Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
VLX created in 2007 will not run in other versions
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: VLX created in 2007 will not run in other versions (Read 1830 times)
crowellsr
Guest
on:
April 03, 2007, 09:13:52 PM »
I created a VLX using AutoCAD 2007 and can not get it to run in other versions. The LSP version runs fine in other versions just not the vlx. Am I doing something wrong or is this a problem with 2007?
Steve
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: VLX created in 2007 will not run in other versions
Reply #1 on:
April 03, 2007, 09:57:51 PM »
I'd have to see the code Steve.
Personally I've not tried to run 2007 compiled in earlier versions, I build/compile the VLX in the version it's intended for ... that's just my belt and braces philosophy kicking in though.
Logged
ElpanovEvgeniy
Water Moccasin
Moscow (Russia)
WWW
Reply #2 on:
April 04, 2007, 12:18:07 AM »
I constantly use the compiler VLX of 2007 version.
My programs are used on computers with acad 2004, 2006, 2007, 2008...
All works!
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
