: Draw outline
« Reply #30 on: April 20, 2007, 01:37:54 PM »
The attached drawing has boundaries created using Keith GetBoundary LSP program (the boundaries on the left).
The boundaries on the right were created using AutoCAD's shrinkwrap command.
LE
« Reply #31 on: April 20, 2007, 01:44:48 PM »
Thank you for your time!
Here is attached the drawing, showing in white - what my command does - I noticed that using the shrinkwrap requires to draw some lines in order to make some closed areas - that are not, unless it does it automatically, not bad at all!
« Reply #32 on: April 20, 2007, 02:40:38 PM »
Tim;
Do you have a drawing sample?
Can't post the drawing sorry.  And I don't think I could come up with something as complicated so easly.
So in some words:
You are going to explode all the drawing, to have simple objects and from them generate an outline or footprint, when possible.... am I right/close?
I recall that MAP have some cleanup tools and the ability to create boundaries, they said better that the overkill (I never had the chance to used any of both).
Yes that is what I was planning on doing.  I don't have map, but I guess I could download it and try some stuff.
« Reply #33 on: April 20, 2007, 04:52:13 PM »
If you google gbpoly you still see it for sale. ???
LE
« Reply #34 on: April 20, 2007, 06:45:47 PM »
Just updated the data, now is there a note of is not available.
Thanks.
« Last Edit: April 20, 2007, 07:38:16 PM by LE »
lamarn
« Reply #35 on: January 18, 2010, 08:07:15 AM »
Where can i find the _aeclineworkshrinkwrap command?
Matt__W
  • I like my water diluted.
« Reply #36 on: January 18, 2010, 09:07:48 AM »
MEP 2008 and ARCH 2008.  Not sure if it's in C3D as well.
I'm assuming it's in the latest versions of MEP and ARCH but can't verify that.
Autodesk Expert Elite
