Author Topic: Plot freezeing at 48 bytes in printer que  (Read 7475 times)
« on: March 16, 2007, 05:57:53 PM »
I am still having problems with this code.  I'm not sure if its the code or if it's the printer I'm sending my test to.  I have redesigned it a little, and I like the format now better (for now  :-D).  Does anyone have any ideas why it will stop spooling the print file in the printer at 48 bytes?
On a side note:
Does anyone have any simple examples of dragging items in a listview to reorder them?  The ones I have seen seem complicated, but if that is the only way, then I will drive in a see what they are doing.
Thanks in advance.
TonyT
Re: Plot freezeing at 48 bytes in printer que
« Reply #1 on: March 17, 2007, 11:56:45 AM »
Hi Tim.
There's probably no simple examples, because
drag and drop operations in a listview are not
simple. ;)
Have a look here:
   www.codeproject.com/cs/miscctrl/DragAndDropListView.asp
« Reply #2 on: March 18, 2007, 02:38:17 AM »
Hi Tim.
simple. ;)
Have a look here:
That is what I was scared of Tony, thanks for the conformation.  I will have a look on Monday when I can try some coding with it.
« Reply #3 on: April 03, 2007, 05:36:21 PM »
An update.  I have been talking back and forth with the ADN, and we are not getting anywhere.  They did make me test different things, and the program will plot to file just fine, but that is the only way it will work right now.  If anyone has any idea I would LOVE to get this working.
Thanks in advance.
« Reply #4 on: May 15, 2007, 03:28:00 PM »
                               YES!!!
I finally got it to work.  I had an epiphany last night while trying to sleep.  I change one thing, and now it works.  The problem was I was setting last plot to false until the last drawing selected was to be plotted.  So today I changed it to always be true, and it works.  I think that last plot is only false if you are plotting more than one space per drawing, but since I'm not, it will always be true.
Maybe I confused myself by calling it LastPlot, when in the arx help it calls it LastPage
Should I tell ADN?  They couldn't help me... I guess I will so that someone like me doesn't have to find this out by themselves.
I'm so happy right now.  Attached is the one that works per my testing in '06.
« Reply #5 on: May 15, 2007, 07:00:01 PM »
I'm really happy for you Tim .. I know you've had a tempestuous relationship with this routine.
« Reply #6 on: May 16, 2007, 11:44:30 AM »
Thanks Kerry.  It does feel really good to know this one works.  My old lisp one worked, but this one doesn't close the open drawing, and this one opens them up as read only, so it doesn't matter if they are open already, it will open them and print them.
LE
« Reply #7 on: May 16, 2007, 11:58:54 AM »
Tim;
I did a quick view to your code, and it is great to see you, now writing in C#.... cheers man! :)
« Reply #8 on: May 16, 2007, 12:15:56 PM »
Tim;
Thanks Luis.   :-D  Been a long way from when you first starting helping me with Lisp over on the Adesk Ng.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #9 on: May 16, 2007, 12:19:34 PM »
What no piccy? :-o
Come on, do a victory lap!
« Reply #10 on: May 16, 2007, 01:18:25 PM »
What no piccy? :-o
Okay just for you.  I guess I should change the version number to 1.0 since it works now.
Side note: Thanks Glenn for posting how to make .Net applications auto load.  I have mine set up like that now, and love it.
Maybe should add a pic of an empty printer que. :-D
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: May 16, 2007, 01:44:41 PM »
Thank you,
Excellent Work Tim!  8-)
« Reply #12 on: May 16, 2007, 03:21:02 PM »
Thank you,
Thank you Daniel.
« Reply #13 on: May 17, 2007, 06:40:43 PM »
New question with this routine.  I might have gotten to happy to quickly.
Is there a difference between printers and plotters?  My code will work on printers, but gets and error 'eInvalidInput' when trying to send to the plotter.  I will place some message boxes in my code to see if I can find out where it is coming from.
Thanks in advance.
Edit:  Here is the offending line in my code.  Now to see why.....
PltSetVald.SetPlotConfigurationName(PltSet, DeviceName, Paper);
Edit:  I'm thinking the CononicalMediaName is different than the LocalMediaName for the plotter, but not the pritners.  Off to do some testing.......
« Last Edit: May 17, 2007, 06:56:14 PM by T.Willey »
« Reply #14 on: May 17, 2007, 07:32:16 PM »
That was what I had to do.  Here is the code I used for now.
PlotConfig pc = PCM.SetCurrentConfig(DeviceName);
foreach (string str in pc.CanonicalMediaNames) {
if (string.Compare(pc.GetLocalMediaName(str), Paper) == 0) Paper = str;
