I've been (ab)using, er learning, MSVS for some time and have grown accustomed to the display. Wanting to add a few commands to Sinc's quite useful Civil3D commands I tried to place his Project into my VS Projects folder. HA! I get lots of warnings on opening, namely "The file 'AutocadUtilities\C3DUtil.cs' could not be added to the project. Cannot add a link to the file C:\Documents and Settings\Master\My Documents\Visual Studio 2005\Projects\Sincpac\Sincpac\AutocadUtilities\C3DUtil.cs. This file is within the project directory tree." etc. Being about as bright as a brick in this VS stuff I cannot figure out how to edit Sinc's code in VS.
OK, no problem, I'll just download and install SharpDevelop! Great, everything goes as planned, unzip the project to the SD Projects folder and AH HA! I can open and edit without any problems. Except.......the interface is a bit different, the (excuse my ignorance in the correct terminology) known types are not highlighted, the code dosen't seem to want to auto format itself, and some other things I'm not recalling right now. Oh, and I got 2 Fatal Errors while just looking around at Sinc's code and 1 more when attempting to build it. So I'm finding it is giving me headaches looking at the code in SD.
So, can anyone give me step by step instructions on How-To either use this code in VS2005 OR get SD to appear similar to VS2005?
Thanks!
Jeff "the brick"
