Author Topic: Multy-tab on the PalletSet.  (Read 3054 times)
gilseorin
« on: April 08, 2007, 07:56:46 AM »
Hi,all.
I tried to create multy-tab on my PalletSet, but couldn't find the way.
Is it impossible? Only PaletteSetStyles.ShowTabForSingle is the all?
public void Initialize()
 if (ps == null) {
   ps = new Autodesk.AutoCAD.Windows.PaletteSet("GilSeoRin");
   Modelessform myForm = new Modelessform();
   ps.Add("GilSeoRin", myForm);
   ps.Style = (Autodesk.AutoCAD.Windows.PaletteSetStyles.ShowAutoHideButton +
               Autodesk.AutoCAD.Windows.PaletteSetStyles.ShowTabForSingle);
   ps.MinimumSize = new System.Drawing.Size(300, 300);
   ps.Visible = true;
« Last Edit: April 08, 2007, 08:09:03 AM by gilseorin »
gilseorin
Re: Multy-tab on the PalletSet.
« Reply #1 on: April 08, 2007, 09:05:48 PM »
Finally I found the way.
ps.Add("YourPallet", yourForm);
Thanks,anyway.
« Reply #2 on: April 08, 2007, 09:06:09 PM »
I missed the original post,
.. but It wasn't too difficult, was it ?
« Last Edit: April 08, 2007, 09:57:25 PM by Kerry Brown »
gilseorin
« Reply #3 on: April 08, 2007, 10:07:31 PM »
Yes, it was very very difficult.
It took several months to solve.
But compare with ObjectArx programming, It's a piece of cake.
MickD
« Reply #4 on: April 09, 2007, 06:23:40 PM »
A quick search of the board for "palette" would have made your work a bit easier also, give it a go, there's heaps to look through ;)
« Last Edit: April 09, 2007, 06:25:35 PM by MickD »
- John Carmack
- J.R.R. Tolkien
