Author Topic: Undefine/Redefine Xref  (Read 4779 times)
cadpro
« on: March 22, 2007, 06:00:58 AM »
I would like to create a VBA module to undefine Xref command, then create a new command called 'xref', then redefine it. Is this possible? Please help.
Glenn R
Re: Undefine/Redefine Xref
« Reply #1 on: March 22, 2007, 09:05:07 AM »
No.
cadpro
« Reply #2 on: March 27, 2007, 01:25:58 AM »
Redefine...in fact is not necessary...when a user types xref in the command line, immedietly the ActiveUCS should go to 'World', as well as the ActiveLayer should go to '0'. After that the Xref dialog box should pop up. After inserting the drawing through the xref dialog box, the layer and ucs should go back to the original as it was earlier. Can this be accomplished?
Dave R
« Reply #3 on: March 27, 2007, 08:15:43 AM »
Yes, you can use the BeginCommand event of the active document to do this.
Bryco
« Reply #4 on: March 27, 2007, 10:12:00 AM »
Don't forget XATTACH as well.
cadpro
« Reply #5 on: March 28, 2007, 12:32:13 AM »
This is the code I wrote. But unfortunately, it's not working.
Please help.
Option Explicit
Dim CurUCS As AcadUCS
Dim CurLayer As AcadLayer
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
If CommandName = "XREF" Or CommandName = "XATTACH" Then
Set CurUCS = ThisDrawing.ActiveUCS
Set CurLayer = ThisDrawing.ActiveLayer
SendKeys "{Esc}"
ThisDrawing.SendCommand "ucs" & vbCr & "world" & vbCr
ThisDrawing.Layers("0").Freeze = False
ThisDrawing.Layers("0").LayerOn = True
ThisDrawing.ActiveLayer = ThisDrawing.Layers("0")
End If
End Sub
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
ThisDrawing.ActiveUCS = CurUCS
ThisDrawing.ActiveLayer = CurLayer
End If
End Sub
Dave R
« Reply #6 on: March 28, 2007, 08:15:58 AM »
I don't think you're going to be able to effectively use the sendkeys function while you are beginning another command. You may want to take a look at programmatically setting your UCS rather than using the sendkeys function.
Please help.
Option Explicit
SendKeys "{Esc}"
End If
End Sub
End If
End Sub
Bryco
« Reply #7 on: March 28, 2007, 10:24:27 AM »
This appears to work.
Sub owcs()
    Dim zero(2) As Double
    Dim Xaxis(2) As Double
    Dim Yaxis(2) As Double
    Dim strNm As String, sUcs As String
    Dim oUcs As AcadUCS
    If ThisDrawing.GetVariable("WORLDUCS") = 1 Then
        Exit Sub
    Else
        sUcs = ThisDrawing.GetVariable("UCSNAME")
        'Debug.Print sUcs
        Xaxis(0) = 1: Yaxis(1) = 1
        Set oUcs = ThisDrawing.UserCoordinateSystems.Add(zero, Xaxis, Yaxis, "World")
        ThisDrawing.ActiveUCS = oUcs
    End If
End Sub
cadpro
« Reply #8 on: March 28, 2007, 11:57:56 PM »
I duplicated WCS and it all works fine. But one problem. If the user clicks on the Xref dialog box's Cancel button, the old UCS and Layer are not restored as it doesn't execute the EndCommand Event. I have given the code to restore the old UCS and Layer in the EndCommand event. Is there a workaround?
« Reply #9 on: March 29, 2007, 12:26:52 AM »
Something that has worked for me in the past, is to set a configuration variable in the begincommand event, then clear it in the end command event ... filtering of course for the proper command names ... now in the begin command event, if the variable is already set, then clear it and reset the previous settings saved in the last firing of the begincommand event.
The flow would be something like this:
[Begin Command]
<check config setting>
if settings = true
   <reset drawing vars>
   <clear config setting>
<verify xref call>
<set config settings>
<save current settings>
<change drawing vars>
xref command runs
[End Command]
<verify xref call>
This scenario would reset the previous settings that didn't get reset when xref was cancelled, immediately upon running another command .. beware however, you would also need to verify the settings using the Begin Lisp event too in order to capture most scenarios.
cadpro
« Reply #10 on: April 01, 2007, 12:35:03 AM »
Keith,
I'm sorry I didn't understand the workaround you explained. I will give the code that I have done. Hope you will do the changes in the code, and that makes me understand better.
Option Explicit
Dim UCSs As Object
    Call ShowWCS
End If
End Sub
Sub ShowWCS()
'   Display WCS
    Dim wcs As Object
    Dim dorigin(0 To 2) As Double
    Dim dxAxisPnt(0 To 2) As Double
    Dim dyAxisPnt(0 To 2) As Double
    dorigin(0) = 0#
    dorigin(1) = 0#
    dorigin(2) = 0#
    dxAxisPnt(0) = 1#
    dxAxisPnt(1) = 0#
    dxAxisPnt(2) = 0#
    dyAxisPnt(0) = 0#
    dyAxisPnt(1) = 1#
    dyAxisPnt(2) = 0#
    Set wcs = ThisDrawing.UserCoordinateSystems.Add(dorigin, dxAxisPnt, dyAxisPnt, "WORLD")
'    Display WCS.
    ThisDrawing.ActiveUCS = wcs
End Sub
    ThisDrawing.UserCoordinateSystems.Item("World").Delete
End If
End Sub
If I am not wrong, I understood that the execution control never enters the EndCommand Event if the Xref dialog box is cancelled. Please help.
Bryco
« Reply #11 on: April 01, 2007, 01:38:47 AM »
dim bActive  as boolean
set this true in your startcommand
set it false in your endcommand
if it is true when you start the startcommand then the endcommand was never activated (an escape happened). Now you reset the layers
cadpro
« Reply #12 on: April 02, 2007, 01:51:08 AM »
Bryco,
I did what you said in the previous post, but didn't work. In the third step, you wrote, If true in StartCommand, then EndCommand never activated. So my question is, if EndCommand never activated, then the boolean is true, which is set in startcommand. so the snippet that is needed will not run.
Bryco
« Reply #13 on: April 02, 2007, 10:48:47 PM »
Watch the layer manager as you use the Line command ,escape yadayada
Option Explicit
Private Curlayer As AcadLayer
Private bActive As Boolean
    If bActive Then
        ThisDrawing.ActiveLayer = Curlayer
    End If
    If CommandName = "LINE" Then
        Set Curlayer = ThisDrawing.ActiveLayer
        bActive = True
    End If
End Sub
        bActive = False
    End If
End Sub
cadpro
« Reply #14 on: April 12, 2007, 01:18:29 AM »
No! Didn't work.
