I've got a DB that I'm trying to make work (maybe it's possible, maybe it's not). It's a key note call out (leader attached to a circle with a number inside). The circle can be moved about the end point of the leader. The problem arises when you rotate the circle past 90 or 270, at which point the attribute in the circle becomes "unreadable". In other words, it's upside down. Is it possible to keep the attribute rotation at ZERO degrees? If so, how? I've attached the DB that I've been dabbling with (it ACAD 2007).
