Author Topic: 3d solid model problem  (Read 4871 times)
Martin-Y
« on: June 21, 2004, 10:34:05 AM »
I am struggling to make this shape in ADT3.3
Two triangles 4,5,6 over 1,2,3 one above the other except the apex
Point 1 = 0.0000,0.0000,0.0000
Point 2 = 2500.0000,915.0000,0.0000
Point 3 = 5000.0000,0.0000,0.0000
Point 4 = 1500.0000,0.0000,3850.0000
Point 5 = 2500.0000,1415.0000,3850.0000
Point 6 = 3500.0000,0.0000,3850.0000
Points 1 & 4 connect
Points 2 & 5 connect
Points 3 & 6 connect
side 1,2 5 4 is non planar
side 2,3,6 5 is non planar
Transition needs to be smooth not triangulated.
I need this as a 3d solid, can it be done in ADT3.3, if not what upgrade path would you suggest bearing in mind I need Autocad for other add-ons.
daron
« Reply #1 on: June 22, 2004, 08:22:35 AM »
If you can draw those triangles in autocad, you can convert them into a massing element for ADT. Either way works.
Anonymous
« Reply #2 on: June 22, 2004, 10:33:21 AM »
Thanks for reply Daron but it doesn't seem possible to have different heights for the triangle, the grips are in the centre not at each apex.
Martin-Y
« Reply #3 on: June 22, 2004, 10:55:56 AM »
Sorry that was me being forgetfull not logging on
