Look at attach file, I got trouble to find length from part of ellipse,then look again in this below code.
If you check by list function,it can displayed,but I got teribble to find in lisp, have you idea to find it.
This object search by list function
Command: _list
Select objects: 1 found
Select objects:
ELLIPSE Layer: "0"
Space: Model space
Color: 2 (yellow) Linetype: "BYLAYER"
Handle = CE
Length: 12.1106
Center: X = 0.0000 , Y = 0.0000 , Z = 0.0000
Major Axis: X = -10.0000 , Y = 0.0000 , Z = 0.0000
Minor Axis: X = 0.0000 , Y = -5.0000 , Z = 0.0000
Start Point: X = 10.0000 , Y = 0.0000 , Z = 0.0000
End Point: X = 0.0000 , Y = 5.0000 , Z = 0.0000
Start Angle: 180
End Angle: 270
Radius Ratio: 0.5000
it get with vlisp
(setq ss (car (entsel "\nSelect an ellipse object")))
(setq sse (entget ss))
((-1 . <Entity name: 7efb30f0>)
(0 . "ELLIPSE")
(330 . <Entity name: 7ef60cf8>)
(5 . "CE")
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "0")
(62 . 2)
(100 . "AcDbEllipse")
(10 0.0 0.0 0.0)
(11 -10.0 0.0 0.0)
(210 0.0 0.0 1.0)
(40 . 0.5)
(41 . 3.14159)
(42 . 4.71239))
_$
here I try with activeX
(setq vevo (vlax-ename->vla-object ss))
(vlax-dump-object vevo)
; IAcadEllipse: AutoCAD Ellipse Interface
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 00b9b5e4>
; Area (RO) = 14.2699
; Center = (0.0 0.0 0.0)
; Document (RO) = #<VLA-OBJECT IAcadDocument 010f3d20>
; EndAngle = 4.71239
; EndParameter = 4.71239
; EndPoint (RO) = (1.83691e-015 5.0 0.0)
; Handle (RO) = "CE"
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 06492014>
; Layer = "0"
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; MajorAxis = (-10.0 0.0 0.0)
; MajorRadius = 10.0
; MinorAxis (RO) = (0.0 -5.0 0.0)
; MinorRadius = 5.0
; Normal = (0.0 0.0 1.0)
; ObjectID (RO) = 2130391280
; ObjectName (RO) = "AcDbEllipse"
; OwnerID (RO) = 2130054392
; PlotStyleName = "Color_2"
; RadiusRatio = 0.5
; StartAngle = 3.14159
; StartParameter = 3.14159
; StartPoint (RO) = (10.0 -6.12303e-016 0.0)
; TrueColor = #<VLA-OBJECT IAcadAcCmColor 064966d0>
; Visible = -1
T
_$
