If I may make a suggestion.
In DataCAD to get certain items to show up behind others, it is dependent on the layer order. Stuff located on layers at the top of the menu are rendered first and everything after that will then start displaying on top. This is most helpful to know when working with bitmaps on a drawing.
It is something you can check with Microstation, but I have a feeling in this case it is DataCAD specific.
