Author Topic: Getting started in VB.NET  (Read 11140 times)
DaveW
« on: March 19, 2007, 06:27:47 PM »
I have been looking at the labs for 2 days and have a few things working, but I must say the lack of practical examples in the ACAD help is really making this difficult. I am not a programmer by trade and there is still a whole world in VB6 I still do not understand. I have been able to code quite a bit by using other source code as an example and modifying it as needed.
After an hour or so I finally had it working in design time by loading the dll in the bin folder and setting the 2 dlls res in the ACAD dir to false. About an hour or so later I had the active document. After that it has been a stand still. I have tried a bunch of example code snippets and can never seem to get where I want.
In vb6 if I wanted to parse through every entity in modelspace I would:
Dim ent as acadentity
Dim thisdrawing as acaddocument
Set thsidrawing as acadactivedocument
for each ent in thissdrawing.modlespace
If ent.objectname = "AcDb3dSolid then
msgbox "I have a solid"
next
In vb.net I have gotten modelspace though the db, blah blah, from example code, but how to iterate through and look for what I want, I have no idea. I have even passed out the ids of the objects selected to a message box, but still cannot find a objectfromobjectid or objectfromhandleid method.
This is just one of about100 typical things that I would expect to have available in the help file.
Instead, it points you to the password protected ADN site of which I refuse to enroll in due to the nature of the licence agreement. The cost is not an issue at all.
Is anyone here game for creating a library of functions and methods for public use?
I am thinking about taking a day or two and creating 50 or so typical VB6 pieces of code that do things like set an object color, layer, linetype, etc., add layers, get the coords of pline, work with multiple documents and on and on and then sending it off to a programming company, each as its own project not to load down too much in each area, and have them convert it to vb.net.
What do you guys think?
sinc
Re: Getting started in VB.NET
« Reply #1 on: March 19, 2007, 06:45:34 PM »
Have you looked at the Transaction class yet?  Database access in .NET is basically controlled there.
I've mostly been working in C#.NET so far, and with Civil-3D, but you can try checking out what I've done here.  VB.NET and C#.NET are close enough that just looking at this code might give you lots of ideas, even if you don't have Civil-3D and can't actually run any of my code.
« Reply #2 on: March 19, 2007, 06:50:58 PM »
Here is what was posted by Kerry to help me out.  It's C#, but I think it can help you.
// Posted by Kerry Brown
[CommandMethod("PrintMSpacev02")]
public static void MyPrintMspace_1()
            Database db = HostApplicationServices.WorkingDatabase;
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)(trans.GetObject(db.BlockTableId, OpenMode.ForRead));
                foreach (ObjectId ObjId in
                    (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead))
                    Entity Ent = (Entity)trans.GetObject(ObjId, OpenMode.ForRead, true);
                    ed.WriteMessage("\n  Layer: " + Ent.Layer);
« Reply #3 on: March 19, 2007, 08:06:24 PM »
This may be indicative ..
[CommandMethod("test103")]
static public void test()
            ed.WriteMessage(string.Format(
                "\n  Layer: {0} \tObjectType: {1} \tHandle: {2}",
                 Ent.Layer,
                 Ent.GetType().Name,
                 Ent.Handle  ));
added:
and the piccy for example output ..
