Author Topic: Getting a PlotConfig by name  (Read 3772 times)
« on: April 11, 2007, 01:51:29 PM »
How can I get a PlotConfig without setting it current?  When looking at the constructions for the PlotConfig class in the reflector, it is only asking for no arguements, or (IntPtr, Boolean).  I'm not sure what the 'IntPtr' is supposed to be.  I read that it is an integer that is system specific, so I tried this
IntPtr tempIntPtr = new IntPtr(5);
PlotConfig pc = new PlotConfig (tempIntPtr, false);
and got this as an error
c:\MyCustom\CSharp\AcadClass\Test\MyPlotv03.cs(651,20): error CS0122: 'Autodesk.AutoCAD.PlottingServices.PlotConfig.PlotConfig(System.IntPtr, bool)' is inaccessible due to its protection level
and when I tried it with no arguements, I got this error
c:\MyCustom\CSharp\AcadClass\Test\MyPlotv03.cs(650,20): error CS1501: No overload for method 'PlotConfig' takes '0' arguments
Is there anyway to get the PlotConfig without setting it current?  I'm going this route because I can't seem to get my batch plot routine to work, so I figured I would plot to file (since this worked), then send the file to the right plotter/printer, but I need the port of the plotter/printer, and the only way I see to get it is by the PlotConfig.
Any/all help/ideas/comments welcomed.  Thanks in advance.
Chuck Gabriel
Re: Getting a PlotConfig by name
« Reply #1 on: April 11, 2007, 09:13:45 PM »
I can't see a way to do it without setting the PlotConfig current at least temporarily, something like this:
PlotConfig pcTmp = PlotConfigManager.CurrentConfig;
PlotConfig pc = PlotConfigManager.SetCurrentConfig("YourConfigName");
PlotConfigManager.SetCurrentConfig(pcTmp.DeviceName);
« Reply #2 on: April 12, 2007, 11:29:06 AM »
Thanks Chuck.  That is what I was afraid of.
