Author Topic: 4. All objects shall be drawn precisely.  (Read 15167 times)
« on: June 24, 2004, 06:16:39 PM »
Obviously this is a pragmatic thing - if you have a field measurement of something, and the surveyor paced off a loose measurement (it happens, c'mon),  the drafting should reflect, but generally speaking, if an object is known to 10 feet long it should be precisely 120 units long [expletive deleted], not 119.1234!
Same goes for angular precision.
Thoughts?
Slim©
  • The Dude Abides...
« Reply #1 on: June 24, 2004, 06:42:18 PM »
Very, true and your end points of lines should meet, no gaps or overlaps.
Dent Cermak
« Reply #2 on: June 24, 2004, 06:56:28 PM »
ALL lines shoud join and "list" out at exactly the correct bearing and distance.
« Reply #3 on: June 24, 2004, 07:15:58 PM »
Quote from: Dent Cermak
ALL lines should join and "list" out at exactly the correct bearing and distance.
Agreed. Draw accurately, using objects snaps and other accuracy / drawing aids as appropriate.
ELOQUINTET
« Reply #4 on: June 25, 2004, 04:11:34 PM »
PRECISELY :!:
CADaver
« Reply #5 on: June 25, 2004, 10:44:49 PM »
is ther another way????
Slim©
« Reply #6 on: June 26, 2004, 12:26:35 AM »
Quote from: CADaver
"Ohh, just sketch that in it doesn't need to be to scale."
How many times have I heard that one.
Then they say "It's faster not drawing to scale."
So, yes there is. It's just not accurate.
« Reply #7 on: June 26, 2004, 12:50:33 AM »
Well, you know, I agree 110% (if you can do such a thing) but what really gripes me is when I receive a set of certified site plans that I must incorporate into my plans and I find out that after drawing the entire perimeter of the lot, starting at POB and continuing until persumably I am back to the POB, I find myself several feet off.....
The survey shows 247.80' N88D45'28"E and after drawing it I find it should really be 246.52' N88D44'08"E .... how can this be off by that much?
It is not possible to draw accurately without accurate information. So to that end, all objects must be drawn accurately and to scale (as close as accuracy is defined in the standard) I have worked places where .10 degrees was "close enough" but not for me.... where things were dimensioned at 1/4" precision, not me ...Oh well ... I am the rogue anyway
CADaver
« Reply #8 on: June 27, 2004, 03:36:26 PM »
Quote from: Keith
We must also be aware of the actual limitations of construction as well.  Running survey numbers out 5 or 6 decimal places serves little purpose, much like calling for a machine tolerance that is impossible to achieve.
« Reply #9 on: June 27, 2004, 04:17:08 PM »
Quote from: CADaver
Quote from: Keith
Which is why we have tolerences.... but if boundary markers are required to be within .05' of their actual location, why do I continually get measurements that are .25' off? Or did I misinterpret/misread Dent's remarks concerning where markers are required to be placed?
« Reply #10 on: June 29, 2004, 02:05:44 AM »
Please hear a friendly voice as you read this ...
Seems to me this discussion drifted into one of annotation, and while that's fine, imho I think it would be more beneficial if another thead discussed annotation issues like displayed accuracy separately.
This thread was about drawing accuracy, and as such, imho,  drawing accuracy should not be a function of presentation or annotation. In my experience as little or as much as that may be, data, be it models, or databases, tend to be used many different ways, and as such, it is best to maintain "it" in the most accurate manner possible - you an always dumb it down later. :)
Slim©
« Reply #11 on: June 29, 2004, 02:27:11 AM »
Quote from: Keith
I believe that the discussion has stayed on track, if something is not drawn correctly, the annotation will be incorrect in the Civil/Survey field. The problem Keith is refering to is one that also involves the accuracy of the surveyor's calculations, if they aren't correct the drawing will not be accurate. I guess we could start a new thread reguarding the inaccuracies of surveyor calculations if you would like, but that would be somewhere other than CAD Standards.
Dent Cermak
« Reply #12 on: June 29, 2004, 10:06:27 AM »
In response to Keith's question above; The positional accuracy required by Mississippi Survey Regulations is 0.05 feet. If you are running into erros of 0.25 feet you need to turn that surveyor in to the State Board Of Registration. Again, i would refer you to Chapter 16 of the Florida administrative Code, Chapter 61G17-6, Minimum Technical Standards. i believe that you will find that an error of 0.25' is not acceptabele by anyones standards. DUDE that's 3 friggin inches off!! You guys need a new surveyor. We have an office in Maitland.  8)
« Reply #13 on: June 29, 2004, 06:17:39 PM »
I have had them off by FEET not mere inches....I once had a legal plat description obtained from a courthouse and when I went to draw that plat from the description, it did not even produce a polygon, the boundary as recorded would make a Z shape if platted out.
and Dude, I do not hire these bozos I am relegated to use the clients surveying data... many times it is pretty sketchy
CADaver
« Reply #14 on: June 29, 2004, 06:28:56 PM »
Quote from: Keith
Somebody needs a 'nad hammered.
Quote from: Keith
Sorry to hear that, we have our own, and they really don't like re-doing it on their own time.
