Author Topic: Where my xxx  (Read 3262 times)
Adesu
Where my xxx
« on: March 22, 2007, 10:08:28 PM »
(setq xx "xxx_x")                ; "xxx_x"
(vl-string-right-trim "_x" xx)   ; ""    >>>????
Re: Where my xxx
« Reply #1 on: March 22, 2007, 10:12:08 PM »
My dog ate it!
dan19936
Re: Where my xxx
« Reply #2 on: March 22, 2007, 10:18:57 PM »
vl-string-right-trim will remove each individual character in the list provided, not the string pattern, meaning it removes each "_" and each "x" it finds, not the pattern "_x"
Re: Where my xxx
« Reply #3 on: March 22, 2007, 10:19:34 PM »
yes, it happens to be recursive ..
(setq xx "a1212121212")
(vl-string-right-trim "12" xx)
;;-> "a"
(setq xx "a12                    ")
(vl-string-right-trim " " xx)
;;-> "a12"
(setq xx "a1212121212p")
(vl-string-right-trim "12a" xx)
;;-> "a1212121212p"
(vl-string-right-trim "12ap" xx)
(vl-string-right-trim "12324555a453" xx)
Re: Where my xxx
« Reply #4 on: March 22, 2007, 10:42:04 PM »
you could try something like this ..
(SETQ
   string    "xxx_x"
   pattern   "_x"
   newString (IF (SETQ index (VL-STRING-SEARCH pattern string 0))
                (VL-STRING-SUBST "" pattern string index)
Adesu
Re: Where my xxx
« Reply #5 on: March 22, 2007, 11:05:25 PM »
Great info,this would memorized in my brain,thanks.
Adesu
Re: Where my xxx
« Reply #6 on: March 22, 2007, 11:09:53 PM »
Good solution,thanks for your help.
(SETQ
   string    "xxx_x"
   pattern   "_x"
Re: Where my xxx
« Reply #7 on: March 22, 2007, 11:24:25 PM »
be aware that this will replace the first match it finds ...
a better way may be to :
count the characters in the pattern
count the characters in the string
subtract patternCount from StringCount
use that value as the last parameter in (VL-STRING-SEARCH pattern string < Count Difference > )
