Author Topic: Xref and UCS  (Read 5982 times)
cadpro
Xref and UCS
« on: April 02, 2007, 02:24:12 AM »
I'm new to .NET. I had been trying to create a dll to change the UCS and Layer when the user types XREF in the command line. I don't know how to go about it. I just tried the code below, but it is not working. Can anybody help me?
Imports System
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports acadApp = Autodesk.AutoCAD.ApplicationServices.Application
Public Class UCS
    Public Sub XrefCommand()
        If acadApp.DocumentManager.MdiActiveDocument.CommandInProgress = "XREF" Then
            MsgBox("Done!")
        End If
    End Sub
End Class
Re: Xref and UCS
« Reply #1 on: April 02, 2007, 03:09:22 AM »
I was going to say that you could cover all the bases and ask at AUGI as well ... but I see that you have.   :-D
Have you done the Labs ?
Can you change the UCS ?
Can you change the Layer ?
cadpro
Re: Xref and UCS
« Reply #2 on: April 02, 2007, 03:46:31 AM »
I have done some labs, but didn't try to change the UCS and Layers. Thought I will look into it after I've done with trapping the Command Event.  :-(
Re: Xref and UCS
« Reply #3 on: April 02, 2007, 05:06:23 AM »
Sorry, I thought my hint was pretty good  :|
If you do a couple more, you may find your answers.
cadpro
Re: Xref and UCS
« Reply #4 on: April 02, 2007, 05:38:06 AM »
Please have a look at this code. It works, but only with the document that was active when the dll was loaded. What could be wrong?
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Public Class UCS
    Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
    Private Doc As Document
    Public Sub New()
        Doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        AddHandler Doc.CommandWillStart, AddressOf cmdWillStart
    End Sub
    Public Shared Sub cmdWillStart(ByVal o As Object, ByVal e As CommandEventArgs)
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Try
            If e.GlobalCommandName = "XREF" Then
                MsgBox(e.GlobalCommandName)
            End If
        Catch ex As Exception
            ed.WriteMessage("Error in cmdWillStart: " + ex.Message)
        End Try
    End Sub
Re: Xref and UCS
« Reply #5 on: April 02, 2007, 06:40:06 AM »
No.
Tony seems to be giving you good advice ... I'll leave you with him.
Glenn R
Re: Xref and UCS
« Reply #6 on: April 02, 2007, 08:35:00 AM »
Nicely put Kerry.
On a side note, Tony seems to be remarkable restrained with this one - I wouldn't be.
It's Alive!
  • Retired
  • AKA Daniel
Re: Xref and UCS
« Reply #7 on: April 02, 2007, 10:01:13 AM »
<removed silly comment> Doh!
« Last Edit: April 02, 2007, 11:15:54 AM by Danielm103 »
TonyT
Re: Xref and UCS
« Reply #8 on: April 04, 2007, 02:22:54 PM »
Nicely put Kerry.
Well, I hope he can learn the difference
between the assignment and equal operators:
cadpro
Re: Xref and UCS
« Reply #9 on: April 10, 2007, 03:14:24 AM »
Please help! :-(
cadpro
Re: Xref and UCS
« Reply #10 on: April 11, 2007, 02:20:17 AM »
Please can anyone help me to convert this code to vb.net?
Option Explicit
Dim CurUCS As AcadUCS
Dim CurLayer As AcadLayer
Dim UCSs As Object
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
If CommandName = "XREF" Or CommandName = "XATTACH" Then
Set CurUCS = ThisDrawing.ActiveUCS
Set CurLayer = ThisDrawing.ActiveLayer
Call ShowWCS
ThisDrawing.Layers("0").Freeze = False
ThisDrawing.Layers("0").LayerOn = True
ThisDrawing.ActiveLayer = ThisDrawing.Layers("0")
End If
End Sub
Sub ShowWCS()
' Display WCS
Dim wcs As Object
Dim dorigin(0 To 2) As Double
Dim dxAxisPnt(0 To 2) As Double
Dim dyAxisPnt(0 To 2) As Double
dorigin(0) = 0#
dorigin(1) = 0#
dorigin(2) = 0#
dxAxisPnt(0) = 1#
dxAxisPnt(1) = 0#
dxAxisPnt(2) = 0#
dyAxisPnt(0) = 0#
dyAxisPnt(1) = 1#
dyAxisPnt(2) = 0#
Set wcs = ThisDrawing.UserCoordinateSystems.Add(dorigin, dxAxisPnt, dyAxisPnt, "WORLD")
' Display WCS.
ThisDrawing.ActiveUCS = wcs
End Sub
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
ThisDrawing.ActiveUCS = CurUCS
ThisDrawing.ActiveLayer = CurLayer
ThisDrawing.UserCoordinateSystems.Item("World").Delete
End If
End Sub
Bryco
Re: Xref and UCS
« Reply #11 on: April 11, 2007, 09:43:59 AM »
Don't you get a bit dizzy posting everywhere,
"Help,Help",post post ,"Help,help" post post.
Glenn R
Re: Xref and UCS
« Reply #12 on: April 11, 2007, 05:07:00 PM »
 :lmao:
cadpro
Re: Xref and UCS
« Reply #13 on: April 12, 2007, 01:05:14 AM »
 :-( coz it's urgent!
Glenn R
Re: Xref and UCS
« Reply #14 on: April 12, 2007, 01:18:32 AM »
Then hire a professional.
