Author Topic: Layer Help  (Read 2449 times)
hudster
Layer Help
« on: June 21, 2004, 11:05:22 AM »
How do i save the layer states, prior to thawing all layers, using a lisp?
I'm trying to write a lisp to create all our standard layers, but if one is already made and frozen, the lisp falls down, so I want to save the states, thaw everything add the layers and then return the layers to their previous states.
thanks in advance for any help.
Jeff_M
  • C3D user & customizer
Layer Help
« Reply #1 on: June 21, 2004, 11:19:13 AM »
I think it would be easier to add a check for the layers' existence and skip it if it is.
Jeff
Layer Help
« Reply #2 on: June 21, 2004, 11:54:21 AM »
I think Jeff's approach is a good one.
You could thaw that the layer revise it to company standards then freeze it back.
It might be easer to suggest a fix if you posted the code or just that section
of code.
I might approach it like this:
pseudo code
setq locked nil  frozen nil
if (layer locked) -- setq locked T
  Unlock layer
if (layer frozen) -- setq frozen T
  Thaw layer
Change layer as needed
if locked --> lock layer
if frozen --> freeze layer
Layer Help
« Reply #3 on: June 21, 2004, 01:14:33 PM »
yep agreed.
Hudster, i, Mark & Daron have writen several rotines you might be intrested in. I think mark had a Layer state tester, Daron had a Frozen layer collector and i had a ...well i prolly did something stupid like a "tblsearch" and added a few worthless lines in there to make it look fancy :P , but i would do some searching around and see what you come up with.