« Last Edit: March 19, 2007, 08:36:10 PM by Kerry Brown »
Fatty
« Reply #4 on: March 19, 2007, 08:15:13 PM »
I think so and thanks to KWB :)
Here is VB.NET version translated from
example above
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.DatabaseServices
Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
Namespace Properties
    Public Class EntProps
        <CommandMethod("ShowLays", CommandFlags.Modal Or CommandFlags.Session)> _
        Public Shared Sub PrintLayers()
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim ed As Editor = acApp.DocumentManager.MdiActiveDocument.Editor
            Using trans As Transaction = db.TransactionManager.StartTransaction()
                Dim bt As BlockTable = CType(trans.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                Dim btr As BlockTableRecord = (CType(trans.GetObject(db.CurrentSpaceId, OpenMode.ForRead), BlockTableRecord))
                For Each ObjId As ObjectId In btr
                    Dim Ent As Entity = CType(trans.GetObject(ObjId, OpenMode.ForRead, True), Entity)
                    ed.WriteMessage(vbCrLf & "   Layer: " & Ent.Layer)
                Next
            End Using
        End Sub
    End Class
End Namespace
~'J'~
« Reply #5 on: March 19, 2007, 08:25:46 PM »
and from the more explicit example
Public Class kdubTest103
    ' TODO: Add constructor logic here
    Public Sub New()
    End Sub
    <CommandMethod("test103")> _
    Public Shared Sub test()
        Dim ed As Editor = AcadApp.DocumentManager.MdiActiveDocument.Editor
            Dim bt As BlockTable = DirectCast((trans.GetObject(db.BlockTableId, OpenMode.ForRead)), BlockTable)
            For Each ObjId As ObjectId In DirectCast(trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead), BlockTableRecord)
                Dim Ent As Entity = DirectCast(trans.GetObject(ObjId, OpenMode.ForRead, True), Entity)
                ed.WriteMessage(String.Format("" & Chr(10) & "  Layer: {0} " & Chr(9) & "ObjectType: {1} " & Chr(9) & "Handle: {2}", Ent.Layer, Ent.[GetType]().Name, Ent.Handle))
            Next
        End Using
    End Sub
End Class
added:
I get the burps when I use VB. This was translated using SharpDevelop 2.1 .. There are a few things that are not conventional to ACAD .. DirectCast for example
perhaps someone should tart-up the code.
« Last Edit: March 19, 2007, 08:39:55 PM by Kerry Brown »
Glenn R
« Reply #6 on: March 19, 2007, 08:34:35 PM »
Kerry - VB...shame on you  :evil:
« Reply #7 on: March 19, 2007, 08:37:42 PM »
Sorry Glenn
I'm just a masochist I guess ..
[*slinks away*]
Fatty
« Reply #8 on: March 19, 2007, 08:46:19 PM »
Here is another example from masochist too :)
Select then rotate entity
Imports System
Imports System.Collections
Imports graph = Autodesk.AutoCAD.GraphicsInterface
Public Class EntityRot
        <CommandMethod("ROE", CommandFlags.Modal Or
        Public Sub RotEnt()
acApp.DocumentManager.MdiActiveDocument.Database
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Try
                '// select object
                Dim selOpts As New PromptSelectionOptions()
                Dim res As PromptSelectionResult
                selOpts.SingleOnly = True
                selOpts.MessageForAdding = "    Select an entity"
                res = ed.GetSelection(selOpts)
                If res.Status <> PromptStatus.OK Then Return
                Dim id As ObjectId = res.Value.GetObjectIds(0)
                Dim ent As Entity = tr.GetObject(id, OpenMode.ForWrite, False)
                '// get point
                Dim orig As Point3d
                Dim ptRes As PromptPointResult
                ptRes = ed.GetPoint("   Specify base point")
                If ptRes.Status <> PromptStatus.OK Then Return
                orig = ptRes.Value
                '// get angle
                Dim ang As Double
                Dim angOPts As PromptAngleOptions = New PromptAngleOptions("
Specify rotation angle or pick a second point: ")
                '// add another options to prompt
                angOPts.AllowNone = False
                angOPts.AllowZero = False
                angOPts.UseBasePoint = True
                angOPts.BasePoint = orig
                '// get result
                Dim angRes As PromptDoubleResult = ed.GetAngle(angOPts)
                If angRes.Status <> PromptStatus.OK Then Return
                ang = angRes.Value
                '// rotate entity by using transformation matrix
                Dim v3d As Vector3d =
ed.CurrentUserCoordinateSystem.CoordinateSystem3d.Zaxis
                Dim m3d As Matrix3d = Matrix3d.Rotation(ang, v3d, orig)
                ent.TransformBy(m3d)
                tr.Commit()
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                tr.Abort()
                MsgBox(ex.Message)
            Finally
                tr.Dispose()
            End Try
        End Sub
    End Class
~'J'~
Paul Richardson
« Reply #9 on: March 19, 2007, 11:18:54 PM »
Sample to iterate a SymbolTable. Thanks to T.T. for the original idea - although I added the SymbolTableEnumerator. It's in c++ but just ignore all the funny symbols and you have c# - then add a few more funny symbols and you have VB...~) : Update - removed 'doc' from 'HasName' arguments in Tests...oops)
static void
Tests()
Document ^ doc = GetActiveDoc();
Database ^ db = doc->Database;
Editor ^ ed = doc->Editor;
String ^ recordName = "foo";
ed->WriteMessage
(HasName(db->BlockTableId, recordName).ToString() + "\n");
ed->WriteMessage
(HasName(db->LayerTableId, recordName).ToString() + "\n");
static bool
HasName(ObjectId ^ symbolTableId, String ^ recName)
SymbolTableRecord ^ str;
Transaction ^ tr =
db->TransactionManager->StartTransaction();
try
SymbolTable ^ st =
(SymbolTable^)tr->GetObject(*symbolTableId, OpenMode::ForRead);
SymbolTableEnumerator ^ ste = st->GetEnumerator();
while (ste->MoveNext())
str = (SymbolTableRecord^)ste->Current.GetObject(OpenMode::ForRead);
if (str->Name == recName)
return true;
finally
delete tr;
return false;
static Document ^
GetActiveDoc()
Document ^ doc =
Application::DocumentManager->MdiActiveDocument;
return doc;
EDIT: Tony Tanzillo recommends against using SymbolTableEnumerator as I have here. Use For Each instead! Teach me to modify his code...:)
« Last Edit: June 13, 2007, 09:57:46 AM by Paul Richardson »
DaveW
« Reply #10 on: March 20, 2007, 10:04:21 AM »
Thanks guys. Great stuff. I see I had the ID's, but
was the way to go. I would have never figured that out!
