Author Topic: Dim setting for placing text  (Read 1341 times)
PHX cadie
« on: April 18, 2007, 08:59:55 PM »
My memory is failing:
I'm on a dwg that came from a figure that someone did and they changed a dim setting that I can not remember.
What is happening is when placing a dimension, I pick the 2 points, then the third pick is where it places the text. Then I rt clk and place the text to the "home postion". Its not dimaso, my favorite (  :lmao: ) the dims are intact, not as though exploded.
What's the dim variable to set the text to its home position?
Thanks !
Acad 2013 and XM
Krushert
  • FREE BEER Tomorrow!!
Re: Dim setting for placing text
« Reply #1 on: April 18, 2007, 09:15:53 PM »
I believe this is it.  (up to R2005) and later maybe.
DIMUPT
System Variable
Type:  Switch
Saved in:  Drawing
Initial value:  Off
Controls options for user-positioned text.
Off
 Cursor controls only the dimension line location
On
 Cursor controls both the text position and the dimension line location
dan19936
« Reply #2 on: April 18, 2007, 09:31:23 PM »
To change dimensions that are not at the home position (manually moved)
Command DIM1 > HOME > (select objects)
To control dimension styles with leader or no leader on text position, try DIMTMOVE.
Dan
PHX cadie
« Reply #3 on: April 18, 2007, 09:37:31 PM »
DIMUPT
That's the ticket, thanks!   :-)
I must be gettin old dimupt doesn't even sound familiar
Thanks to dan also, Ill try that also, just came back from dimupt
Acad 2013 and XM
adalea03
« Reply #4 on: April 19, 2007, 07:46:44 AM »
I use a litte routine to do a quick fix:
(defun c:ht ()
  (command "_dimedit" "h" "\\"))
Tony.
