Author Topic: Counting Blocks  (Read 19770 times)
ML
Re: Counting Blocks
« Reply #30 on: April 11, 2007, 01:49:18 PM »
Luke
Give The VBA a try
I will help you if you need it
Luke
Re: Counting Blocks
« Reply #31 on: April 11, 2007, 02:00:27 PM »
The diesel / lisp that Mark & Crank supplied work great and aside from understanding the exact code to type I already knew where and how to do all the other things they were describing.
I'm always looking to learn new things but I've never done anything with VBA so I'll need you to hold my hand, step by step throught this.
What is first?
ML
Re: Counting Blocks
« Reply #32 on: April 11, 2007, 02:12:32 PM »
OK, Go to Tools-Macro-VBA Manager-Click New (For New VBa Project)
Click the button that says Visual Basic Editor
Righ Click on your new project, by default it will be called ACADProject
Click insert Module, then paste the code in the code that I gave you.
By default the new module puts in Sub and End Sub, so make sure you delete it because my code already has it.
Save it
Then you can go back to Tools-Macro-Macros and run it from there
I hope this helps?
Let me know if you have any problem   :-)
Re: Counting Blocks
« Reply #33 on: April 11, 2007, 02:16:03 PM »
A word of cautions....
When you use 'setenv' it will be available to all drawings, and in future sessions.  It can be good or bad, so just and FYI.
Continue....  :-)
Luke
Re: Counting Blocks
« Reply #34 on: April 11, 2007, 02:29:46 PM »
OK so I did all that.
When I run it it pops a little windows box up on my screen that says "There are 71 blocks in this drawing and" OK.  When I click OK it then says "886 Block references" OK.  When I click OK there it seems to be done.
Is this working how you planned?
Re: Counting Blocks
« Reply #35 on: April 11, 2007, 02:56:39 PM »
Just to follow-up, the values are stored in the registry as seen below.
CottageCGirl
Re: Counting Blocks
« Reply #36 on: April 11, 2007, 03:05:48 PM »
If you have Express Tools (I may be getting off the wrong train here) you could use "bcount". Try typing it in the command line.
NiiiiiiiCE one thanks, did not know about that...it is FABULOUS for systems furniture..........you get the good fairy points for the day!!! :-)
won't use it for ordering , but for general budgeting this will be awesome....
Luke
Re: Counting Blocks
« Reply #37 on: April 11, 2007, 03:18:52 PM »
Well everything Mark Thomas & Crank gave me previously works great and does just what I want.  I'm not concerned with the Model Paper space issues.  I'm only working in 1.  Additionally I have no interest in messing with or going into and extracting info from my registry.
Thanks again all. I've done what I need to do.
Re: Counting Blocks
« Reply #38 on: April 11, 2007, 03:43:13 PM »
<cut> image </cut>
Thanks for pointing out where it went.  I tried looking, but looked in the wrong place to start with.
ML
Re: Counting Blocks
« Reply #39 on: April 11, 2007, 03:48:17 PM »
Yep,
That was it Luke.
I'm sorry if it isn't what you are looking for but that is how you insert VBA code and run a macro.
You can also launch the macro from a toolbar button, a pulldown menu etc.
If it is a routine you will use frequently, like LISP, you can put it in Startup Suite
Luke
Re: Counting Blocks
« Reply #40 on: April 11, 2007, 03:49:43 PM »
Thanks Mark,
Good to know, just doesn't give me the results I was looking for.
Regards
Luke
ML
Re: Counting Blocks
« Reply #41 on: April 11, 2007, 04:07:04 PM »
Sure man, no problem
Now, it is VBA forever, right?   :-D
Remember VBA crosses over to MS Products, LISP is limited to ACAD, though LISP still has a place for sure.
Krushert
  • FREE BEER Tomorrow!!
Re: Counting Blocks
« Reply #42 on: April 11, 2007, 04:23:50 PM »
Just for no other reason but to ask why.
Why are you accessing and storing data to the registry?
Luke
Re: Counting Blocks
« Reply #43 on: May 02, 2007, 09:30:35 AM »
Mark Thomas,
Thanks again for your previous help on this post.
I have another question now...
What do I need to change to get it to result a zero if the qty truely is zero.  What is happening to me is when the block is not in the drawing the lisp recognizes nothing and does not update the qty.
Re: Counting Blocks
« Reply #44 on: May 02, 2007, 09:51:46 AM »
Mark Thomas,
That shouldn't be to hard to do, give me a little while to work it out.