There is one small step. Once I have something to share for beginners like me I will post some too.
Needlessto say I will never catch you guys.
Thanks again,
Dave
Fatty
« Reply #11 on: March 20, 2007, 10:22:57 AM »
Dear Paul,
I couldn't to convert your example on VB.NET,
because of my browser not found SymbolTable name
Can you upload here a VB.NET (or on C#),version?
Thanks in advance,
Regards,
Oleg :|
~'J'~
Paul Richardson
« Reply #12 on: March 20, 2007, 10:42:18 AM »
Dear Paul,
Thanks in advance,
Regards,
Oleg :|
~'J'~
Here is the link to Tony's original post in c#... Not sure why you don't have a SymbolTable datatype - I assume you've referenced 'acdbmgd.dll' - What version of AutoCAD are you using?
http://discussion.autodesk.com/thread.jspa?messageID=5437715
Fatty
« Reply #13 on: March 20, 2007, 01:05:15 PM »
Here is complete code
Well, the debugger have not found any error
there, but this is not working for now... :(
Imports System
Imports Autodesk.AutoCAD.ApplicationServices
Namespace WorkSpace
    Public Class InfoDoc
        '//not working for now
        <CommandMethod("DwgCont", CommandFlags.Modal Or CommandFlags.Session)> _
        Public Sub Tests()
            Dim doc As Document = GetActiveDoc()
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim recordName As String = "foo"
            ed.WriteMessage _
   (HasName(doc.Database.BlockTableId, recordName).ToString() & vbNewLine)
            ed.WriteMessage _
   (HasName(doc.Database.LayerTableId, recordName).ToString() & vbNewLine)
        End Sub
        Public Function HasName(ByVal symbolTableId As ObjectId, ByVal recName As String) As Boolean
            Dim str As SymbolTableRecord
            Dim tr As Transaction = _
            Try
                Dim st As SymbolTable = CType(tr.GetObject(symbolTableId, OpenMode.ForRead, False), SymbolTable)
                Dim ste As SymbolTableEnumerator = st.GetEnumerator()
                While ste.MoveNext()
                    str = CType(ste.Current.GetObject(OpenMode.ForRead, False), SymbolTableRecord)
                    If str.Name = recName Then
                        Return True
                    End If
                End While
            Finally
                tr.Dispose()
            End Try
            Return False
        End Function
        Public Function GetActiveDoc() As Document
            Dim doc As Autodesk.AutoCAD.ApplicationServices.Document = _
            Application.DocumentManager.MdiActiveDocument()
            Return doc
        End Function
    End Class
End Namespace
~'J'~
Paul Richardson
« Reply #14 on: March 21, 2007, 02:08:12 AM »
Imports System
Namespace WorkSpace
        Public Sub Tests()
            ed.WriteMessage _
            ed.WriteMessage _
        End Sub
            Try
                        Return True
                    End If
                End While
            Finally
                tr.Dispose()
            End Try
            Return False
        End Function
            Return doc
        End Function
    End Class
End Namespace
~'J'~
How about "And" instead of "Or"
CommandFlags.Session And CommandFlags.Modal
