Author Topic: Fun with MText  (Read 9795 times)
LE
Re: Fun with MText
« Reply #15 on: April 14, 2007, 01:55:34 PM »
Some data is not right, have a look into the following:
((-1 . <Entity name: 7efa1120>)
  (0 . "MTEXT")
  (330 . <Entity name: 7efb6cf8>)
  (5 . "DC")
  (100 . "AcDbEntity")
  (67 . 0)
  (410 . "Model")
  (8 . "ACG_ZGRADA_OZNAKA")
  (6 . "Continuous")
  (100 . "AcDbMText")
  (10 6.32855 5.85846 -1.#IND)
  (40 . 1.0)
  (41 . 0.0)
  (46 . 0.0)
  (71 . 5)
  (72 . 5)
  (1 . "P=6m\U+00B2")
  (7 . "Standard")
  (210 0.0 0.0 1.0)
  (11 1.0 0.0 0.0)
  (42 . 4.5)
  (43 . 1.0)
  (50 . 0.0)
  (73 . 1)
  (44 . 1.0))
then if it is exploded:
((-1 . <Entity name: 7efa0168>)
  (0 . "TEXT")
  (5 . "E5")
  (67 . 0)
  (410 . "Model")
  (100 . "AcDbText")
  (10 -1.#IND -1.#IND -1.#IND)
  (40 . 1.0)
  (1 . "²")
  (50 . 0.0)
  (41 . 1.0)
  (51 . 0.0)
  (7 . "Standard")
  (71 . 0)
  (72 . 0)
  (11 0.0 0.0 -1.#IND)
  (210 0.0 0.0 1.0)
  (100 . "AcDbText")
  (73 . 0))
LE
Re: Fun with MText
« Reply #16 on: April 14, 2007, 02:05:17 PM »
If I replace the -1.#IND with 0.0, then the mtext behaves normally.
Re: Fun with MText
« Reply #17 on: April 14, 2007, 10:17:45 PM »
MaksimS,
conventionally the m_ prefix is used for the names of private fields to a class .. you seem to be using them for local variable names for your functions .. is this correct ?
not that it makes any difference to the compiled code ; just the non-VB side of my brain asking .. trying to make sure I'm not missing something.
MaksimS
Re: Fun with MText
« Reply #18 on: April 16, 2007, 01:56:21 AM »
We have local agreement to use m_ prefix for any local variable and private field (private to the class anyways) :-) Not the best solution, I know, but we're practicing it for years. It seems to me that the Point3d returned by Centroid property needs some fixing. It has to do with certain PrecisionModel class governing overall geometry precision, since some geometric calculations do not perform mathematically correct within default precision model.
I'd say that Z coordinate is erroneous, this might be the source of this weird MText's behaviour.
Regards,
Maksim Sestic
MaksimS,
« Last Edit: April 16, 2007, 01:58:06 AM by MaksimS »
Glenn R
Re: Fun with MText
« Reply #19 on: April 16, 2007, 02:25:23 AM »
If you Audit that drawing, it reports the MText as being in error and fixes it. Prior to the audit, I could select the object to get the grip, but I could not move my cursor to the grip to grip it. Whenever the cursor got near the grip, the cursor would just...disappear...
MaksimS
Re: Fun with MText
« Reply #20 on: April 16, 2007, 09:40:30 AM »
Not only you can't select it via it's grip - ACAD somehow enters the entity selection state when you try to pick the grip and waits for user to select entities (at the time crosshair disappears try to move the mouse and see what happens). What puzzles me the most is Editor's behaviour.
Re: Fun with MText
« Reply #21 on: April 16, 2007, 09:45:15 AM »
Well at least you know which part of your program to fix to have it come good :-)
LE
Re: Fun with MText
« Reply #23 on: April 19, 2007, 08:29:16 AM »
How'd you go Maksim ??
MaksimS
Re: Fun with MText
« Reply #24 on: April 23, 2007, 07:43:09 AM »
Bah, the tricky part (Z axis returning #IND) was hidden in set of classes performing coordinate conversion. I received fixed code from my coworkers but I didnt' receive requested debug log to find out what actually caused the coordinate misinterpretation :-) This one will remain mistery for the time being, I need some extra couple of hours to check this out myself (somehow I'm always missing couple of hours daily...) :-)
